Tcash Samba Member
Posted: Sun Sep 24, 2017 9:54 am Post subject: Re: Start but..... |
WESTYJACK wrote: |
I'm going to buy my fuel pressure tester
question
on the double relays each relay was ground by pin 85
where is that ground is it suppose to be with the bolt that hold the 2 relays? |
That ground either goes to the ECM (electronic control unit) OR has a Ring connector under the bolt that hold the 2 relays.
WESTYJACK wrote: |
upgrade
fuel test pressure between 3-4 cyl on port 10psi
disconnect gauge and install direct on pump 10psi
WOW BRAND NEW |
The fuel pump may be good. But the fuel tank is clogged. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Sep 24, 2017 10:35 am Post subject: Re: Start but..... |
WESTYJACK wrote: |
next problem afert 17 years not moving a think clutch is seize
i got under and the cable work the tranny leveller move
but tranny in 1 clutch down start and the westry move foward |
It's not unusual for a clutch plate to stick to the flywheel after a long outdoor sit. Warm the engine up and shut it off, then start it in 1'st gear with the clutch depressed and drive around the yard while poking the gas pedal now and then (clutch pedal depressed constantly), it usually breaks loose. This assumes the bus is aimed towards an area where you can drive around safely. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
WESTYJACK Samba Member
Joined: February 21, 2017 Posts: 266 Location: LAVAL,QC CANADA
Posted: Sun Sep 24, 2017 12:57 pm Post subject: Re: Start but..... |
Thanks Busdaddy
try it next week
little problem with the brake try to bleed it but only one line from original equipment were kipping an it's no good
have to replace it but not a big job an all line will be new |
Posted: Sun Sep 24, 2017 1:00 pm Post subject: Re: Start but..... |
Tcash
the fuel system work with jerrycan
tank is to old and durty will order new tank for next spring when the engine gonna be drop |
Posted: Sun Sep 24, 2017 4:38 pm Post subject: Re: Start but..... |
his alive
Tcash Samba Member
Posted: Sun Sep 24, 2017 6:33 pm Post subject: Re: Start but..... |
Whoohoo
You got the time?
Timing |
Posted: Mon Sep 25, 2017 5:01 am Post subject: Re: Start but..... |
repair my brake line
unstuck the clutch
timming light time
after i'm suppose to be able to move it around the house
next spring i'll drop the engine to check everything (small oil leak)
someone tell me to recheck compression (low compression on 1)after the engine start and run for a little bit
maybe stick ring on piston |
Tcash Samba Member
Posted: Mon Sep 25, 2017 9:35 am Post subject: Re: Start but..... |
WESTYJACK wrote: |
Pour about 30 ml of one of these products down each spark plug hole and let it soak.
http://www.marvelmysteryoil.com/index.php/site/mmo/
https://seafoamsales.com/
Automatic transmission fluid |
Posted: Mon Sep 25, 2017 4:51 pm Post subject: Re: Start but..... |
I'll try it but maybe not endoff
for my idle where do I began troubleshooting it
no idle at all hot or cold
I know it's praticaly impossible to have good idle if the compression is not to good an no vacuum hose change but I only need a little idle to move it around the house until next spring |
Tcash Samba Member
Posted: Wed Sep 27, 2017 8:44 am Post subject: Re: Start but..... |
thanks Tcash
i buy a dwell-tach meter from ebay wait for it |
Posted: Wed Sep 27, 2017 10:06 am Post subject: Re: Start but..... |
WESTYJACK wrote: |
thanks Tcash
Get on Craigslist locally, there's hundreds of former Sunday tinkerers and backyard mechanics who are moving into care homes and thier kids are cleaning out the basement. You can score a badass set of tools like dwell meters, timing lights, torque wrenches, etc.. for dirt cheap, and it's often the good stuff made to last, opposed to the disposable new trash sold today. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Sep 27, 2017 2:01 pm Post subject: Re: Start but..... |
thanks you
my garage is not the biggest one but for tool i got
the thing i need for restoration and mecanic
restore a renault 5 gtl 1984
Fiat 1974 x19 roadster with back engine
so i goat a good kind of tools
the dwell meter not needed for my other car because electronic ignition |
Posted: Sat Sep 30, 2017 3:17 pm Post subject: Re: Start but..... |
I work on my bus today
unstuck the clutch (rear wheels up start on 1frst full brake that'st it)
wait for my dwell meter
wait for my exhaust
here's a video of the first mouvement of the bus by it own after 17 years
Tcash Samba Member
Posted: Sat Sep 30, 2017 4:26 pm Post subject: Re: Start but..... |
It's Alive!! |
Tcash Samba Member
Posted: Sat Sep 30, 2017 4:40 pm Post subject: Re: Start but..... |
You should run some fuel injection cleaner through the fuel system and see if that will improve the running. Also check and recheck for vacuum leaks, these things have lots of hoses, boots, elbow, etc and they all leak with time causing running problems. |
Tcash Samba Member
Posted: Sat Sep 30, 2017 5:43 pm Post subject: Re: Start but..... |
tanks guys
tomorrow i'll check for major leak because all hose gonna be change at spring
i only need a little idle for moving around until next spring
dwel is comming
exhaust is comming
cross my finger to have idle
it's my first time with air cooled do you know if and engine with bad exhaust (straight pipe) can get idle
I know a water cooled it is very difficult with no exhaust |
Posted: Sat Sep 30, 2017 5:52 pm Post subject: Re: Start but..... |
Trick to find a vacuum leak with no idle |
