Joined: May 21, 2017 Posts: 2 Location: Albuquerque, NM
Posted: Sat Sep 23, 2017 7:07 pm Post subject: Speedometer Noise |
Help, my 1985 Vanagon Westy has a noise that emanates from the speedometer when the outside temperature is cool/cold say below 70degrees F. I have replaced the speedometer cable thinking that was the issue but no luck. Is lubrication the answer and if so what do i lube and with what type of lubricant? Thanks. |
Vnyd Dog Samba Member
Posted: Sat Sep 23, 2017 8:13 pm Post subject: Re: Speedometer Noise |
When my speedometer was making noises it was actually the odometer issue and the cog spinning on the shaft. Once I fixed that the noises were gone. Ymmv _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
https://www.thesamba.com/vw/forum/viewtopic.php?t=713391&highlight=life |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Sun Sep 24, 2017 5:27 am Post subject: Re: Speedometer Noise |
The noise is more of a screetch that is pretty loud. |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Sun Sep 24, 2017 6:23 am Post subject: Re: Speedometer Noise |
My toyota truck did this and the screach was intense. It was also the odometer and not the cable as I had assumed. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
E1 Samba Member
Joined: January 21, 2013 Posts: 6572 Location: Westfalia, Earth
Posted: Sun Sep 24, 2017 7:32 am Post subject: Re: Speedometer Noise |
Mine makes a rattling-drill sound but only if near freezing. In this case it's the cable... I *think* (and then get a pounding headache).
It's even jumpier than usual when it happens, too. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
