esotericsean Samba Member
Joined: July 12, 2016 Posts: 54 Location: California, USA
Posted: Thu Sep 28, 2017 9:29 pm Post subject: Re: Can I use flux core wire to weld body panels? |
I'm not trying to convince anyone that what I'm doing is correct, I'm really just trying to understand the proper way of doing it (it's been very confusing trying to teach myself).
At the same time, this is all I currently have so I'm trying to see if I can get away with it. I really appreciate everyone's input. I understand that I need a proper gas MIG with thinner wire. _________________ My 1966 13 Window Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=672199 |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Thu Sep 28, 2017 11:24 pm Post subject: Re: Can I use flux core wire to weld body panels? |
Yes it is a complex subject, with no real in depth places to learn how to do it well. There is a reason though.. sheet metal welding is not just a technical job; it truly takes an artistic understanding, or a designer’s eye.
You learn something new every single job. It’s like teaching crayon drawing or finger painting.. we all start at the basic level but few of us get really good, and even fewer master it.
The best way to learn how to do what you’re asking is actually really simple. Get a MIG welding setup, get a body hammer and dolly set, and spend some time welding sheet metal on junk. It’s not magic or mysterious at all, it’s like romancing your girlfriend... it takes time, patience, finesse, an eye for details.
Once you get your panel welded in, knock down the heavier spots with a 40-60 grit flap wheel on a 4” angle grinder.. don’t get into the base metal though. Once you knocked down the mountains, start working on the hills with a die grinder and 3M roloc dics, smoothing things out. Bump your grit levels up as you go, feeling out what the area needs. Shine a bright light behind your panel and look for pinholes or missed areas, then sharpie mark them and go back over with the welder.
Yes, your panel needs to be absolutely perfect when you finish with the rolocs... ideally if you started with a small uniform gap all the way around before you started welding, and you took your time tacking it in, there won’t be any major issues. Use a hammer and dolly every few tacks if possible; you’re just trying to persuade the metal back out a little to keep its shape and prevent the weld contraction from distorting the area.
Don’t use glass or body filler to compensate for an ugly finish job or poor welding. Ugly welds are usually bad welds. My preference is to spray my panels with a 2k epoxy primer, weld through it where I can, then shoot epoxy over the finished panel followed by a 2k high build primer. The high build is where you start to hide the minor welding imperfections... use Rage Gold body filler if you need it.
I see all the time in the Bay forum, guys will go to town cutting, then realize oh SH** bit off more than I realized! Then it’s followed with popcorn looking spattered welds, distorted metal, and finally a thick layer of body filler. We all started somewhere but it just really sucks to ruin an otherwise salvageable project with costly mistakes.
All that to say just work towards your goal. Once you have the right tools and some practice, you’ll know when you’re ready to jump on something as complex as a body panel. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Sat Sep 30, 2017 5:19 pm Post subject: Re: Can I use flux core wire to weld body panels? |
From the image posted here https://i.imgur.com/qHz5TWU.jpg ,it looks like you have the process down. For most people the learning curve is too steep but you have managed it. You have to watch the heated weld zone and not the pool.
After you figure it out. MIG is mostly just faster than 'Flux Core Repeated Spot welds'. The same method is used with both on butted thin sheet metal. You have to grind down the welds on both so mostly the end result is the same.
The only big difference between the two is if you weld upside down , flux spatters a lot (it' does not use (Short Circuit Transfer) so you HAVE to use the proper safety gear like long welders gloves and DO NOT lay directly under the pool but to the side.
If your in doubt you can try to horizontal Flux Core weld on a test piece. I don't notice a difference. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Gordo_89 Samba Member
Posted: Sun Apr 01, 2018 1:46 pm Post subject: Re: Can I use flux core wire to weld body panels? |
Good evening,
First attempt of welding using flux cored wire following many hours practice I believe I have a good Weld
Front
Back
However I seem to have inconsistent penertration in the metal when I'm not blowing holes as you can see
Grinding down has highlighted missing weld
I will try gas welding tomorrow if I get the chance. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Apr 01, 2018 3:30 pm Post subject: Re: Can I use flux core wire to weld body panels? |
It looks like the metal is overlapped? I thought butt welding is preferred. Your last picture looks pretty good though! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sun Apr 01, 2018 5:44 pm Post subject: Re: Can I use flux core wire to weld body panels? |
What we really should be looking at ,is images of a series of spot welds ,started from the last spot weld ,done in a row to mimic a bead. The issue with Flux Core welding thin metal is that it welds hotter ,has more arc force ,and the wire is mostly flux and not metal. So its a challenge to start from scratch once. There is no point in repeating it. Do 3 or more spot welds to hold the piece where you want it. Then start your next spot weld on one of the last spot welds and overlap it by 1/3 to 1/4 of the diameter. Do maybe three of these in a row before moving to another area to keep heat down.
The same method is used for MIG but looks better and is a lot faster. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Posted: Mon Apr 02, 2018 1:16 pm Post subject: Re: Can I use flux core wire to weld body panels? |
They are butt welded close together. I have read that the closer the joint the less chance of blowing through. I will give it another shot when I get chance _________________ 1989 Vanagon 2.1L |
Posted: Mon Apr 02, 2018 3:51 pm Post subject: Re: Can I use flux core wire to weld body panels? |
After coming to grips that overlapping body panels had many disadvantages I was lucky to come across this webpage.
https://www.cartechbooks.com/techtips/mig-butt-welding/
This explains it all. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Braukuche Samba Member
Posted: Fri Apr 06, 2018 2:34 pm Post subject: Re: Can I use flux core wire to weld body panels? |
Flux is fine, in fact better in certain circumstances, like if you have to work outside and there is wind.
If you clean off your welds well then you don't have to worry about paint reaction. Ive used flux for years, never had an issue.
In the end both do the same thing, they bond metal together. One is arguably more efficient but it's not like only one works. Both are also primitive technology, we all would be better off bonding panels with modern adhesives, far stronger and don't distort panels. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Sat Jun 20, 2020 3:47 pm Post subject: Re: Can I use flux core wire to weld body panels? |
Evil_Fiz wrote: |
67ctbug wrote: |
Mig all the way! So much more control over the job. Try to find a mig 135 from Eastwood, great welder at an affordable price. |
If you can wait until Black Friday, you might get lucky and find a promo code on-line for a deep discount on the Eastwood MIG 135. I was able to score one last year (2016) for $199 + free shipping. It is a very nice welder for the hobbyist with infinite adjustability and an included gas regulator. |
Adding an update for future readers.
The Eastwood MIG 135 has been performing well but I discovered the hard way that it has a strong limitation in relation to sheet metal welding. The welder does not have the ability to turn off shielding gas post-flow. The gas solenoid remains open for about one second after the trigger is released. When you are doing short half-second tacks you end up using three times as much gas as you would with post-flow turned off. I ended up going through a 40 Lbs. bottle of gas and only used 1/3 of a 2 Lbs. spool of wire.
For the reasons mentioned above I switched to using flux core wire to do my panel repairs. It took me a while to find the right settings. I am welding-in patches made from metal taken from another Ghia (OE metal, same gauge as the metal on my car.) The welds require some clean-up but the money I save is worth it to me. I am not building a show queen so I am not beyond using filler to cover up mistakes and imperfections.
Eastwood MIG 135 Flux core settings for sheet metal:
Wire Speed = 2
Voltage = B - B 1/2 (Mostly on B however)
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted
modok Samba Member
Posted: Sun Jun 21, 2020 1:09 am Post subject: Re: Can I use flux core wire to weld body panels? |
yep that thing is a gas hog, not really a problem tho
Use straight co2 gas instead of fancy argon mix, it's cheap. |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sun Jun 21, 2020 1:30 am Post subject: Re: Can I use flux core wire to weld body panels? |
You can also dial back your gas bottle pressure regulator, it won't stop the post weld flow but can reduce the volume used if welding in a still air environment like a closed in workshop _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Posted: Sun Jun 21, 2020 5:03 am Post subject: Re: Can I use flux core wire to weld body panels? |
modok wrote: |
Thanks for the tip. Based on what I have read on-line I wasn't sure if straight CO2 was a viable option.
66brm wrote: |
You can also dial back your gas bottle pressure regulator, it won't stop the post weld flow but can reduce the volume used if welding in a still air environment like a closed in workshop |
I dialed it back to almost nothing and it is still a "gas hog" as stated above. I am going to open up the welder and see if I can hack it so the solenoid cuts out with the trigger release.
kiwighia68
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Canghia Samba Member
Joined: June 27, 2017 Posts: 70 Location: Toronto Ontario
Posted: Mon Jun 22, 2020 5:09 am Post subject: Re: Can I use flux core wire to weld body panels? |
Emil,
Wbat about trying another solenoid. My Lincoln 110 MIG was a flux core only but when I looked at the circuit board I saw the connectors there for gas. I ordered a solenoid from someone on Ebay and it was basically plug and play. It worked well. Well enough to get done what I needed. A better welder would have made my life so much easier. Mine was a basic machine.
Mark |
Posted: Mon Jun 22, 2020 2:55 pm Post subject: Re: Can I use flux core wire to weld body panels? |
Canghia wrote: |
Emil,
Mark |
I will look into your suggestion. I need to figure out if the delay is built into the solenoid or if it's controlled by the circuitry.
kiwighia68
modok Samba Member
Posted: Tue Jun 23, 2020 10:10 pm Post subject: Re: Can I use flux core wire to weld body panels? |
Evil_Fiz wrote: |
wow
I generally get my info from the Lincoln welding company. |
finray Samba Member
Joined: May 11, 2019 Posts: 108 Location: Birmingham, AL
Posted: Sun Jan 10, 2021 9:04 pm Post subject: Re: Can I use flux core wire to weld body panels? |
I know this is an older thread but wanted to share this video. Found this video today and was curious what you all thought about what he is saying about flux core.
https://youtu.be/ic7Gwf8y4Yc |
fredybear Samba Member
Posted: Mon Jan 11, 2021 11:46 am Post subject: Re: Can I use flux core wire to weld body panels? |
See how he does that, tap and let cool, tap and let cool.
That's the way its done.
You can lay a nice bead like that. |
Posted: Mon Jan 11, 2021 5:21 pm Post subject: Re: Can I use flux core wire to weld body panels? |
finray wrote: |
That video makes me both depressed and angry. As I mentioned above I switched to flux due to excessive gas consumption. I am able to do butt weld patches but, because of my failing eyesight, I keep blowing holes in the panels (so wire welding is no longer in my future). I can confirm however that it is possible and doable even by the most inexperienced welder.
I may consider torch welding/brazing as an option in the future.
modok wrote: |
Evil_Fiz wrote: |
Based on what I have read on-line I wasn't sure if straight CO2 was a viable option. |
wow
That did sound kinda boneheaded. What I should have said is that there is an opinion in the welding forums that straight CO2 is too hot for sheet metal welding. On your advice, I tried to get CO2 from Airgas but I would need to buy a different bottle and the cost of CO2 vs Ar/CO2 mix is only six dollars.
Canghia wrote: |
Emil,
What about trying another solenoid. My Lincoln 110 MIG was a flux core only but when I looked at the circuit board I saw the connectors there for gas. I ordered a solenoid from someone on eBay and it was basically plug and play. It worked well. Well enough to get done what I needed. A better welder would have made my life so much easier. Mine was a basic machine.
Mark |
I finally got into the welder. The post flow is controlled by the circuitry and not the solenoid. I took voltage readings from every possible tap on the board but none fit the bill.
kiwighia68
infiniteLoop Samba Member
Joined: October 09, 2020 Posts: 265 Location: Empire State
Posted: Mon Jan 11, 2021 6:57 pm Post subject: Re: Can I use flux core wire to weld body panels? |
MIGs without the solenoid have a mechanical switch in the gun that works fine. Why not bypass the board and have the switch in the gun close the circuit with the solenoid? |
