KOMBI NIKO Samba Member
Joined: February 03, 2013 Posts: 278 Location: Australia
Posted: Mon Sep 25, 2017 3:02 pm Post subject: Re: empi oil cooler kit? |
[quote="Glenn"]
KOMBI NIKO wrote: |
Eric&Barb wrote: |
KOMBI NIKO wrote: |
Hi guys I'm running a 1916cc motor in my 61 bus and its not liking the hot weather, I'm getting temps around 260F on the highway with in 20 mins driving on a hot day (84f) |
1. Which non-external cooler do you have now?
2. Which crankshaft pulley?
3. Which gen/alt pulley?
4. What size cooling fan (inside measurement)? |
I don't have a external cooler on the motor just the internal one.
Pulleys are stock original ones both top and bottom.
Internal fan is also stock. |
There are different stock parts.
Make sure you have a dog house fan shroud along with the correct fan, oil cooler and pulleys. Having a non-dog house fan will not cool correctly.[/quote
They are the right parts as Stan built the motor. _________________ https://www.instagram.com/demop_garage/
https://www.facebook.com/Demopgarage/
https://www.youtube.com/@DEMOPGARAGE/featured |
Posted: Mon Sep 25, 2017 3:09 pm Post subject: Re: empi oil cooler kit? |
Eric&Barb wrote: |
KOMBI NIKO wrote: |
1. Which is why we asked "Which non-external cooler do you have now?". Non = not. There are three possibilities of stock coolers you could have installed internally.
2. Stock crankshaft pulleys changed outside diameters over the years. Some years getting smaller and some years getting bigger. Bigger OD pulley means higher fan RPM speed in-comparison to the crankshaft RPM, for more air pumped over the engine. Smaller OD means less air....
3. Stock VW gen/alt pulley is larger than the stock Porsche 356 gen/alt pulley for more fan RPM than the stock VW one. See above for what higher fan RPM gives you...
4. As both compression was raised and cubic centimeters of each generation of VW engine increased so did the fan change. Widened a little each time and even the number of fan blades increased in number. EG if you used a stock single port 1500/1600 cc engine fan in an engine with dual port dog house cooler/shroud system, you are going to have a whole lot of cooling engine problem.
So if you could answer the 1, 2, & 4 questions.... |
So the fan and both pulleys were for a 1600cc twin port motor. I will measure the pulleys to get a dia. Internal oil cooler I don't know as Stan would have supplied that part but it does have a dog house tin on. _________________ https://www.instagram.com/demop_garage/
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Mon Sep 25, 2017 4:36 pm Post subject: Re: empi oil cooler kit? |
Sounds like Stan needs to answer your questions and reassure you that the oil temps are OK and will warranty any problems. _________________ Glenn
Member #1009
#BlueSquare |
fabo Samba Member
Posted: Tue Apr 10, 2018 5:11 am Post subject: Re: empi oil cooler kit? |
KOMBI NIKO wrote: |
Glenn wrote: |
Sounds like Stan needs to answer your questions and reassure you that the oil temps are OK and will warranty any problems. |
I will talk to him again, the temps do drop once i get off the freeway so maybe it is a fan/airflow issue. |
What was the outcome of this??? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Tue Apr 10, 2018 5:15 pm Post subject: Re: empi oil cooler kit? |
Yes, what's up??
Twin ports AKA dual port engines came out with 33 mm wide fan (inside measurement), later a 34 mm wide fan, then the last was a 35 mm wide fan. So you could have one of three fans in there...
You also need to get the carb/s jetted just right. While it might run too lean at a certain RPM, it could be running way too lean at another RPM.
KOMBI NIKO wrote: |
So the fan and both pulleys were for a 1600cc twin port motor. I will measure the pulleys to get a dia. Internal oil cooler I don't know as Stan would have supplied that part but it does have a dog house tin on. |
_________________ In Stereo, Where Available! |
scubaseas Samba Member
Joined: May 24, 2013 Posts: 442 Location: ME & Texas, in a Bus or on a boat somewhere
Posted: Tue Apr 10, 2018 5:55 pm Post subject: Re: empi oil cooler kit? |
My oil temps went up about 20*F when I put a freeway flyer in my bus. Smaller generator pulley may help Or a bigger crank pulley. Or both. A 7" crank pulley, 356 Generator pulley and smallest 13 mm belt you can get on it will give you the highest fan speed.
Ideally you want a welded and balanced 71+ (widest) cooling fan and the appropriate dog house fan shroud/housing.
Atomic-cool brand plate type oil cooler works well if the pulleys/fan don't solve the issue. Use a thermostatic switch on the fan. _________________ Al
08/1970 T2a Westphalia owned since 1980
ASE Master certification. 50 years pushing a wrench
Retired |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1106 Location: Burlington, WA
Posted: Wed Apr 11, 2018 3:56 pm Post subject: Re: empi oil cooler kit? |
I'm not a fan of Empi products either, as we all know their typical quality, but I did use their oil cooler/fan setup. I have it ~mid bus on the drivers side, ran with stainless braided teflon hose, a thermostatic oil filter sandwich plate, and a thermostatic fan switch... Never had an issue with it and it makes a noticeable difference... And got it new at bug-o for a good price... _________________ -Adam
'59 Mango Bus
'11 Golf TDI 6-speed
'69 Bug |
Nubby Samba Member
Joined: August 28, 2010 Posts: 605 Location: Down by the river
Posted: Wed Apr 11, 2018 8:28 pm Post subject: Re: empi oil cooler kit? |
I run a 1904 stroker in my bus in AZ with a Seatrab cooler. No issues |
charles henson Samba Member
Posted: Tue Sep 21, 2021 1:39 am Post subject: Re: empi oil cooler kit? |
how many fins 28? or more.. _________________ 71 deluxe
71 s.c.
73 factory sunroof |
Posted: Tue Sep 21, 2021 9:07 am Post subject: Re: empi oil cooler kit? |
KOMBI NIKO wrote: |
sorry for the late reply, I did end up changing out the top gen pulley to a Porsche 356 one and it made a big difference in temp, doesnt get above 225 now. |
That is great to hear! Thanks for the update. _________________ In Stereo, Where Available! |
