elpres Samba Member
Posted: Mon Sep 25, 2017 10:59 am Post subject: Wheel bearing |
Hi, i found my rear wheel bearing was dead, and therefore I ordered a new wheel bearing kit.
I received the kit and the inner bearing was easy to change.
The outer bearing was giving me trouble, I tried to cool it down and to heat up the bore, no luck... couldn't even get the new KML bearing to sit in the hole.
Then I measured the OD of the bearing and I was 62,3mm, and the bore is 62,0mm.
Is it possible to get that bearing squeezed in? _________________ Jakob |
busdaddy Samba Member
SGKent Samba Member
Posted: Mon Sep 25, 2017 12:38 pm Post subject: Re: Wheel bearing |
IMHO the KML bearings are junk. The steel is full of scratches - sort of implying it is soft. The ones I got fought me like crazy - and I had done the job on other bays before. I was afraid to run it because it was oval. Pulled it and put in a FAG bearing - and it slide in properly, not loose and not overly tight. I told the vendor I got them from to stop selling them because they are junk, so have other people here but I suspect our words fall on deaf ears sometimes. Don't use those or you will regret it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
elpres Samba Member
Posted: Mon Sep 25, 2017 1:01 pm Post subject: Re: Wheel bearing |
Anyone knows where to buy a FAG outer bearing? Preferably in EU and on a internet site? _________________ Jakob |
SGKent Samba Member
Posted: Mon Sep 25, 2017 1:04 pm Post subject: Re: Wheel bearing |
is this on the 1976? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
elpres Samba Member
Posted: Mon Sep 25, 2017 1:07 pm Post subject: Re: Wheel bearing |
No the 75 _________________ Jakob |
SGKent Samba Member
Posted: Mon Sep 25, 2017 1:30 pm Post subject: Re: Wheel bearing |
I did not see any FAG bearings on ebay.de but they do have SKF which should work too. Call around to your local VW shops and see if anyone has the SKF or FAG bearing outer. The part number should be 211-501-283D _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Tcash Samba Member
Posted: Mon Sep 25, 2017 2:08 pm Post subject: Re: Wheel bearing |
Here is the part number 211-501-283-D. You may find it in Febi.
Good luck
Tcash |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Mon Sep 25, 2017 4:30 pm Post subject: Re: Wheel bearing |
this is a well known problem.
so the last time i did this job, here's what i did:
OG
FAG
KML
pretty obvious, no? _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Abscate Samba Member
Posted: Mon Sep 25, 2017 5:16 pm Post subject: Re: Wheel bearing |
That is asppalling
_________________ .ssS! |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
elpres Samba Member
Posted: Mon Sep 25, 2017 11:20 pm Post subject: Re: Wheel bearing |
It seems difficult to find anyone around here (Denmark), that has the FAG bearings, but I found a private guy that has a SKF rear wheel bearing kit, for 350dkr (41£). So I'm gonna pick that up. _________________ Jakob |
elpres Samba Member
Posted: Fri Oct 06, 2017 11:40 am Post subject: Re: Wheel bearing |
I finally Got my hands on some skf bearings. And I followed this great guide http://www.itinerant-air-cooled.com/viewtopic.php?t=11737
It all went well but One thing I’m not sure about is, that I feel some resistance/binding when turning the stub axel by hand. Compared to the other side it’s a lot. It’s not the outer bearing making trouble and I dident need to use the hammer very much to tap the stub axle in. Could the inner rear seal create that much resistance? Is it normal behavior to have some resistance with a brand new setup?
Any thoughts? _________________ Jakob |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Fri Oct 06, 2017 12:38 pm Post subject: Re: Wheel bearing |
I seem to remember it being a little harder to turn a fresh bearing but not binding.
Please make sure that the roller bearing shell is fitted exactly straight .
And check that it it is very well packed with grease - I failed to do this and ended up with the outer bearing shell starting to melt - this is after about 50km driving including 110kph running.
I then fitted another identical bearing from a low cost supplier here in the UK and another the other side, a bearing from VWH.
The cheaper bearing was larger outside diameter and before fitting, it was quite loose on the inner sleeve but it crushed slightly as it was knocked into place. It was then stiffer but did not bind at all.
I have now driven well over 30000 km on both the cheap no-name and the VWH bearing.
I believe that grease and good alignment are possibly more important than whether the bearing seems to fit well.
A big enough hammer and a 46mm drive impact socket using the stub axle as a guide seems to work to get it in there.
This all comes from a how-to I wrote http://www.thelatebay.com/index.php?threads/rear-wheel-bearing-replacement-in-progress.63457/ _________________ Ancient vehicles and vessels
elpres Samba Member
Posted: Sun Oct 08, 2017 12:20 am Post subject: Re: Wheel bearing |
I made a little video then you guys maybe better can see what I’m concerned about.
SGKent Samba Member
Posted: Sun Oct 08, 2017 7:35 am Post subject: Re: Wheel bearing |
a new seal will make it harder to turn but it should not feel gritty or uneven. If it seems wrong try it without the seals then put new ones back in after the test, make sure you grease them before installing them. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Oct 08, 2017 8:52 am Post subject: Re: Wheel bearing |
In your video it looks a little stiffer than mine ..mine had resistance but with a wheel on the hub it still span freely.
The lip seals should not drag if they are greased.
Check the outer bearing cage is exactly square in the hub carrier.Then if you are certain the grease is packed well in the bearing I would try assembling the hub and brake drum.
Then drive on it. If it is OK then it will last more than say 100km.
If it goes bad .. you needed to change it again anyway.. _________________ Ancient vehicles and vessels
Tcash Samba Member
Posted: Sun Oct 08, 2017 9:17 am Post subject: Re: Wheel bearing |
Push the stub axle half way in, so it is riding only in the inner bearing. Try it. Still stiff, the problem is in the inner bearing.
Remove the stub axle and install into the outer bearing and test. Still stiff, problem is in the outer bearing.
If both bearings are smooth with the axle only installed half way. The bearings are misaligned. Make sure bearing races are square in the bearing housing bore.
Good day
Tcash |
elpres Samba Member
Posted: Fri Oct 13, 2017 6:09 am Post subject: Re: Wheel bearing |
Thank you guys for some good posts.
I knocked the stub axel out once again and then put another rear seal on it, and then turned the axel, holding on to the seal. And the resistance felt like the amount I felt when the axel was mounted on the car.
So I feel good now about it, and has put it all together again. _________________ Jakob |
