Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Jul 30, 2018 8:29 am Post subject: Re: LandSpeed Buggy |
Friend of mine wanted to run rubber fuel hose to right hand side carb so he went behind shroud... Suddenly one day had fuel "problem".... Fan actually (somehow) sucked fuel hose in and shredded it..... Have always thought the old screen trick (for sticks and leaves) on fan shroud has/had some merit....
https://socalautoparts.com/shop/engine-tinsheet-metal/fans-accessories/fan-intake-screen-chrome/
And then there is that overlooked shop rag or wad of paper towels and the mouse nest...
slalombuggy Samba Member
Posted: Mon Jul 30, 2018 10:34 am Post subject: Re: LandSpeed Buggy |
Ya, I never thought mush of those screens, especially with the fan inlet usually up against the firewall and I figured it would be pretty hard to suck stuff up in there. Now with the engine behind the body and everything out in the open......I got a screen coming with all the replacement parts,
brad |
Posted: Mon Aug 06, 2018 8:01 pm Post subject: Re: LandSpeed Buggy |
Well the engine is all back together. Found a couple of internal issues with the carbs and did a jet change and now it runs even better. Borrowed some proper wheel alignment equipment and got the alignment set. My tape measure alignment was actually very close. I also hung the rear tail lights and license plate and made the brackets for the front headlights to meet the class rules of being "street legal, plated and insured". Everything can come off in 5 minutes after I go through tech.
Before putting the fan shroud on, it requires a lot of trimming to fit the CB bubble top case. I also weld in these vanes that are the same size and spacing as the factory flaps to help direct air. And as you can see in the dog house cooler opening I weld in another flange that fills the gap and fits tight to the base of the oil cooler
brad |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Mon Aug 06, 2018 9:27 pm Post subject: Re: LandSpeed Buggy |
On all my engines I have welded in that little tab for the oil cooler and then you don't need that stupid Hoover bit. I've never done it but have considered welding in the tabs to replace the flaps. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Tue Aug 14, 2018 8:35 pm Post subject: Re: LandSpeed Buggy |
Made the brackets to mount the front "headlights"
Mounted the master electrical switch on the front cowl. I cut all the circular plates on the car out of .100 aluminum and riveted them to the body.
Sat in the car Sunday all geared up and moved the warning and shift lights around till I found spots I could see them the best and they wouldn't interfere with anything.
And I've started getting the pit box together and gathering spares. I'll glue a few sets of valve cover gaskets together to throw in.
The salt is in incredible shape. There are 4 cars that have run over 400 this week and 3 that have run 450+ Everyone is saying how good the conditions are. We leave 4 weeks from today..........
brad
brad |
cdnltded Samba Member
Joined: March 13, 2015 Posts: 381 Location: Pincher Creek, Alberta
Posted: Wed Aug 15, 2018 9:19 am Post subject: Re: LandSpeed Buggy |
This thread ha been a great one to watch and follow Brad. I only wished we could hit a like button on some of your posts.
Anyways from at one time where you thought you were not gonna make it to getting things ready for that just in case issue. It is great to see you make it through and beat the odds.
Good luck |
Firebuggy Samba Member
Joined: November 16, 2010 Posts: 122 Location: Black's Corners, Ontario Canada
Posted: Wed Aug 15, 2018 11:33 am Post subject: Re: LandSpeed Buggy |
cdnltded wrote: |
Ditto! _________________ 2110 build for buggy
The cost of building an engine yourself is like converting to metric..."Double it and add thirty!" |
Posted: Mon Aug 27, 2018 6:16 am Post subject: Re: LandSpeed Buggy |
Chimps dig the car
When it quits raining tomorrow I'm taking the car to the print shop to install the lettering on the aluminum sides.
And I would like to welcome Jackpot Motor$ports as a sponsor this year with a generous donation to help with the costs of getting down to Bonneville. Thanks to Mike and Shelly Sill for their support, much appreciated.
brad |
Posted: Tue Aug 28, 2018 6:57 pm Post subject: Re: LandSpeed Buggy |
I can hardly wait to show my nephew the new lettering on the car. I think he'll be pretty excited
brad |
Posted: Wed Aug 29, 2018 6:35 am Post subject: Re: LandSpeed Buggy |
NICE!!!...
Best of luck in this endeavor....
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Wed Aug 29, 2018 7:13 am Post subject: Re: LandSpeed Buggy |
So amazing and thank you for sharing all the creativity and work that goes into high speed runs.
Blessings and safe racing. Jeff _________________ If I knew what I was doing; I wouldn't be building a buggy! |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1171 Location: San Angelo, Texas
Posted: Wed Aug 29, 2018 9:46 pm Post subject: Re: LandSpeed Buggy |
Just read through this thread and I enjoyed it very much. Anything fast and I'm all in. Good luck and go out there and kick ass. If anyone has Amazon Prime you can stream a documentary movie called, "Boys of Bonneville" and it is a fantastic historical reference. With some surprises, at least for me. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
Posted: Sun Sep 09, 2018 9:29 pm Post subject: Re: LandSpeed Buggy |
34 hours and counting. Car is tied down and the trailer is ready to roll Tuesday morning. Tool box and spares are packed. Went over the entire car every night for the last week and found a couple of little projects to do. Bolted the body on for the last time last night including the headlights to go through tech inspection.
Princess Auto had a yard wagon on sale so I bought one and used a 2'x4' steel shelf and made a pit wagon to pull along as we are in line will hold the cooler, tool boxes, tires, jack and most importantly a large beach umbrella so we have some shade without someone having to hold it all the time.
brad |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Sep 10, 2018 5:24 am Post subject: Re: LandSpeed Buggy |
Safe travels Brad. see you on the Salt
What are you bringing to put in the cooler to drink under the umbrella? _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Tom_Kathleen Samba Member
Joined: August 26, 2004 Posts: 919 Location: Vernon, CT
Posted: Mon Sep 10, 2018 5:41 am Post subject: Re: LandSpeed Buggy |
Good luck! And (I hope you have a) good speed! Tom _________________ Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA |
Posted: Mon Sep 10, 2018 6:24 am Post subject: Re: LandSpeed Buggy |
Keeping fingers crossed you have a successful event...
62kellison Samba Member
Posted: Mon Sep 10, 2018 6:43 am Post subject: Re: LandSpeed Buggy |
awesome!!….got my adrenaline going, just going thru the build pics again!!..GO FAST!!... |
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Mon Sep 10, 2018 6:58 am Post subject: Re: LandSpeed Buggy |
Here's hoping Johnny Canuck brings home a record!
Paul _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
Posted: Mon Sep 10, 2018 1:29 pm Post subject: Re: LandSpeed Buggy |
60ragtop wrote: |
What are you bringing to put in the cooler to drink under the umbrella? |
Water and Gaterade for the pits, ice for the single malt 18 year scotch to celebration at the hotel.
brad |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Mon Sep 10, 2018 3:53 pm Post subject: Re: LandSpeed Buggy |
Here's for a safe trip!
GO BRAD GO!!!! _________________ Jesucristo es mi Señor y Salvador! |
