mark tucker Samba Member
Posted: Tue Oct 09, 2018 2:36 am Post subject: Re: LandSpeed Buggy |
I would ram induce it.but fuel would need to be wached closely.and sealed to the carb so the bowels are also pressurized...but Im sure you know that. or a good air cleaner to get rid of turdbulance witch is a killer.and may be part of the issue in 4th. a variable length stinger may also be nice to try to find the right length in 4th. The buggy looks great!!
as kid I learned about ram air....on a motorcyle. I wantend more power... all it did was to push the fuel back up the jets & out of the bowel and die.I wasent real smart about that kinda stuff back them. if I would of just put the vent hose in the pressure .....it probably would of worked somewhat, but it may also of needed a fuel pump..it was a real head scratcher at 12 years old.
on duel 4's on a v8 tunnel ram Ive seen the fuel pulled right out of the bowel vents at high speed with no air cleaner. lots of fuel.... |
slalombuggy Samba Member
Posted: Tue Oct 09, 2018 9:30 am Post subject: Re: LandSpeed Buggy |
mark tucker wrote: |
One of the guys tried a ram air intake with plumbing elbows glued to the tops of his air cleaners. It didn't work and they spent 20 minutes looking for white plumbing elbows out on the white salt.......
I'm thinking ram air induction but of a mechanical nature. and ditching carbs all together. There ain't no air at Bonneville so I'm thinkin I'll make my own.........
brad |
Posted: Tue Apr 09, 2019 10:45 am Post subject: Re: LandSpeed Buggy |
Parts have started to arrive for the new engine combo.
The newest generation of 044 head casting is terrific. Much cleaner casting. The chambers are thicker and they have moved the valves around a bit to increase strength. The chambers are of a much tighter design too, so should be much better for flame propagation = hp.
And finally taking the leap to get rid of the distributor all together. Next on the chopping block.......carburation.....
brad |
lelef Samba Member
Posted: Tue Apr 09, 2019 11:36 am Post subject: Re: LandSpeed Buggy |
found only now your post..
Posted: Mon Apr 22, 2019 9:56 am Post subject: Re: LandSpeed Buggy |
Well, Changes are a comin' This was taken yesterday. The car was parked after spending the weekend at the big Easter car show (and picked up some hardware). The last time it will run with carbs, merged header and a distributor based ignition system. New heads are sitting in the basement and a CB Gen 4 will be ordered next month.
The last run.
https://www.youtube.com/watch?v=caeOB-zffTw
brad |
Dale M. Samba Member
Posted: Mon Apr 22, 2019 4:25 pm Post subject: Re: LandSpeed Buggy |
Dale _________________ Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
rubenski Samba Member
Joined: December 03, 2014 Posts: 100 Location: belgium
Posted: Mon Apr 22, 2019 7:01 pm Post subject: Re: LandSpeed Buggy |
ccol!!
you won't be dissaponted with the cb gen4. |
cdnltded Samba Member
Joined: March 13, 2015 Posts: 381 Location: Pincher Creek, Alberta
Posted: Mon Jun 03, 2019 5:36 pm Post subject: Re: LandSpeed Buggy |
Any updates on the engine mods? |
Posted: Tue Jun 04, 2019 6:14 am Post subject: Re: LandSpeed Buggy |
cdnltded wrote: |
Nothing yet. I was hoping the dollar might go up a bit before ordering but it's headed the other way..... I'll probably pull the trigger here in a couple of weeks it's just been super busy at work so finding time to talk with Pat or Mark at CB is hard.
I sold my 1.4 Pauter rockers and bought a set of 1.3 Pauters. I'm hoping the pushrods are kind of the right length so I can run the engine a bit. I want to take it to a couple of shows this summer to promote my sponsors so won't be pulling it out till later this year when I strip the car and go through it all.
I'm also busy with a bunch of summer projects and building engines for a couple of guys. Also trying to get my orange buggy on the road. I thought I cleaned it really well after the last trip to Bonneville with it in 2012 but the salt water got everywhere and destroyed a bunch of stuff, but I've got most of it fixed and the new engine and gearbox are in it Just about done the rewiring and then I can get the shifter and park brakes back in it and run a new throttle cable and tube.
I'll be sure to start posting once I'm underway on the racecar. I want to do a fairly in depth thread on the Gen4/turbo install as their seems to be precious little info like that anywhere on the web.
brad |
Posted: Fri Jun 07, 2019 3:35 pm Post subject: Re: LandSpeed Buggy |
cant wait |
Posted: Fri Jul 12, 2019 8:09 pm Post subject: Re: LandSpeed Buggy |
SOMETHING WICKED THIS WAY COMES.
😎😎😎😎STAY TUNED😎😎😎😎
brad |
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Sun Jul 14, 2019 1:43 pm Post subject: Re: LandSpeed Buggy |
Dont make us wait TOO long, the box is only so big....
Paul _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
62kellison Samba Member
Posted: Mon Jul 15, 2019 5:07 am Post subject: Re: LandSpeed Buggy |
really interested in seeing this Brad!!
.I been thinking about putting a turbo on a 1600dp I got laying around taking up space in the garage.
..SEAN |
Posted: Mon Aug 26, 2019 7:47 pm Post subject: Re: LandSpeed Buggy |
Well, I finally pulled my orange buggy out of mothballs and have been driving it every day the weather is good. I've put almost a thousand miles on it in the last month and a bit. Love this little 1904 I built for it, great pep and scoots along at 75mph easily. I've got my high geared Bonneville transaxle in it so at 75 it's loping along at around 2600rpm. Can easily grab the dipstick when I get off the highway after an hours cruz
I stripped the engine in the race car down to the long block and then pulled the heads off. The parts from CB should be shipping this week so I'll spend the next couple of days cleaning up the heads and big beef manifolds and getting them ready to sell. Tonight I mocked up the crank trigger wheel and sensor, took out my trust old 009, pulled the lightened drive pinion and put in the blanking plug.
brad |
Posted: Tue Aug 27, 2019 7:23 pm Post subject: Re: LandSpeed Buggy |
Posted: Tue Sep 03, 2019 10:31 am Post subject: Re: LandSpeed Buggy |
Yesterday I finally got some free time and got the bodywork stripped off the car which is kind of involved as I have to remove the brakes and calipers as well as the caliper brackets off the axle tubes and then undo 36 fasteners per side.
Then I removed the seat and belts, dash and wiring, all the shifter linkage and steering shaft so I can either redo or clean up parts. The salt air at Bonneville rusts any exposed metal almost instantly. Most of the hardware will get tossed and replaced with new, non-rusty stuff. I use stainless hardware in non structural or safety applications but most is zinc coated and rusts almost as fast as bare metal.
Parcel from CB should be here next Tuesday, going to broker it tonight not looking forward to paying the taxes on this package......
brad |
joescoolcustoms Samba Member
Posted: Tue Sep 03, 2019 11:41 am Post subject: Re: LandSpeed Buggy |
Looking forward to see how fast Broke gets you, or how fast you go Broke. (Have not figured that out yet myself)
I did not clean my buggy each day while at the Atlantic Beach last fall like I normally would. The chassis the body was on is going to get scrapped/recycled anyway due to a new chassis build this coming Winter. The corrosion is horrendous. I must have gone through water deep enough that it got into a CV and junked out a 930 Porsche joint. Chrome is ruined, (that too is getting scrapped) and even waxed Aluminum took a beating. Because I use soo much dielectric grease, the Rebel Wiring harness is still in great shape and savable. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Tue Sep 03, 2019 11:54 am Post subject: Re: LandSpeed Buggy |
slalombuggy wrote: |
... pulled the lightened drive pinion and put in the blanking plug...
brad |
I'm following along (as is everyone else) to see it go faster, Brad. Any pics of the lightened distributor drive pinion? I'm always interested in seeing what guys have done with lightening parts. Al _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Wed Sep 04, 2019 3:43 pm Post subject: Re: LandSpeed Buggy |
The jaws on my Dads little Unimat lathe needed some repair when I did this, so I had to use a little cruder method but you get the idea.
brad |
ALB Samba Member
Posted: Wed Sep 04, 2019 8:55 pm Post subject: Re: LandSpeed Buggy |
Thanks for the pic. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
