LandSpeed Buggy
rubenski
rubenski is offline
PostPosted: Mon Nov 06, 2017 1:13 pm    Post subject: Re: LandSpeed Buggy Reply with quote
Good progress, awesome build!
slalombuggy
slalombuggy is offline
PostPosted: Tue Nov 07, 2017 8:20 pm    Post subject: Re: LandSpeed Buggy Reply with quote
Steering shaft is in and works nice and smooth.
brad
1962 Canadian Buggy 121.253mph - Bonneville 2012
1957 LSR Buggy - Rowan's Rocket - goal -150mph
slalombuggy
PostPosted: Tue Nov 14, 2017 9:35 am    Post subject: Re: LandSpeed Buggy Reply with quote
More progress this weekend. I also purchased a portable heater so I'll be able to extend my working time in the garage. I got the last of the braces in for the rear shock mounts and dash bar. Drilled the mounting holes for the transaxle mounts. Finally got the shifter working as smooth as silk. You REALLY have to watch the angles when installing the side shift adapter. I also got the relocated front shock mounts figured out. Not an elegant solution but it works and on this car, function all I worry about. All that is left is some final welding. Adding a couple of helmet retention bars on the upper cage, a skid plate to the very top of the cage to prevent the bars from digging in is something should ever happen and then it's time to skin this cat and figure out some routing for hydraulics and wiring.
Rear shock tower braces. There are also gussets at the base.
Dash bars, relocated battery, and shock mounts
Shock tower brace and clutch slave mount
Snaking the shift rod through the cage and tacked in place.
brad
heywebonya
heywebonya is offline
PostPosted: Tue Nov 14, 2017 11:14 am    Post subject: Re: LandSpeed Buggy Reply with quote
Wow! Great work and thank you for the updates!
If I knew what I was doing; I wouldn't be building a buggy!
vwracerdave
vwracerdave is offline
PostPosted: Tue Nov 14, 2017 8:27 pm    Post subject: Re: LandSpeed Buggy Reply with quote
Have you considered a NASCAR style seat with the head supports that wrap around the sides of the helmet? I know when I drag race my Dunebuggy at 100 MPH I have to hold my head against the padded back rest to keep my head from whipping around. Keeping my helmet solid in the airstream make a difference in the consistency of my ET's. I'm not required to wear a Hans devise for my speeds. Is it required for your class?
What MPH goals do you have for your Buggy?
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
slalombuggy
PostPosted: Wed Nov 15, 2017 6:04 am    Post subject: Re: LandSpeed Buggy Reply with quote
Yes, I have a friend who is a wiz at aluminum fabrication and we will be building a helmet support for the seat. In 2012, my helmet started shaking so bad I couldn't see the markers until I grabbed by chin bar with my right hand, that was on my 121mph run when I reset the record. I am also looking at helmet restraint systems like a HANS device, it isn't required, but I'd rather have it and not need it, than the other way around.
This year I am shooting for 150mph but will be happy with anything close to 140mph. I'd also like to get my 130mph Club hat for reaching 130mph in the mile.
brad
slalombuggy
PostPosted: Sun Nov 19, 2017 9:10 pm    Post subject: Re: LandSpeed Buggy Reply with quote
Worked on the dash today. Used some 3/16" glastic that we use at work for insulation on high voltage projects. Gauges are NOS VDO Jet Cockpit, oil pressure and temp, cylinder head temp and 10,000 rpm CarbonFibre series Autometer tach. The blue and yellow lights above the steering shaft are indicator for 3rd and 4th gear that will be turned on by micro=switches on the shift linkage and the toggle switches are for fuel, ignition and master on/ start. On the forward dash bar braces will be mounted the Autometer shift, Oil and Gen. warning lights.
brad
vwracerdave
PostPosted: Mon Nov 20, 2017 11:53 am    Post subject: Re: LandSpeed Buggy Reply with quote
Just some thoughts.
I think you should spend a little more time and rethink your dash. I believe I would extend the fiberglass hood to be flush with the dash or maybe 1-2" past. I would also aim the shift light to be in your direct eyesight. I would use huge oil pressure and Alt. idiot lights. You will need to fabricate some sort of windshield or windscreen 3-4" high above the dashboard hood level to direct airflow over your helmet. Maybe lower the steering wheel. Your hands and steering wheel should be completely out of the Windstream. May need to lower the shifter too.
60ragtop Premium Member
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Mon Nov 20, 2017 12:01 pm    Post subject: Re: LandSpeed Buggy Reply with quote
slalombuggy wrote:
I also picked a 5 gallon pail full of wheel weights to melt down for ballast in the front end.
brad
Don't look like you need no ballast added Laughing
looking good Brad.
we had to add lead to the frame of the 109 after seeing a video of the front lifting at 150 MPH and the driver didn't realize it Shocked
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
" Even when all the experts agree they may well be mistaken." Bertrand Russell
[email protected] wrote:
aftermarket shit that always needs a tweek eats time
Eaallred wrote:
People are over analyzing.......(insert your problem here)
slalombuggy
PostPosted: Mon Nov 20, 2017 6:11 pm    Post subject: Re: LandSpeed Buggy Reply with quote
Thanks for the ideas Dave.
Yes the body work will extend even further than you suggest. It will come almost to the front bars on the cage and there will be a raised section over my hands and steering wheel that will also deflect some air . I have Autometer warning lamps that are very bright and directional. I'll mount those in line of site and the shift light will be fine where it is, I've had it mounted down low out of the airflow before an I have always noticed it in my periphery.
I set it about 300rpm early and use the tach to shift. I shift pretty lazy compared to you drag race guys so it's not imparitive that I shift as soon as the light is on. The shifter is just a stand in to get the linkage set up. The one I'm building will only bee about 6" tall. I actually can't get first gear with the one in there now as it hits the tach.
Yes Rick , I know it looks like I'll load the car down pretty good, but I'm on a mission to shed some of the pounds. Between badly crushing my left leg and then tearing my MCL in my left knee a year later keeping active has been a real problem I'm trying to make your job getting me belted in as easy as possible LOL. I'm even buying pull up belts this time around.
As far as ballast. I added a bunch of lead in the front tubes of the orange buggy when I rebuilt it and if I can make this one as stable as that one is I'll be really happy. That thing was hooked up.
brad
slalombuggy
PostPosted: Sun Dec 03, 2017 8:21 pm    Post subject: Re: LandSpeed Buggy Reply with quote
Made a new dash with a bit different layout and moved the gear indicator lights for a bit better visibility. Today is was half decent out so I built a fire in the firepit and smelted down about a hundred pounds of lead and filled some of the front tubes in the chassis. Also started fabbing up the body mounts for the fiberglass part of the body.
Drivers eye view of the dash panel
Lead filled tubes
brad
slalombuggy
PostPosted: Fri Dec 15, 2017 10:28 pm    Post subject: Re: LandSpeed Buggy Reply with quote
Cutting out templates to make the fiberglass panels from. I'll be using glastic panels from work and then reinforcing them with wood and 'glass cloth underneath. The rear fenders are going to be reworked a lot also.
brad
GS guy
GS guy is offline
PostPosted: Sat Dec 16, 2017 8:30 pm    Post subject: Re: LandSpeed Buggy Reply with quote
Looks like that body needs some serious streeeeetching! Nice progress!
70's vintage Deserter GS buggy - undergoing transformation to Super GS!
joescoolcustoms
joescoolcustoms is offline
PostPosted: Sat Dec 16, 2017 8:48 pm    Post subject: Re: LandSpeed Buggy Reply with quote
As a buggy builder/fabricator, this thread is absolutely killing me.
At some point before I die, I have to do this too. New item on my bucket list.
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Member of Wagenfolks
http://images.thesamba.com/vw/gallery/pix/870707.jpg
http://www.thesamba.com/vw/forum/viewtopic.php?t=479740
slalombuggy
PostPosted: Tue Dec 19, 2017 9:05 pm    Post subject: Re: LandSpeed Buggy Reply with quote
Rolled the car over to the garage door to get a better shot without all the clutter in the background. I love the look of bare chassis before they get covered up with 'glass and aluminum, always so much potential and possibilities. I wonder if my friends glass 356 Carrera coupe body will fit on this LOL
brad
rubenski
rubenski is offline
PostPosted: Wed Dec 20, 2017 7:33 pm    Post subject: Re: LandSpeed Buggy Reply with quote
Popcorn Popcorn Popcorn
pure car-porn....
Glasser
Glasser is offline
PostPosted: Tue Dec 26, 2017 5:01 pm    Post subject: Re: LandSpeed Buggy Reply with quote
Looking good Brad!!!!
Want to borrow my 2650cc Porsche. She'd pull real nice in that Hotrod you got going. You might have to share that wold record with me though Wink
All the best in your endeavor and be safe!!!
Brent
My build up http://www.thesamba.com/vw/forum/viewtopic.php?t=265364&postdays=0&postorder=asc&start=0
Project#2. Neighbors build up. http://www.thesamba.com/vw/forum/viewtopic.php?t=327008
slalombuggy
PostPosted: Tue Jan 02, 2018 5:03 pm    Post subject: Re: LandSpeed Buggy Reply with quote
Love your engine Brent. One day I'll have a 911 shroud in the back of something. Probably the Bounty Hunter. I'm working on the engine right now as its too cold in the garage but the current mods should get me another 30hp.Big changes to compression, cam, and carburation. The heads are ready for machining and then I can figure out the valve pockets. Ive torn the engine right down to inspect everything and it all looks like new. Going to do a bit more work in the case for oiling and then put it back together.
brad
Glasser
Glasser is offline
PostPosted: Thu Jan 04, 2018 8:22 am    Post subject: Re: LandSpeed Buggy Reply with quote
brad
Sounds awesome!!!!
Brent
slalombuggy
PostPosted: Thu Jan 11, 2018 7:36 am    Post subject: Re: LandSpeed Buggy Reply with quote
Man, this has been an expensive week. I bought my fire suppression system from Fire System Research, my transaxle from Vallis Motorsports, and a couple of engine goodies I've wanted for a while Thorsten Pieper lifters and some Wiseco light weight wrist pins.
brad
Page 3 of 6
