hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Tue Sep 26, 2017 10:05 am Post subject: Everyhing you need to know about pipes |
GOVERNMENT PIPE SPECIFICATIONS
1. All pipe is to be made of a long hole, surrounded by metal or plastic, centered around the hole.
2. All pipe is to be hollow throughout the entire length – do not use holes of different length than the pipe.
3. The I.D. (inside diameter) of all pipe must not exceed the O.D. (outside diameter) – otherwise the hole will be on the outside of said pipe.
4. All pipe is to be supplied with nothing in the hole, so that water, steam or other stuff can be put inside at a later date.
5. All pipe should be supplied without rust – This can be more readily applied at the job site. Some vendors are now able to supply pre-rusted pipe. If available in your area, this product is recommended as it will save a lot of time on the job site.
6. All pipe over 500 feet (153m) in length should have the words “long pipe” clearly painted on each end, so the Contractor will know it is a long pipe.
7. Pipe over 2 miles (3.2 km) in length must have the words “very long pipe” painted in the middle, so the Contractor will not have to walk the entire length of the pipe to determine whether or not it is a long pipe, or a very long pipe.
8. All pipe over 6” (152 mm) in diameter must have the words “large pipe” painted on it, so the Contractor will not mistake it for a small pipe.
9. Flanges must be used on all pipe. Flanges must have holes for bolts quite separate from the big hole in the middle.
10. When ordering 90 degrees, 45 degrees or 30 degrees elbow, be sure to specify right hand or left hand; otherwise you will end up going the wrong way.
11. Be sure to specify to your vendor whether you want level, uphill, or downhill pipe. If you use downhill pipe for going uphill, the water will flow the wrong way.
12. All couplings should have either right hand or left hand thread, but do not mix the threads - otherwise, as the coupling is being screwed on one pipe, it is unscrewed from the other. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2666 Location: Long Island, NY
Posted: Tue Sep 26, 2017 10:40 am Post subject: Re: Everyhing you need to know about pipes |
Makes perfect sense. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
mark tucker Samba Member
Posted: Tue Sep 26, 2017 11:28 am Post subject: Re: Everyhing you need to know about pipes |
and he's in the neither lands...crap his gov is almost as bad as ours. |
Posted: Tue Sep 26, 2017 11:33 am Post subject: Re: Everyhing you need to know about pipes |
mark tucker wrote: |
You know it _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
mukluk Samba Member
Posted: Tue Sep 26, 2017 12:02 pm Post subject: Re: Everyhing you need to know about pipes |
Funny stuff _________________ 1960 Ragtop w/Semaphores "Inga" |
cbeck Samba Member
Posted: Tue Sep 26, 2017 3:09 pm Post subject: Re: Everyhing you need to know about pipes |
Excellent. Now what do we need to know about tubing? |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Tue Sep 26, 2017 3:28 pm Post subject: Re: Everyhing you need to know about pipes |
hobbybob517 wrote: |
This reminds me of a story that a machinist buddy of mine told me, A new engineer gave him a blue print of a part to be made out of titanium, he questioned the measurements that she gave him & she snapped back at him to make the part as specified. Four hours later he brought her a box of shavings & she asked "what's this?" he told her "that's what you get when your ID is larger than your OD." _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Sep 26, 2017 6:35 pm Post subject: Re: Everyhing you need to know about pipes |
TDCTDI wrote: |
This reminds me of a story that a machinist buddy of mine told me, A new engineer gave him a blue print of a part to be made out of titanium, he questioned the measurements that she gave him & she snapped back at him to make the part as specified. Four hours later he brought her a box of shavings & she asked "what's this?" he told her "that's what you get when your ID is larger than your OD." |
shit that was me!!!! just kidding, but Ive had those situiations. and when it's the owner of the prototype speciality machine shop doing the prints...4 times....and still rong....... you fix them and make the ffucken parts and dont let him know just how effing stupid he has gotten...(thats being nice to an arrogant my shit don't stink suit wearing every day..moron) . many times this has happened with guys that program the cnc equipment without knowing what there doing...or reading what there doing ..or....well you cant fix stupid, but it really wasent stupids fault.The print is never rong...must be a glitch. |
