Joined: January 01, 2007 Posts: 16886 Location: sticksville, ct.
Posted: Sat Oct 28, 2017 12:08 pm Post subject: Re: Ride-On goes Subaru power |
very true. I have met more good folks than bad for sure. in terms of the filler elbow it's a dam shame someone hasn't stepped up to make this. perhaps the GEEBEE fellow may be able to do something? this is the most asshole design ever. and worse yet, the filler tube isn't supported by ANYTHING....except the rubber flange that the gas cap plate pinches the whole mess together. I think if you are one of those people who sit and click click click the pump to top up this would accelerate that elbow tearing as now it's supporting the weight of the fill tube AND gas...
anyway...
paint is drying up nicely. not a 100% job for sure, but it REALLY cleans up the bay. off to the shower to clean the holocaust cloud of green out of my nooks and crannies _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Sat Oct 28, 2017 12:28 pm Post subject: Re: Ride-On goes Subaru power |
vwwestyman wrote: |
As I was filling up the '78 the other day, I was thinking about skill's comments about the new rubber part and access flap, and how hard of a time I was given for choosing to slather my old one in RTV and reuse it! I guess it's hard to say which is worse, but mine is still holding up a year and a half later. |
Instead of just slathering it with RTV, I have taken cloth & spread the RTV over it on a piece of wax paper and worked it into the cloth from both sides & then wrapped NLA intake boots with that & made sure to squeeze the layers together. The RTV impregnated cloth becomes a silicon hose of sorts. I've run my Eurovan like that for 3 years now. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20279 Location: Sandpoint, ID
Posted: Sat Oct 28, 2017 7:45 pm Post subject: Re: Ride-On goes Subaru power |
TDCTDI wrote: |
vwwestyman wrote: |
Instead of just slathering it with RTV, I have taken cloth & spread the RTV over it on a piece of wax paper and worked it into the cloth from both sides & then wrapped NLA intake boots with that & made sure to squeeze the layers together. The RTV impregnated cloth becomes a silicon hose of sorts. I've run my Eurovan like that for 3 years now. |
I have been using the black RTV treatment on 40 year old CV boots and tie rod boots for many years. Works way better than the modern replacements as long as you don't give a damn about what the judges think. _________________ nothing |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Sat Oct 28, 2017 9:16 pm Post subject: Re: Ride-On goes Subaru power |
cdennisg wrote: |
TDCTDI wrote: |
vwwestyman wrote: |
I have been using the black RTV treatment on 40 year old CV boots and tie rod boots for many years. Works way better than the modern replacements as long as you don't give a damn about what the judges think. |
It may well have been your comments that inspired me to RTV my fuel filler boot! Because they were inspired by comments about RTV-ing CV and tie rod boots.
On the '78, I have to hold the filler the entire time, because diesel pumps don't fit quite right in it's filler. As it sounds, that is probably a good thing!
On the '73, it is a sturdy metal pipe there. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Sun Oct 29, 2017 5:07 pm Post subject: Re: Ride-On goes Subaru power |
so, on todays adventure....
got the new tank cleaned up
I set it in the bus. it had a OE access hole cut (poorly) and I thought it wasn't right, but it was hard to tell with a crushed tank. so....
as you can see, way off...
un-corked it. yum yum....
and with the goo removed, you can see they went after it with a claw hammer
also note, it's way off and the sender won't fit thru the hole, let alone my hand...
here you can see where it SHOULD have been. same rib as the pin for the rear hatch, 9" back from the opening on the engine access hatch. the circle is dead center of the sender.
so, I made a new cover. I had to make it bigger to cover up the mess some hero left me
here you can see just how far off they were...
and the new cover
after that mess was handled I pulled the tank back out, laid down the sound deadening, installed the tank for good, installed new gates barricade vapor hoses, new MB filler pipe etc etc. getting close to final assembly now
still have another layer of sound deadener to do, but the hard stuff is done _________________
Jake Raby wrote: |
Brian wrote: |
wcfvw69 Samba Purist
Posted: Sun Oct 29, 2017 6:29 pm Post subject: Re: Ride-On goes Subaru power |
Looks good Don-
One thing I didn't do when I installed sound deadener in the fuel tank compartment and engine bay was put a layer on the back side of the fuel tank compartment cover. I wish I would have as I 'think' he could help a bit.
Do you? _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sun Oct 29, 2017 6:38 pm Post subject: Re: Ride-On goes Subaru power |
so, here is my take on sound deadener....
I like it. BUT I won't cover every square inch of a bus with it, and sure as hell won't put it on floors etc.
this is the stuff I have been using
http://www.raamaudio.com/
I like it. I won't do the foam in the tank area for fear of it holding moisture/fuel stink. but I use the fatmat (or whatever they call it) just like you describe...tank area and on the front of the firewall.
that ensolite is neat stuff. it works real well. other than wind noise my bus is VERY quite at 75 on the road....I bet if I packed it with some on the drives side wall/slider etc it would be better, but honestly just doing the engine bay makes a huge difference.
so, doing the firewall would for sure help with noise transmission....that panel is huge and really like a bass drum _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Oct 29, 2017 8:04 pm Post subject: Re: Ride-On goes Subaru power |
skills@eurocarsplus wrote: |
so, doing the firewall would for sure help with noise transmission....that panel is huge and really like a bass drum |
Shit! I figured you'd say that. I guess next time I have the engine out, I pull the firewall off and add some to the backside of it.
I installed it in the fuel tank area with the tank out. I stuck it above the engine. It did make a HUGE difference for sure. _________________ Contact me at [email protected]
Chochobeef Samba Member
Joined: May 01, 2013 Posts: 811 Location: Ft. Worth, Texas
Posted: Tue Nov 07, 2017 9:56 am Post subject: Re: Ride-On goes Subaru power |
Any updates? |
Abscate Samba Member
Posted: Tue Nov 07, 2017 6:32 pm Post subject: Re: Ride-On goes Subaru power |
Don't rush skills. He's an artist, and he don't surf. _________________ .ssS! |
Posted: Tue Nov 07, 2017 9:52 pm Post subject: Re: Ride-On goes Subaru power |
was out of power for about 5 days. unfortunately I never got around to setting up the shop for a generator. the house is dialed in, but the shop, no so much.
finished up the rear brakes tonight and got handed an exploding curve ball
the collar for the e brake cable had broken off the baking plate and looks like it was like that for a long time
first time ever I needed a body hammer and a welder to do a brake job
the Subaru harness has been run/installed. I need to hook it all up, finish some brackets etc but with any luck I *should* be able to set the engine and transmission in for good this weekend.
I still need to tie in the clutch hydraulic line, it's been run and flared on the master side, but need to set the final position of the line to the slave.
engine hanger has been finished, painted and ready to roll. I need to turn up the wick and make up for 5 days of no work. I also have to dig thru my side marker lights, as ride-on had some pretty crappy bases that I don't want to reuse. 99.9999% of the parts are here for final assembly, so it's getting close for sure _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Nov 08, 2017 7:14 am Post subject: Re: Ride-On goes Subaru power |
Dang, sorry to hear about the power loss. To relieve Abscate of his anxiety, I am in no way rushing the master Skills. I just want to marvel at his awesomness that I will never achieve.
It is amazing at all the little things that can go wrong and never find them until you start digging into a system (ie. Brakes). Even an important system like the E brake can be overlooked and not necessarily neglected. Ride-on is a lucky guy as most mechanics nowadays just want to get you in and get you out (for any vehicle).
Can't wait to see the next installment of ShopTalk with Skills the master mechanic. |
Ride_On Samba Member
Joined: August 27, 2015 Posts: 385 Location: Ottawa, Canada
Posted: Wed Nov 08, 2017 8:26 am Post subject: Re: Ride-On goes Subaru power |
We are definitely lucky! Especially if it was at all related to safety, I'm sure that Skills would go at least as far as kicking me in the nuts to stop me from taking the bus home without it being fixed!
We have been really happy with the work done previously by our mechanic up here in Ottawa - no doubt there - but, even with that, how often do you get to do a deep dive like this, especially with someone with Skills' attention to detail? I'm a bit surprised that the gas tank never came up during work up here, and maybe that e-brake guide, but they had Fourbie running well.
Of course there are going to be some leftovers when this is all said and done, but it's so nice to know that stop and go won't be among them! Thanks Skills! _________________ 1977 Westfalia 2.0 FI Skills EJ25 w SubaruGears 5sp
https://www.thesamba.com/vw/forum/viewtopic.php?t=687254
2018 Golf Sportwagen 4MO DSG (Dieselgated 2013 Golf Wagon TDI DSG) |
Posted: Wed Nov 08, 2017 9:04 am Post subject: Re: Ride-On goes Subaru power |
Well - have you donated early and often to his go fund me??
Posted: Wed Nov 08, 2017 9:16 am Post subject: Re: Ride-On goes Subaru power |
Thanks for the kind words
It still doesn't change the fact that I feel bad about all of the little issues....and the time and money spent fixing them. The reality is I want every client to have zero problems...nothing worse than pulling it out of winter storage and have a brake (or whatever) issue....I try to keep that stuff in check _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Nov 08, 2017 9:32 am Post subject: Re: Ride-On goes Subaru power |
Abscate wrote: |
Ride On does with each & every post that Skills makes. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Wed Nov 08, 2017 10:02 am Post subject: Re: Ride-On goes Subaru power |
you going to hang on to the VW OE access panel for the sender that you replaced? |
Posted: Wed Nov 08, 2017 10:15 am Post subject: Re: Ride-On goes Subaru power |
alman72 wrote: |
Message ride_on. I have no use for it. Honestly...its too small in my opinion. There is no way I can get my hand in there. If you have hands like a 3 year old it may work _________________
Jake Raby wrote: |
Brian wrote: |
airschooled Air-Schooled
Posted: Wed Nov 08, 2017 12:30 pm Post subject: Re: Ride-On goes Subaru power |
I cut mine six inches square, and it’s almost uncomfortably small... maybe the dealership mechanics were like carnies?
Skills, is the clutch hydraulic line one solid hose? Or is there a rubber line in there to allow flex of the transaxle mounts?
www.airschooled.com |
pkrboo Samba Member
Joined: October 09, 2009 Posts: 512 Location: Lincolnshire, UK
Posted: Wed Nov 08, 2017 1:26 pm Post subject: Re: Ride-On goes Subaru power |
Hi Skills, Do you have any more pictures of how you attached the master to the clutch pedal please?
I need to redo mine this winter and am looking for ideas _________________ 1979 Sage Green Westfalia P22 |
