Eberspacher B2l repair guide
Microbusdeluxe Premium Member
Microbusdeluxe is offline
PostPosted: Tue Sep 26, 2017 9:50 pm    Post subject: Eberspacher B2l repair guide Reply with quote
I just repaired my Eberspacher B2l and thought I'd share my discoveries with others. Since VW of North America never offered the Eber in the vanagons, information on them is hard to come by.
I found the UK site http://www.syncronauts.org.uk/ an invaluable resource for information. This page has a great write up: http://forum.club8090.co.uk/viewtopic.php?f=40&t=136617&start=75
The first thing you need is a copy of the troubleshooting guide available from here: https://www.butlertechnik.com/downloads/Eberspacher_B2L-D2L_Troubleshooting_manual.pdf
One thing that the write up from the UK site that needs clarification is the location of the three thermo time switches. Page 18 of the troubleshooting manual has a good line drawing of the unit. You want to replace the temperature switch, number 3 in the drawing, with the 100degree switch. The 250 degree switch goes in position 4, the safety thermal cut-off switch and the 50 degree switch is #13, the heating coil switch. Here's the website that has the switches. www.newark.com The part numbers for the switches are as follows: 68C5873, 98K1990, 98K1988.
I replaced all of those as well as the glow plug and figured I was good. Unfortunately after putting it all back under the van it still wasn't working. The fuel pump did not click on. I then discovered that the small glass 1.25 amp fuse in the silver control unit was blown. Which was a surprise because the fan still operated.
Replaced that, but still no fuel pump action. Cleaned the pump, pulsed it by applying 12v rapidly on and off and finally got it to click, but it wouldn't pump any fuel. New pumps are over $200 shipped from the UK, so I was not too happy. Finally found one on Ebay for $70 from China and threw the dice.
Got the new pump today, put it back together and heat on! May your repair be less painful than this. Taking apart/putting back together the unit is not hard at all as long as you have the manual. There are a couple of Youtube videos that show some of this, too.
'69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig!
PJ Snow
PJ Snow is offline
PostPosted: Wed Oct 31, 2018 5:22 pm    Post subject: Re: Eberspacher B2l repair guide Reply with quote
I have the BA6 in my van.
The previous owner said it worked great.
I pulled the motor as soon as I got the van home for a rebuild.
My mechanic had a bad experience with an Eberspacher that he had in one of his cars many years ago. So he disconnected the gas line to the heater, and ran new line from the tank to the engine when he put the new motor in. I want to use the heater and may end up restoring it just for peace of mind, but I can not find a really clear diagram, and cant remember, how the gas line was run. I think it Tee'd off after the fuel pump? Is this correct?
I have a digital copy of the Eberspacher manual, but the pictures are not real clear.
Thanks for your help!
I just don't want to loose the van in a fire.
1980 Riviera EJ25 swapped
1986 Tinny EJ22 swapped
shagginwagon83
shagginwagon83 is offline
PostPosted: Wed Oct 31, 2018 6:39 pm    Post subject: Re: Eberspacher B2l repair guide Reply with quote
You'd want to Tee it off before the fuel pump...cause it has its own fuel pump right?
I might be wrong
https://www.thesamba.com/vw/forum/viewtopic.php?t=613526&highlight=b4
valvecovergasket
valvecovergasket is offline
PostPosted: Thu Nov 01, 2018 11:13 am    Post subject: Re: Eberspacher B2l repair guide Reply with quote
nice find on the teardown thread!
we have a DA6 in our 83 diesel... other than the blower fan running doesnt appear to do much but looks somewhat complete.
whats the value of some of these things for parts? seems like not many folks are overhauling the old heaters like you did, at least based on my quick search on here
PJ Snow
PJ Snow is offline
PostPosted: Thu Nov 01, 2018 3:39 pm    Post subject: Re: Eberspacher B2l repair guide Reply with quote
You are right. Thanks.
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Thu Nov 01, 2018 11:07 pm    Post subject: Re: Eberspacher B2l repair guide Reply with quote
For BA6 info search the bay forum, myself and notchboy detail out quite a few things on them, not to mention many others smarter then I. LOTS of info there.
Stuart Zickefoose
206-841-7324
[email protected]
outcaststudios
outcaststudios is offline
PostPosted: Thu Jan 17, 2019 9:17 pm    Post subject: Re: Eberspacher B2l repair guide Reply with quote
I have a D1L in my Doka that isnt running. when i turn the control knob the relay clicks once and thats it, i jsut ordered a bunch of fuses and cant find the control unit. ( 12v ) any ohter places that sell Eberspacher parts?
here is a link to the D1L parts:
https://www.butlertechnik.com/d1l-t224
'88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791
akciddento
akciddento is offline
PostPosted: Fri Aug 09, 2024 7:38 am    Post subject: Re: Eberspacher B2l repair guide Reply with quote
Reviving this thread in case someone has an insight
I have a B2l in an 86 euro westfalia club joker - was working fine but parked up for several months while doing a rear brake conversion.
Now when switching on the PCB unit clicks waits 3-5 seconds and clicks again. No fan
so I checked fuses (the filament fuse in the PCB box and the 16amp main supply) and both are good -
my guess is
a) PCB control
b) motor died
c) mice ate the wiring or nested in the vent box underneath (not joking...)
I remember reading somewhere that the PCBs suffer from dry solder problems and some one was repairing them?
before I tear it down is there anything else diagnostic anyone can recommend to isolate where the issue is?
(bug tracking with the very useful butler service manuals leaves me here ...)
(BTW at some point a PO has spliced in an extra 3 pin plug that plugs into nothing? any clues ? - as I say - it was working - was parked up - now not working ??)
http://www.akciddento.com
let's drag race the bus !
