Are VIN #s stamped on body of 84 Vanagon?
chrismm
chrismm is offline
PostPosted: Thu Sep 28, 2017 8:42 pm    Post subject: Are VIN #s stamped on body of 84 Vanagon? Reply with quote
I am trying to find the correct VIN for a 84 Vanagon Westy I bought. The title says"86". The 86 title VIN matches the VIN on dash, which has obviously been replaced. The driver's side door says manufactured in 83, but the VIN has been ground off. It's water cooled with round headlights. Question is: Where (besides the dash and door frame) would I be able to find the VIN stamped into this vehicle? Thanks in advance for any insight! I'm trying to sort this out so that I can resell it with a proper title, I hope.
E1
E1 is offline
PostPosted: Thu Sep 28, 2017 9:03 pm    Post subject: Re: Are VIN #s stamped on body of 84 Vanagon? Reply with quote
I believe it's stamped on the chassis behind the right-front wheelwell, facing rearward, and forward of the fuel pump.
‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman
kamzcab86
kamzcab86 is offline
PostPosted: Thu Sep 28, 2017 9:09 pm    Post subject: Re: Are VIN #s stamped on body of 84 Vanagon? Reply with quote
kamzcab86 wrote:
Back side of the front cross-member, right side:
https://www.thesamba.com/vw/forum/viewtopic.php?t=316862
~Kamz Anxious
2016 Golf GTI S
chrismm
chrismm is offline
PostPosted: Fri Sep 29, 2017 8:24 am    Post subject: Re: Are VIN #s stamped on body of 84 Vanagon? Reply with quote
Thank you. Numbers are there...I hope they check out OK!
