telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Wed Nov 22, 2017 11:48 am Post subject: Re: Robbie is building another engine… |
Had trouble sleeping last night due to an annoying head cold. Figured that thinking about this piston problem would have to put me to sleep. So I did. It didn't work.
First, the concept of having 12 equally balanced OG pistons available was a bit overwhelming. But wait, there's only 11. One is off a little. Gotta fix that.
We know, from the way the problem was worded, that the correct answer is 3 weighings. But how? So try this:
For the sake of discussion, number all of the pistons with a black Sharpie 1 through 12. Label the scale pans A and B.
1) Put pistons 1-4 on pan A and pistons 5-8 on pan B. Leave pistons 9-12 on the bench. Note the balance. There are 3 possibilities:
1a) The scales balance.
1b) Pan A is heavy
1c) Pan B is heavy.
(1a) Suppose the pans balance. We know the bad piston is in group 9-12 still on the bench, and that pistons 1-8 are all good. Put them to the side of the bench. Now put piston 9 on pan A, along with 1 of the good pistons. Put pistons 10 and 11 on pan B. Note the balance. Again, there are 3 possibilities:
2a) The scales balance
2b) pan A is heavy
2c) Pan B is heavy
(2a) If the pans balance, then we know that piston 12, still on the bench, must be the bad piston. Comparing it to any of the good pistons will determine if it is heavy or light.
(2b) If pan A is heavy, then either piston 9 is heavy, or either piston 10 or 11 is light. Put piston 10 on pan A and 11 on pan B, and note the balance. 3 possibilities:
3a) The scales balance. Piston 9 must be heavy.
3b) Pan A is heavy. Piston 11 must be light.
3c) Pan B is heavy. Piston 10 must be light.
Done.
(2c) Pan B is heavy. Same as (2b), (3a-c) above, but the bad piston has the opposite weight offset.
Done.
Otherwise, back to the first 8 pistons.
(1b) Pan A is heavy.
(1c) Pan B is heavy.
We know that pistons 9-12 are all good.
Put pistons 6, 7 and 8 on the bench.
Leave pistons 1 on pan A. Move pistons 2 , 3 and 4 from pan A to B. Add 3 good pistons to pan A. So, the setup looks like this:
Pan A = piston 1 and 3 good pistons
Pan B = pistons 5, 2, 3 and 4. Note the balance. 3 Possibilities:
2d) The scales balance. If coming from path (1b), this means that one of pistons 6, 7 or 8 is light. Compare pistons 7 and 8. If they balance, it's piston 6 that is light. Otherwise, it's the lighter of 7 or 8 that's bad. If coming from path (1c), the bad piston will be heavy instead of light.
2e) Pan A is heavy, and pan A in weighing 1 was also heavy, or pan B is heavy, and Pan B in weighing 1 was also heavy: Because pistons 2, 3, and 4 swapped sides, but the balance didn't change, then either piston 1 is bad or piston 5 is bad. Compare piston 1 to a good piston. If they balance, then piston 5 is bad, otherwise piston 1 is bad. If from path (1b) if it's piston 1 then it's heavy, or piston 5 is light. If from path (1c), then it's the opposite.
2f) Pan B is heavy, and was light in weighing 1, or pan B is light, and was heavy in weighing 1:. if coming from path (1b), one of pistons 2, 3, or 4 is heavy. If from path (1c) then 2, 3 or 4 is light. Compare pistons 2 and 3. If they balance, it's piston 4 that's bad. Otherwise, it's pistons 2 or 3. If coming from path (1b), the bad piston is heavy. If from path (1c), it's light.
Done.
Because I came up with a solution (I think...), I obviously didn't sleep. Now I feel like crap. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
Last edited by telford dorr on Wed Nov 22, 2017 12:53 pm; edited 7 times in total |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Wed Nov 22, 2017 12:07 pm Post subject: Re: Robbie is building another engine… |
Why are you here, Telford?
_________________ .ssS! |
Posted: Wed Nov 22, 2017 12:16 pm Post subject: Re: Robbie is building another engine… |
I don't know. Ask me again after I've had some sleep... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Brian Samba Moderator
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Thu Nov 23, 2017 8:31 pm Post subject: Re: Robbie is building another engine… |
Just read through the entire thread. My brain hurts. _________________ nothing |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22460 Location: Escondido CA
Posted: Thu Nov 23, 2017 8:36 pm Post subject: Re: Robbie is building another engine… |
cdennisg wrote: |
Just read through the entire thread. My brain hurts. |
Posts.
Robbie 23
Everyone else 141
I thought before I looked it was more like 5 to 200 _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
wcfvw69 Samba Purist
Posted: Thu Nov 23, 2017 9:21 pm Post subject: Re: Robbie is building another engine… |
notchboy wrote: |
cdennisg wrote: |
Posts.
Robbie 23
Everyone else 141
I thought before I looked it was more like 5 to 200 |
Well duh?!?!
He screwed up and posted this in the "bay forums"! It's not like the bay group isn't a bunch of knuckleheads that love to post smart ass comments, photo's, videos and other drivel.
I'm actually quite proud of my contributions to this thread, thank you very much! _________________ Contact me at [email protected]
The Samba member since 2004.
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Thu Nov 30, 2017 1:02 am Post subject: Re: Robbie is building another engine… |
notchboy wrote: |
cdennisg wrote: |
Posts.
Robbie 24
Everyone else 141
Fixed it for you.
Now GoFundMe a camshaft?
www.airschooled.com |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6612 Location: Houston, Texas
Posted: Thu Nov 30, 2017 2:05 pm Post subject: Re: Robbie is building another engine… |
I'm still waiting on the engine to be built. _________________ www.vwnos.com [email protected]
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Thu Nov 30, 2017 4:19 pm Post subject: Re: Robbie is building another engine… |
kawfee wrote: |
I'm still waiting on the engine to be built. |
You must be new to the bay forum..... Nothing EVER happens in my threads until at least page 12. Why, when I drove a lap around the country there were at least 15 pages of bullshit before I turned the key. And I love this place.
richparker wrote: |
asiab3 wrote: |
Robbie |
I already did that once... |
Yeah you’re off the hook!
I’ve decided I’ll be going with Web camshafts and having them regrind one of my stock cams, that way I have five different gear pitches to chose from, and I can STILL maintain the stock profile.
Posted: Thu Nov 30, 2017 4:37 pm Post subject: Re: Robbie is building another engine… |
Get the Web 110/163 and you can use my Spanish IDFs. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Thu Nov 30, 2017 8:42 pm Post subject: Re: Robbie is building another engine… |
asiab3 wrote: |
Robbie |
Oh dear God... I am ratting you out to Colin and more importantly, to this guy.
It will probably make him spin in his grave. Pretty selfish of you Robbie... _________________ Contact me at [email protected]
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Thu Nov 30, 2017 9:17 pm Post subject: Re: Robbie is building another engine… |
I just tried to solve the scale thing,
And only one piston would fit into each of the little pans.
So you're all wrong... _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Thu Nov 30, 2017 9:51 pm Post subject: Re: Robbie is building another engine… |
asiab3 wrote: |
Robbie |
What lifters? _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Thu Nov 30, 2017 10:04 pm Post subject: Re: Robbie is building another engine… |
What does Spiro Agnew have to do with this?
And why are there old VW beetles behind him? _________________ nothing |
Xevin Samba Member
Posted: Thu Nov 30, 2017 10:18 pm Post subject: Re: Robbie is building another engine… |
cdennisg wrote: |
And why are there old VW beetles behind him? |
_________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Fri Dec 01, 2017 7:38 am Post subject: Re: Robbie is building another engine… |
Clatter wrote: |
So you're all wrong... |
some slight modifications are required. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Fri Dec 01, 2017 8:38 am Post subject: Re: Robbie is building another engine… |
cdennisg wrote: |
Posted: Fri Dec 01, 2017 9:59 am Post subject: Re: Robbie is building another engine… |
richparker wrote: |
asiab3 wrote: |
Robbie |
What lifters? |
I have a set of used original VW lifters that will be reground and hardened by Web at the same time as my cam.
Y'all making fun of me, but Web is currently the ONLY manufacturer of STOCK Type 1 cams and lifters. After speaking to Engle, they will not cut a stock grind for me. They will only sell me the W-90, which is ok in the lift department but has ten more degrees duration. It is impossible to explain to salespeople over the phone why I will not allow that in my car.
