SGKent Samba Member
Posted: Wed Oct 11, 2017 10:21 am Post subject: Re: Robbie is building another engine… |
my understanding is that some of the T3 motors were performance motors - 1500 with higher compression and performance. One probably wants to look at the combustion chambers in the heads to see if they were made for a domed piston. Frankly we are pushing a rock uphill on this one I think. Robbie's bus is almost 50 years old so if one wants a perfectly matching stock parts number engine they will have to scour every corner of the globe and spend lots of $$ to find all those perfectly matching parts. Then the next question is why did almost everyone post 1971 want to convert their single port internal oil cooler engine to a dog house dual port engine... _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
airschooled Air-Schooled
Posted: Wed Oct 11, 2017 10:55 am Post subject: Re: Robbie is building another engine… |
Brian wrote: |
I think we're just wasting time until something happens with this build |
Correct.
SGKent, I originally went single port because the quality of available rubber dual port boots could not keep up with my travel schedules. Then my "butt dyno" tests feel that the single ports have a lower power band than a dual port, which means spending less time at high RPMs between shifts in the mountains. The only reason I would go dual port is if I go T1 fuel injection, which won't happen until they run out of carburetors......
I've been running the doghouse cooler setup on a single port engine since I built it, and it's a perfect combo for what I need- Economical, easy, and smooooooooth.
www.airschooled.com |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Wed Oct 11, 2017 12:52 pm Post subject: Re: Robbie is building another engine… |
1964 & 1965 has the 1500 S motor or the dohmed 83mm pistons. The 371 B cylinder head is correct for that time. It also uses the shorter top row case studs. So if unless you have a bus case where someone pulled the top row of studs and put the shorter ones on like a 1500 then Id think you would be fine.
When I did the clean up on my 1500 S for the 64 notch I went back to this lesser head as it worked fine before I pulled it apart and I didn't want to deal with the stud issue to use my other later heads. Lazy quick option won out.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Brian Samba Moderator
Posted: Wed Oct 11, 2017 1:10 pm Post subject: Re: Robbie is building another engine… |
Holy hell, that piston is pregnant _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Bleyseng Samba Member
Posted: Thu Oct 12, 2017 10:33 am Post subject: Re: Robbie is building another engine… |
Hey, that looks just like my old 64 1500S engine _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
richparker Samba Member
Joined: November 24, 2011 Posts: 6984 Location: Durango, CO
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Thu Oct 12, 2017 3:34 pm Post subject: Re: Robbie is building another engine… |
richparker wrote: |
Just left JAD Machine. One look at these pics and he instantly said that they are T3 heads.
Well yeah the part number beginning with 311 kinda gives it away _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Thu Oct 12, 2017 4:31 pm Post subject: Re: Robbie is building another engine… |
sjbartnik wrote: |
richparker wrote: |
Well yeah the part number beginning with 311 kinda gives it away |
I know right. I can't believe you guys don't know this 101 VW stuff
I may have to call for a council of the highest order. Pull everyone in for a beer to speak of this.
And in defence of some of the younger crowd. I have been a Type 3 A-Hole since I was 14. Im 46 now. Bus affascinato - always but an owner since 2010 is all.
t3kg wrote: |
1964 1500 S
wcfvw69 Samba Purist
Posted: Thu Oct 12, 2017 4:44 pm Post subject: Re: Robbie is building another engine… |
Lots of this going on ^^ about those being "Type 3 heads"..
So...
_________________ Contact me at [email protected]
The Samba member since 2004.
Xevin Samba Member
Posted: Thu Oct 12, 2017 5:06 pm Post subject: Re: Robbie is building another engine… |
_________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Fri Oct 13, 2017 10:50 am Post subject: Re: Robbie is building another engine… |
I don't think they're VW heads at this point _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Fri Oct 13, 2017 11:20 am Post subject: Re: Robbie is building another engine… |
It says " first on the 67 type 3 and on the 71 type 2 and that's what I remember as the 67 1600 type 3 came with the dual port heads and I was using those plus switching to the dual port manifolds on the rebuilds I did back then. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
Xevin Samba Member
Posted: Fri Oct 13, 2017 11:37 am Post subject: Re: Robbie is building another engine… |
I'm going to go with whatever Bleyseng says. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Fri Oct 13, 2017 12:34 pm Post subject: Re: Robbie is building another engine… |
Part numbers from the bay bus parts book, reminding us that not all bus parts start with a number two:
Crankcase: 113 101 025
Flywheel: 311 105 271
Cylinder head: 311 101 353A
Door lock release lever: 411 837 072
I have bigger fish to fry than this shit. If you need me, I'll be waxing the pedals, detailing the dashboard screws, and making sure my firewall screws are painted white. You know, stuff that matters more than the bug that these heads came off of…
raygreenwood Samba Member
Posted: Fri Oct 13, 2017 12:44 pm Post subject: Re: Robbie is building another engine… |
asiab3 wrote: |
Robbie |
Sweet!.....a 411 door lock release lever.....welcome to the world of ugly and sophisticated!
Ray |
Abscate Samba Member
Posted: Fri Oct 13, 2017 1:17 pm Post subject: Re: Robbie is building another engine… |
Type 3, you mean.
...and dont dangle prepositions, and don't call me Shirley _________________ .ssS! |
Xevin Samba Member
Posted: Fri Oct 13, 2017 1:35 pm Post subject: Re: Robbie is building another engine… |
Clatter wrote: |
SGKent wrote: |
Posted: Fri Oct 13, 2017 4:00 pm Post subject: Re: Robbie is building another engine… |
I would think a part that was designed and first to be used on would get the "Type" tag. For no other reason than that because its used on it first AND has the PN on it.
The Type 3 heads on a Bay window bus is truly an acceptable and apt part to use. Type 3 dont get no respect either.
I do agree with the fact that the Type 3 heads are for both - T3 and Bus. But its still a T3 head used on a bus Or to feel better just say its an inter changeable part used on some other ACVW's as well
Im going to polish off a beer. Y'all can go polish some knobs as needed. :2gunfire: _________________
t3kg wrote: |
1964 1500 S
Posted: Fri Oct 13, 2017 4:24 pm Post subject: Re: Robbie is building another engine… |
wcfvw69 wrote: |
So...
Last bit o info. Proof.
t3kg wrote: |
1964 1500 S
