nic_ Samba Member
Joined: February 06, 2015 Posts: 64 Location: Melbourne, Australia
Posted: Fri Sep 29, 2017 3:56 pm Post subject: Correct TE6A3 coil resistance |
I've done a bunch of searching and surprisingly can't find an answer on this.
I have the original coil from my '56 - the TE6A3 (4M datestamp for those playing at home).
It's measuring 2ohm across the primary, and 4.7Kohm across the secondary.
I figure it should be fine given neither circuit is completely open or completely closed, but I'm interested if that's close to spec for this particular coil?
Also a question on "correctness" - should the coil holder be black, or bare metal? I see both frequently, and my original looks like it was painted, but it may have just been buildup of gunk. |
janerick3 Samba Member
Posted: Fri Sep 29, 2017 9:47 pm Post subject: Re: Correct TE6A3 coil resistance |
The bracket should be bare metal.
Back in the day, it was common for VW dealers to drop the engines on trade-ins and repaint the tin, which explains the occasional black bracket.
Factory rebuilds often have fan shrouds that are repainted with the coil left in place. _________________ Thanks,
Jan K. |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Sat Sep 30, 2017 10:26 am Post subject: Re: Correct TE6A3 coil resistance |
If your coil specs are similar to the other 6 volt coils I've checked the primary winding resistance should be about 1.5 ohms. Secondary windings seem to be more variable but somewhere in the 4-12K range is what I have seen others report. |
nic_ Samba Member
Posted: Sat Sep 30, 2017 6:17 pm Post subject: Re: Correct TE6A3 coil resistance |
Thanks for that. Sounds like it should be OK, so I'll see how it runs. |
