Jan '51 build
Page: Previous  1, 2, 3  Next
D-train
D-train is offline
PostPosted: Thu Nov 23, 2017 4:37 pm    Post subject: Re: Jan '51 build Reply with quote
Vacuum assissted diaphragm on the pump also?
shiny paint doesnt make it worth any more
56samba
56samba is offline
PostPosted: Fri Nov 24, 2017 8:34 am    Post subject: Re: Jan '51 build Reply with quote
Can't wait to see more progress on this car AND on the engine!
Seems like you have a very talented friend there. When I saw the pics of the car as it was rescued, I didn't expect it will turn out so nicely.
And the enigne is just......wow!!!
I also purchased an Okrasa engine from Scandinavia but your engine is something really unique. Do you plan to use these "exhaust" tubes in your car? Very Happy Very Happy Very Happy
Martin Southwell
Martin Southwell is offline
PostPosted: Fri Nov 24, 2017 11:42 am    Post subject: Re: Jan '51 build Reply with quote
I remember my father, who is still alive and well in his 90's, and who was in aircraft design during WW2, and aircraft engine design afterwards with Rolls Royce, describing this kind of cylinder surface to me as a youngster, as being 'Honeychrome'. I've not seen or heard the term used anywhere else since.
Obviously a play on words, being the honeycomb finish of a chrome plated surface, which allows for the greater retention of oil within the cylinder walls. https://www.finishing.com/2200-2399/2309.shtml
klubbs
klubbs is offline
PostPosted: Thu Dec 28, 2017 2:41 am    Post subject: Re: Jan '51 build Reply with quote
D-train wrote:
Vacuum assured diaphragm on the pump also?
Yes.., Good eyes😀
klubbs
klubbs is offline
PostPosted: Thu Dec 28, 2017 2:58 am    Post subject: Re: Jan '51 build Reply with quote
Thanks all for the Nice comments
Had the areas that need welding blasted this weekend.
Was not sure to do wheel wells also to keep the Og paint but glad I did Because some more holes came up and I want it 100% solid from the first time
Floor pans are shot
sotos
sotos is offline
PostPosted: Thu Dec 28, 2017 8:27 am    Post subject: Re: Jan '51 build Reply with quote
Great work Sam, the metal reshaping is amazing and the choice of the engine unique.
I found this : STAMO 1400A, 1400B; 42hp@3100rpm, 45@3200 ,here :http://www.enginehistory.org/HOAE/Stark.html
Looking forward for the next update!
http://www.komenda-porsche-designer.at/
Oval53 (June)
Beetle 1.3 1966
New beetle 1.6 2003
greek_tony
greek_tony is offline
PostPosted: Thu Dec 28, 2017 4:28 pm    Post subject: Re: Jan '51 build Reply with quote
Wow! Amazing work and what an engine! Ultimate aero speed Cool
1963 Karmann Ghia - Sold
May 53 Ragtop - Resto started
October 65 Fastback - Almost there.
slow panel
slow panel is offline
PostPosted: Fri Dec 29, 2017 4:44 pm    Post subject: Re: Jan '51 build Reply with quote
I like the engine !!!
It whas shipped in a metal case from Congo'('Africa) to Belgium
And now he will end up in a car that came from Sweden to Belgium.
What a small world whe live in !!!
Who.Me? Premium Member
Who.Me? is offline
PostPosted: Sat Dec 30, 2017 3:51 am    Post subject: Re: Jan '51 build Reply with quote
Hi
I work with a lady who services vintage aircraft engines part-time.
We were talking a few weeks ago about a problem I'd had with the valves on my truck and she started to tell me about VW aero engines that she used to service.
She explained that they used twin magnetos rather than the distributor/coil/generator system used in road engines (apparently it's quite tricky to set the ignition timing with the twin magnetos).
How do you plan to adapt the engine back to road use? Will you fabricate a pedestal to hold a generator and cooling fan and adapt the case to hold the pedestal? Or has it already been adapted?
Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786
klubbs
klubbs is offline
PostPosted: Sun Dec 31, 2017 12:41 am    Post subject: Re: Jan '51 build Reply with quote
Who.Me? wrote:
Hi
This engine used also twin magnetos, directly driven by the crank at ‘flywheel’ side.
There Will be a generator stand welded on this case from a spare 36hp I have.
WrennMetallWerks
WrennMetallWerks is offline
PostPosted: Sun Dec 31, 2017 8:04 am    Post subject: Re: Jan '51 build Reply with quote
Awesome thread. Keep going. 👍
⚒ Believe In The Power Of Positive Thinking ⚒
Purpose Over Pleasure 🕊
“Hard Werk ⚒ God First “
https://music.youtube.com/watch?v=0-PSeV52tZ4&si=wpcuRnQyvIFo2nCJ
https://music.youtube.com/watch?v=PaCorLXzC5w&si=cbzT8fjlzVlIWfSV
https://music.youtube.com/watch?v=_aoE5aYSutY&si=mkZKPxd_41QA1kfs
https://music.youtube.com/watch?v=_NzUyyVexAE&feature=share
https://music.youtube.com/watch?v=UI8yUrIWS7E&feature=share
mandraks
mandraks is offline
PostPosted: Sun Dec 31, 2017 10:06 am    Post subject: Re: Jan '51 build Reply with quote
i think welding it in would be the easiest way. Then again i like trick "skunkworks" kind of solutions. I think it should get a trick, bolt on flange instead. Looks like you have the fab skills to do that. That way the case stays like it is, stays a special aero engine. This could be a super clean engine. hidden plugwires, coil, etc, go nuts and block off the fuel pump and dizzy, go electric and electronic ignition all put behind the fanshroud.
regards
Uli
fusca66
fusca66 is offline
PostPosted: Sat Jan 06, 2018 5:51 am    Post subject: Re: Jan '51 build Reply with quote
Congratulations, another 51 saved, it will work but it will be beautiful :D
Bug 1966 2280cc
Bug 1951 1900cc
Bug 1952 typ4 1800cc
Sp2 1972 1700cc
Na duvida não ultrapasse
klubbs
klubbs is offline
PostPosted: Sat Jan 20, 2018 12:35 am    Post subject: Re: Jan '51 build Reply with quote
Something worth considering!
Thanks for thinking with me😉
klubbs
klubbs is offline
PostPosted: Sat Jan 20, 2018 1:51 am    Post subject: Re: Jan '51 build Reply with quote
More metalwork
Rear Apron was pretty messed up , had a big tear, dents and the overal shape wasn't right.
Straightened
Right front fender was also twisted, dented and rusty
Looks better now
Very nice work from Simon again!
klubbs
klubbs is offline
PostPosted: Sun Aug 12, 2018 12:54 am    Post subject: Re: Jan '51 build Reply with quote
Brought the split over to Jeff at JC welding services in the UK.
He is doing a fantastic job on it, really nice to see it coming together.
klubbs
klubbs is offline
PostPosted: Sun Aug 12, 2018 12:58 am    Post subject: Re: Jan '51 build Reply with quote
Busstom
Busstom is offline
PostPosted: Sun Aug 12, 2018 1:27 am    Post subject: Re: Jan '51 build Reply with quote
What a save...resurrection, I'd say. Can't wait to see the crumpled roof come back. Everything looking awesome.
Subscribed Popcorn
D-train
D-train is offline
PostPosted: Sun Aug 12, 2018 2:29 am    Post subject: Re: Jan '51 build Reply with quote
Lookin epic
WrennMetallWerks
PostPosted: Fri Aug 17, 2018 7:32 am    Post subject: Re: Jan '51 build Reply with quote
Very Kool. Keep it up>>>
Page 2 of 3
