no spark please help
Jokerrw
Jokerrw is offline
PostPosted: Sun Oct 01, 2017 12:48 pm    Post subject: no spark please help Reply with quote
Looking for advice on an issue with my VW 1835 motor no spark. Any VW guru here? Last it ran was 2yrs ago coil fell out of it's holder and grounded out, pop fuse. After replacing the fuse and coil. Would not start, Very weak and intermediate spark. It had electronic ignition not a prertonix. changed to original points and condenser and no spark at all. I triple check gap .40 mm. Bought new pertronix electric ignition and flame thrower coil. No spark. I am getting 12v at coil, new wires,cap,rotor, hooked up test light to pos side and beg when cranked engine test light was flashing as I turned the engine over.
any advice
can I hook a plug wire straight to the coil and put a plug that is grounded to see if there is spark coming out of the coil?
vwjetboat
vwjetboat is offline
PostPosted: Sun Oct 01, 2017 12:54 pm    Post subject: Re: no spark please help Reply with quote
what have you tried ? got power going to coil ? check point gap ? filed reset ? new points & condenser ?
Jokerrw
Jokerrw is offline
PostPosted: Sun Oct 01, 2017 1:01 pm    Post subject: Re: no spark please help Reply with quote
I have replaced with new electronic ignition, coil, cap, rotor, wires, plugs verified getting 12v to pos side of coil. zero spark
SamT
SamT is offline
PostPosted: Sun Oct 01, 2017 2:21 pm    Post subject: Re: no spark please help Reply with quote
Get us a pic of the wires as they attach to the coil. If the positive side is flashing the test light the wires are wrong. The negative side should flash when you crank, positive stays hot if the ignition is on.
Positive side of coil should be attached to ignition 12v wire, it's common to see it power other accessories like choke on the carb and stuff. Also the redwire from the petronix should go there.
Negative side of the coil powers the tach, black wire on petronix or trigger wire for the points.
If a petronix is hooked up in reverse it usually frys it.
Check your rotor, they have an internal resistor that can fry.
Rides:
300HP 900lb turbo VW rail 18/15 travel
Never ending jeep/rzr hybrid build!
http://www.thesamba.com/vw/forum/viewtopic.php?t=546712
Jokerrw
Jokerrw is offline
PostPosted: Sun Oct 01, 2017 2:51 pm    Post subject: Re: no spark please help Reply with quote
I am getting 12v to white wire
Yes when I put the test light ign turned on I get a light. When I crank the ing the test light flashes
Dark Earth
Dark Earth is offline
PostPosted: Sun Oct 01, 2017 4:55 pm    Post subject: Re: no spark please help Reply with quote
Are the intake and exhaust valves closed on the #1 cylinder when the distributor rotor is pointed at the #1 plug wire ?
My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ Anxious
Jokerrw
Jokerrw is offline
PostPosted: Sun Oct 01, 2017 6:08 pm    Post subject: Re: no spark please help Reply with quote
here is the rotor at TEC
Jokerrw
Jokerrw is offline
PostPosted: Sun Oct 01, 2017 6:15 pm    Post subject: Re: no spark please help Reply with quote
Also checked new coil wire and 0.5 resistance on meter
Dale M.
Dale M. is online now
PostPosted: Sun Oct 01, 2017 6:52 pm    Post subject: Re: no spark please help Reply with quote
any advice
THis can indicate electronic module is ok...... But does not actually test primary side of coil...
Light should stay on full time when connected on positive side of coil and ground. Connectrd on negative side of coil & ground also tests primary side of coil... Lamp should flash hooked to negative (points) side of coil and ground when engine is cranking...
Two things... Set timing by putting engine at 7.5° BTDC (#1 cylinder) and set timing (turn distributor) so test light just comes on (one side of lamp on negative terminal of coil-other side to test lamp to ground)...
Is engine getting fuel????
Are you sure its a no spark and not a no fuel start?
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Jokerrw
Jokerrw is offline
PostPosted: Sun Oct 01, 2017 7:26 pm    Post subject: Re: no spark please help Reply with quote
I will check timing with a light. Not 100% on fuel but i have been trying it with spray of starter fluid and tried pouring a little gas down both barrels.
I have also hooked a plug wire straight to coil and a grounded spark plug and no spark.
Dale M.
PostPosted: Sun Oct 01, 2017 7:44 pm    Post subject: Re: no spark please help Reply with quote
Might want to test new coil!....
Dale
Jokerrw
Jokerrw is offline
PostPosted: Sun Oct 01, 2017 7:45 pm    Post subject: Re: no spark please help Reply with quote
I set the timing with the test light. Still no spark
This thing is driving me crazy. Everything shows good but still no spark. Even testing for spark in the dark hoping to see a faint spark nothing but darkness.
Jokerrw
Jokerrw is offline
PostPosted: Sun Oct 01, 2017 7:52 pm    Post subject: Re: no spark please help Reply with quote
Pos to neg 3.3 ohms
Pos to output secondary 10.64
Dale M.
PostPosted: Sun Oct 01, 2017 8:24 pm    Post subject: Re: no spark please help Reply with quote
Jokerrw wrote:
Pos to neg 3.3 ohms
I hope that is 10.64K????
Dale
Jokerrw
Jokerrw is offline
PostPosted: Sun Oct 01, 2017 8:36 pm    Post subject: Re: no spark please help Reply with quote
Yes 10.64k .
If I hooked up a spark plug to a plug wire straight to coil and a grounded spark plug, when I crank the motor I should get a spark?
Dale M.
PostPosted: Mon Oct 02, 2017 7:52 am    Post subject: Re: no spark please help Reply with quote
Jokerrw wrote:
Yes 10.64k .
Yes....
What is voltage at positive terminal of coil while starter is cranking motor?...
Where is battery grounded too... Chassis of buggy (do you have ground strap from chassis to transaxle) or directly to transaxle...
Dale
Jokerrw
Jokerrw is offline
PostPosted: Mon Oct 02, 2017 10:55 am    Post subject: Re: no spark please help Reply with quote
At first when tested I was getting down to 11.6v. So I hook up a commercial battery charger and am now getting 13.4 v at positive side when I crank the engine over.
Battery is grounded with a 1/2 bolt and yes the transaxle has grounding strap.
Thank you for taking the time to help me.
Ron
Dale M.
PostPosted: Tue Oct 03, 2017 6:44 am    Post subject: Re: no spark please help Reply with quote
I suggest you go back to points and condenser (old distributor) and see if that solves issue...
Dale
Jokerrw
Jokerrw is offline
PostPosted: Tue Oct 03, 2017 10:01 pm    Post subject: Re: no spark please help Reply with quote
Went back to points and condenser with condenser green wire connected to neg .Still no spark.. This is bugging me.
With points the wires connected to the coil is 1 green to neg and a 12v wire to the pos.
With elec ignition wires connected to the coil is neg is black from dist red from dist to pos. And 12v to pos.
Those should be the only wires connected to the coil
One green to neg if points
And 2 to pos and one to neg for electric ignition?
pullstart
pullstart is offline
PostPosted: Wed Oct 04, 2017 12:21 am    Post subject: Re: no spark please help Reply with quote
This might be a wild idea, but have you bypassed the ignition switch and/or confirmed that while you're cranking that the coil still has voltage?
I've heard of in the past that if you have a poor connection (bad switch) that you can find "ghost" voltage... it's present but has no real amps to get the job done. Maybe jumper from the battery to the coil + and jump the starter solenoid to see what happens...
4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
my build page: https://www.thesamba.com/vw/forum/viewtopic.php?t=662104&start=0
