jrschuler Samba Member
Posted: Wed Oct 04, 2017 10:33 am Post subject: 1978 West Clutch Cable? |
I have a 1978 Westy, and was driving it on a longer trip...stopped at a stoplight and couldn't get it into any gear. I could get it into first if I turned the engine off and bumped the starter while I slid it into gear. After that I just hit my shifts at the right rpm...and got it home.
The next day I tightened up the clutch cable a little bit, drove it, and the shifting still felt a little "notchy" to me. Tightened up the cable a little more and it feels fine now, but it looks like I'm running out of room to adjust the clutch cable any more...its about to the end of the threads (towards the front of the bus). I recently had the engine rebuilt and when I was putting everything together the clutch looked like it was in good shape.
New clutch? Clutch cable old and stretched out? Any bearings and/or bushings? This is my first VW, so I have a lot to learn. Thanks for the help! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51123 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Oct 04, 2017 12:16 pm Post subject: Re: 1978 West Clutch Cable? |
Welcome!
Try another cable first, sounds like yours is stretching as it slowly breaks. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Wed Oct 04, 2017 1:53 pm Post subject: Re: 1978 West Clutch Cable? |
jrschuler wrote: |
Clutch Failures
On flat ground, Engine off in neutral it should shift into 1-4 without to much problem.
If you had to tighten the clutch cable, as busdaddy posted inspect the cable. As the clutch disc wears out, unlike on other cars we loosen the clutch cable adjuster we do not tighten it.
Clutch Free Play
Inspect the rear shift coupler and the front shift bushing while you are at it.
Shifter Parts ID T2
Good luck
Tcash |
Posted: Wed Oct 04, 2017 1:59 pm Post subject: Re: 1978 West Clutch Cable? |
Remove and clean the ground strap on the front of your transmission. Replace it if it seems very ratty. When the ground strap goes bad the starter current will pass along the clutch cable causing it to rapid stretch and soon fail. |
Posted: Wed Oct 04, 2017 2:56 pm Post subject: Re: 1978 West Clutch Cable? |
Awesome guys, thanks for all of the replies. I'll let you know how it goes. Hopefully I'll have some time this weekend to get at it. |
Posted: Mon Oct 16, 2017 6:54 pm Post subject: Re: 1978 West Clutch Cable? |
Hey, thanks again everyone. I replaced the cable, shift coupler, and the bushing up front. The cable was about to break, the shift coupler was pretty “wallered out,” and the bushing up front was mia. Shifting it now is a completely different experience...hahaha. |
Posted: Mon Oct 16, 2017 8:20 pm Post subject: Re: 1978 West Clutch Cable? |
Good work, hope you got hold of a quality bushing so that it shifts well for a long time to come. |
Posted: Sat Oct 21, 2017 1:33 pm Post subject: Re: 1978 West Clutch Cable? |
Wildthings wrote: |
Thanks! I got it from Wolfsburg West...do you think they have good stuff? Im super new to all of this. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sat Oct 21, 2017 1:44 pm Post subject: Re: 1978 West Clutch Cable? |
Glad to see it was a straight forward maintenance issue-- one thing I noticed was if offered a choice between Brazilian and German parts --ALWAYS take the German part. Because the fact there is a choice-- means the Brazzi part is a piece of shit- especially with door n window seals. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
