lauzboy Samba Member
Joined: April 22, 2015 Posts: 7 Location: Brisbane Australia
Posted: Thu Nov 02, 2017 5:56 pm Post subject: Re: Vintage Speed muffler |
Motor60 wrote: |
Yes I was writin down all my readings with different combos. I couldn’t get it to run right so I gave up and bought a merged header. Installed the header WITHOUT changing any jetting. Fired it up and was very lean. My idle progression was in the 18-19s which was why I couldn’t drive on just progression. I re-tuned with header ended up 55 idles with 16-17 on progression. THEN re-installed the VS exhaust. Bug ran great BUT exhaust fumes were heavy inside the cab. Don’t know why. I have a convertible and my lid is propped open from bottom so I can get cool air with the top down.
After a DKP xmas run, the fam got naseous. So I took it back off and put header back on. NOW, I’ve been searching the earth for a high performance quiet pack. Or at least one WITHOUT drone. I’ve tried dynomax. So far, the ALs headers dual quiet packs have been working but I’m not a fan of huge exhaust. I’d rather have a single muffler that doesn’t have drone. |
So you put the headers on and found 18-19 on progression. Do you recall what the reading was on progression with the VS on?
I'm wondering if i can assume some linear relationship between wideband readings with the VS muffler and "true" readings. I'm doubting this but worth investigating |
Motor60 Samba Member
Posted: Fri Nov 03, 2017 1:30 pm Post subject: Re: Vintage Speed muffler |
On progression, with VS, my readings were 15-16. With headers, same idle jets, readings were 18-19. Much hesitation on acceleration.
With correct jetting, headers read 16-17. When I put back on the VS, it read 12-13. It was my opinion that the VS reads rich when in fact it’s way lean. That’s why I could never get the tuning right with that muffler.
Since then, I’ve removed the VS and am using a header system now. No one else has chimed in with this issue. Or they don’t even know it’s an issue and their tune is way off. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3444 Location: San Diego
Posted: Fri Nov 03, 2017 2:32 pm Post subject: Re: Vintage Speed muffler |
I dont think the location of the O2 sensors in the VS mufflers will work. Its a dead air zone. Probably was just put there for convenience by the Mfg'r |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Mon Nov 06, 2017 12:52 pm Post subject: Re: Vintage Speed muffler |
Finally re-clocked the flanges so the heater boxes match the muffler. Now to get it all coated.
_________________ Glenn
Member #1009
#BlueSquare |
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Wed Nov 08, 2017 1:14 am Post subject: Re: Vintage Speed muffler |
norris wrote: |
I'm tired of the big muffler hanging off the back of my 54 Oval....not to mention the noise. I'm just about ready to pull the trigger on a VS but have a question for you guys. The 54 doesn't have exhaust cut outs in the apron....does anyone know if this will be a problem? If so, can I run a single outlet VS bus muffler?
The 2276 is really strong and I realize that I may need to rejet the 48IDFs.
Tell me what you think.
Thanks
I guess the VS with two pipes can fit on the apron of your '54 Oval even if there are no cutaway provisions for the peashooters. For sure VS had in mind the big big market for bugs whose aprons have no cutaway provisions. Otherwise, the the next available mufflers is the one with four pipes that are angled a bit downward in order not to get entangled with the cutaway-less rear apron. But will not work property on your Oval's big engine. This is for the Okrasa-inspired engines only.
BTW, so so looking awesome Oval there, Buddy! _________________ '67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20 |
Posted: Wed Nov 08, 2017 3:19 am Post subject: Re: Vintage Speed muffler |
I just made some research, and this is what I found: for 1955 + models
@ http://vwparts.aircooled.net/Vintage-Speed-SS-Sport-Muffler-155-203-05200-p/155-203-05200.htm
Quote: |
Vintage Speed Stainless Steel Sport Muffler (Up to 125hp) for 1300-1600cc Based Type 1 Engine in 1956-74 Beetle, Super Beetle, and Ghia, 155-203-05200 is the finest "Pea Shooter" exhaust available for your VW Beetle or Ghia! This model exits the pea shooters like stock, in the stock Rear Apron Cutouts on 1955+ carbureted models! This is a 1 1/2" (38mm) exhaust system, which is a HUGE upgrade from the stock 1 1/4" (32mm) system. This is called the "Heater Style" muffler because it is designed to retain the stock or 1 1/2" (38mm) heater boxes! |
'72 Type 2 Homey
'67 Splitty Bus
norris Samba Member
Posted: Wed Nov 08, 2017 3:26 pm Post subject: Re: Vintage Speed muffler |
Thanks man. I'm going to order that system in 1 5/8" tomorrow from aircooled.net. The one I need has the Abarth type pipes. Just ordered a distributor from Glenn, so I should be good to go....for a while. |
Posted: Wed Nov 08, 2017 6:04 pm Post subject: Re: Vintage Speed muffler |
norris wrote: |
Cool one. Looks like your oval will have her fresh look once the new muffler system had been installed. Keep up posted on the installation. Thanks. _________________ '67 KG Cabrio (Mickey) ;
'72 Type 2 Homey
'67 Splitty Bus
Posted: Thu Nov 09, 2017 6:42 am Post subject: Re: Vintage Speed muffler |
Motor60 wrote: |
Thanks man. That's brilliant info! |
KILLERWATT Samba Member
Joined: November 18, 2003 Posts: 3298 Location: Vero Beach
Posted: Fri Nov 10, 2017 7:03 am Post subject: Re: Vintage Speed muffler |
Probably 7 years ago the bus ones had a problem with the inside baffle welds breaking which made a terrible noise. They added more weld and fixed the problem. I ran one for a few years daily and never had a problem with mine. |
MUD.MAN Samba Member
Joined: April 16, 2007 Posts: 70 Location: Paragould Ark.
Posted: Sat Nov 25, 2017 4:36 pm Post subject: Re: Vintage Speed muffler |
SO after reading this post I have gathered. Replace mounting hardware. Has a quiet sound. Might crack at welds. very few are posting on performance. I don't want to loose any HP,or much. I,m wanting my car to be quieter and my current system is kinda bumping and grinding on the body and such. I am running a 1 7/8 header with a fat boy. If I get the larger VS will it performance close? |
norris Samba Member
Posted: Sat Nov 25, 2017 9:10 pm Post subject: Re: Vintage Speed muffler |
I ordered a VS 1 5/8" system from aircooled.net a week or so ago. Hopefully will receive it in a couple of weeks. I'll report on fit and performance when I do.
Posted: Sun Nov 26, 2017 12:46 pm Post subject: Re: Vintage Speed muffler |
Mine is 1 5/8” superflow. I didn’t think I lost any performance. Except maybe on fwy. I felt like it didn’t have as much torque at higher speeds. But it is MUCH quieter on fwy. Definitely noise improvement.
Might be interested in selling.... |
norris Samba Member
Posted: Sat Dec 02, 2017 6:26 pm Post subject: Re: Vintage Speed muffler |
Fit perfectly. My 54 Oval no longer sounds like Nissan or Honda with a "coffee can" exhaust. Now sounds like a VW but with a deep throaty rumble. No drone at speed.
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Sun Dec 03, 2017 3:06 pm Post subject: Re: Vintage Speed muffler |
And it looks good too! _________________ Some people are so busy being clever they don't have time enough to be wise. |
norris Samba Member
Posted: Sun Dec 03, 2017 5:33 pm Post subject: Re: Vintage Speed muffler |
pyrOman wrote: |
And it looks good too! |
Thanks.
I've spent the day adjusting the timing and carbs after installing the 1 5/8" VS system, one of Glenn's 010 distributors and a Winterburn CDI. Everything is working quite well together. The most notable observation is that I seem to have better torque at lower rpms. When I shift to second at a low rpm it "pulls" better than it did with the A-1 headers/muffler.....easier with less shifting to corner around town. I more than likely have lost a bit of high rpm HP/torque but I'll never know as I rarely go over 4500rpm.
I'm very please with the VS system. Installation was a snap even on my Oval with a big engine. I love the look. A friend of mine was just over here checking it out...he says it sounds just like his '61 356....makes me smile!
And, btw, my Oval is quite a bit faster than his 356 and handles almost as well. |
blue65 Samba Member
Joined: March 10, 2016 Posts: 123 Location: Melbourne Australia
Posted: Mon Dec 04, 2017 1:53 am Post subject: Re: Vintage Speed muffler |
FYI, be sure to glue the two bolt nuts on either side of the cylinder muffler or tighten them from time to time as they will wiggle out leaving a hole.
I lost both of them. |
Redlines Samba Member
Joined: June 07, 2009 Posts: 168 Location: Fredonia, NY
Posted: Mon Dec 04, 2017 10:20 am Post subject: Re: Vintage Speed muffler |
Am seriously considering this muffler but wanted the "quiet" version. However, unless I'm mistaken, I thought the quiet version was an extra $35.00. Now I see its $100.00. Is the quieter version that much quieter? I'd give it a shot for $35 but don't know about $100. Maybe I just don't remember correctly! |
mark tucker Samba Member
Posted: Mon Dec 04, 2017 11:42 am Post subject: Re: Vintage Speed muffler |
these days it seems everything is more expensive when your ready to get it. |
Paul.H Samba Member
Posted: Tue Dec 05, 2017 9:05 am Post subject: Re: Vintage Speed muffler |
k@rlos wrote: |
Horrid things! overpriced, restrictive and sound awful. Swapped 1 on a 2054 stroker with a sidewinder and it made 19hp more |
SSSSh don't let facts get in the way of good opinion |
