barefootwestie Samba Member
Joined: September 19, 2005 Posts: 1551 Location: Johns Island, SC
Posted: Wed Oct 04, 2017 3:39 pm Post subject: Distributor shaft popping out |
After doing an engine cleanup over the past several years, I've put my distributor back in and she fired up. Timing not perfect but thats ok.
The problem is after shutting it off and somewhat of a celebration, tried to crank again and wouldn't start. After troubleshooting, the rotor is turning freely and not engaged with the gear. The distributor is seat as far down as it will go and the holder is tight.
Any ideas what I may be overlooking? Never had an issue with the distributor doing that before. _________________ My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia
Last edited by barefootwestie on Thu Oct 05, 2017 2:06 pm; edited 1 time in total |
wcfvw69 Samba Purist
Posted: Wed Oct 04, 2017 3:43 pm Post subject: Re: Distributor popping out |
Check the distributor hold down clamp. Is it twisted and not 'holding' the distributor where you can't spin it?
The cheap Chinese distributor clamps are famous for this. _________________ Contact me at [email protected]
The Samba member since 2004.
SGKent Samba Member
Posted: Wed Oct 04, 2017 3:45 pm Post subject: Re: Distributor popping out |
barefootwestie wrote: |
Any ideas what I may be overlooking? Never had an issue with the distributor doing that before. |
Pull the rotor off, turn it over, and see if the key underneath it is broken. If yes replace, if not put the rotor back on and be sure the key engages on th distributor shaft. Then slowly turn the rotor to see if it stops - if it keeps spinning, turn it slowly while pushing the distributor down until the distributor drops into the slot. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Oct 04, 2017 3:48 pm Post subject: Re: Distributor popping out |
wcfvw69 wrote: |
The cheap Chinese distributor clamps are famous for this. |
The hold down clamp is flush with the block so yes. Don't know if its a chinese distributor, same one Ive had since bought it 11 years ago.
It' a 021 905 205 P if that helps. _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
Posted: Wed Oct 04, 2017 3:50 pm Post subject: Re: Distributor popping out |
The dog on the bottom of the distributor shaft may kind of grab when the shaft is 180° out. Turn the rotor a full 180° and see if the dog will lock into the slot?
If the thrust washers that fit between the dog gear and housing are missing the dog gear can ride higher than it should increasing the chance that it will not stay in the slot. |
Posted: Wed Oct 04, 2017 4:34 pm Post subject: Re: Distributor popping out |
wcfvw69 wrote: |
It' a 021 905 205 P if that helps. |
I'm speaking of the distributor hold down where the clamp the squeezes together with the bolt and holds the distributor from turning. Sometimes the cheaper hold down clamps have cheap bolts and they are the nut strip as well. _________________ Contact me at [email protected]
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed Oct 04, 2017 5:07 pm Post subject: Re: Distributor popping out |
it's a type 4 engine. didn't know there were cheap chinese type 4 clamps being made.
deja vu kinda sorta all over again? https://www.thesamba.com/vw/forum/viewtopic.php?t=686566 _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Wed Oct 04, 2017 5:09 pm Post subject: Re: Distributor popping out |
Yeah. Mine has the big 10mm hex to tighten it _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
Posted: Wed Oct 04, 2017 5:11 pm Post subject: Re: Distributor popping out |
can you post a pic from above showing your distributor installed? perhaps is it not truly seated even though you think it is. like the vac can is hitting the case, etc _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
Posted: Wed Oct 04, 2017 5:14 pm Post subject: Re: Distributor popping out |
Thanks for the other link. _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
Posted: Wed Oct 04, 2017 5:40 pm Post subject: Re: Distributor popping out |
Loosen the clamp, rotate the rotor while pressing down firmly until you you feel the shafts align, the dizzy should noticeable drop a bit as you do this. Twist the dizzy body down as far as it will go and lightly snug the clamp. Time engine and tighten clamp. |
Posted: Wed Oct 04, 2017 5:42 pm Post subject: Re: Distributor popping out |
I'll try it again. Gotta pull the plug again to find tdc. Third time's a charm... Hopefully. _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
Tcash Samba Member
Posted: Wed Oct 04, 2017 6:28 pm Post subject: Re: Distributor popping out |
If you removed the distributor drive gear? Make sure you put the washer back under it.
thnx jesey
#10
Posted: Thu Oct 05, 2017 3:35 am Post subject: Re: Distributor popping out |
Didn't remove the gear.
After thinking about overnight, I should have clarified. I don't think the actual distributor is popping out. Seems like it's more the shaft from the gear. The rotor is still attached properly but the shaft spins freely. When I put in both times so far, the shaft would only turn with the engine. Then would crank and it's like the shaft is disconnecting from the gear. There doesn't seem to be a lot of play in the distributor and again, everything was working properly prior to me removing it.
Maybe I'm not pressing the distributor shaft in hard enough. Is it like a socket and ratchet fitting somewhat?
Thanks for all your help. Hope to look at again tonight or. This weekend. _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia
Last edited by barefootwestie on Thu Oct 05, 2017 5:02 am; edited 1 time in total |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Thu Oct 05, 2017 4:38 am Post subject: Re: Distributor popping out |
Take a good look at the distributor clamp. If you tighten it too much it will buckle and lift the distributor body away from the block. Even if made in Germany.
If its made in china then it may begin its life this way - my EMPI needed the fixing tang straightened up so when it was bolted down the clamp was actually flat to the block. _________________ Ancient vehicles and vessels
furgo Samba Member
Joined: September 06, 2016 Posts: 944 Location: Southern Germany
Posted: Thu Oct 05, 2017 5:04 am Post subject: Re: Distributor popping out |
mikedjames wrote: |
If its made in china then it may begin its life this way - my EMPI needed the fixing tang straightened up so when it was bolted down the clamp was actually flat to the block. |
The OP mentioned it was a 021 905 205 P, so it should be an original Bosch (unless Chinese distributors also have the VW part number stamped). _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate |
Posted: Thu Oct 05, 2017 5:11 am Post subject: Re: Distributor popping out |
I don't want to get over sentimental or anything, but I sure do appreciate you guys. I haven't been on very much the past 2 years as I just haven't had time for working on the bus because of life and focusing on the wife and kids, but then I just show up, and you guys are always there.
Really glad this forum hasn't died away due to people's attitudes. _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Thu Oct 05, 2017 6:41 am Post subject: Re: Distributor popping out |
The only two distributors that I am aware of that are being reproduced are the 0 231 178 009 and the 0 231 170 034 (VW# 043 905 205). it's unlikely any of the Bosch DVDA will be reproduced. I am aware of some efforts to reproduce the 0 231 129 010 and 019 in cast iron which should be interesting. I get this question all the time with a customer concerned that their 113 905 205 T is a German Bosch unit. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Thu Oct 05, 2017 6:47 am Post subject: Re: Distributor popping out |
Sometimes even on original clamps that have been over tightened the clamp stays flat but the 10 mm od bolt starts to bend making proper tightening impossible which results in more tightening/ bending required... _________________ Roads Scholar &
Posted: Thu Oct 05, 2017 6:50 am Post subject: Re: Distributor popping out |
Sometimes even on original clamps that have been over tightened the clamp stays flat but the 10 mm od bolt starts to bend making proper tightening impossible which results in more tightening/ bending required. this is the result:
