1956 lowlight restoration
Page: Previous  1, 2, 3, ... 11, 12, 13  Next
Braukuche
Braukuche is offline
PostPosted: Tue Oct 31, 2017 12:06 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
c21darrel wrote:
Its gonna get darker earlier before it stays light longer. Crying or Very sad Dislike this time of year.
Did you make the nose/badge patch? Shocked Really nice!
The nose badge patch came from HOG years ago, so I was lucky to get that when I got the car. I just welded it in.
Yeah, I know it's just going to get worse light wise, until Dec 22...
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
c21darrel
c21darrel is offline
PostPosted: Tue Oct 31, 2017 2:02 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
really lucky. Ive never seen that patch piece before. Kind of a short run on the raised section.
I'm marking that date down. Smile
GhiaBuild
1967 DC build
Braukuche
PostPosted: Sat Nov 11, 2017 8:33 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
Been chipping away at this thing. My goal is to finish the entire front of the car from the dash out to the nose so I can then epoxy and Poly prime it in one fail swoop. I didn't think there was too much work on the front clip, but of course it turned out to be a bigger mess than I thought as I removed paint and sandblasted rust sections revealing pin holes and shoddy repairs. So, I ended up having to amputate more rotten metal then anticipated which has consumed more time.
After welding in patches I like to cover the repair section with a thin layer of kitty hair since it is water proof, adds rigidity and covers up any pin holes I might have missed. I will eventually grind it down and then build filler on top of that to smooth it out before priming.
I also had to end up replacing the lower spare tire well recess. It looked good but blasting revealed a mess, and since the metal was so thin I had to cut it out. I couldn't find a repair panel on line, which is odd, since it is a common area for rot, so I made my own using basic tools and a vice.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Mellow Yellow 74
Mellow Yellow 74 is offline
PostPosted: Sat Nov 11, 2017 9:29 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
The usual vendors have this repair panel - they call it the front apron or lower front panel. This panel has quite a bit of crown/shape to it to allow the spare wheel to fit so be aware if you use the flat panel you have made the spare wheel may not fit with the front trunk closed.
1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon)
Braukuche
PostPosted: Sun Nov 12, 2017 8:23 am    Post subject: Re: 1956 lowlight restoration Reply with quote
Thanks for pointing that out. You are correct. One second look, KGP and R didn't have a picture or it, I went to CIP they did, but you can barely make out the embossed area which is why I didn't think they had it.
What is pictured is just the beginning stages of forming it. I have shaped the crown to allow for the spare,
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Braukuche
PostPosted: Sat Nov 25, 2017 5:26 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
Spent the past couple weeks doing some final patches, then some body work. Kept chasing small dents, using the hammer and dolly and the stud puller to work them out and the then finish with a small bit of filler and then sanding, etc. finally was able to get down a quick coat of epoxy this afternoon and will top off with several coats of polyprimer tomorrow. Filled areas are visible as those areas where the primer has dried first.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
c21darrel
PostPosted: Mon Nov 27, 2017 12:50 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
Nice progress!! What brand of epoxy are you spraying?
GhiaBuild
1967 DC build
Braukuche
PostPosted: Mon Nov 27, 2017 1:39 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
Thanks.
I use TCP products, the epoxy is House of Kolor as is the polyprimer. I plan on using their Restoration line single stage for the color.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Braukuche
PostPosted: Mon Nov 27, 2017 1:49 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
...and now in polyprimer. My usual method is to do the rough bodywork, welding and filler, then epoxy and polyprimer so I can see all the defects. Many can be sanded out, but some will require a super thin application of glazing putty or filler. ONce I think I have the panel perfect I polyprimer again and discover I don't after blocking again. Usually though I can work out all the flaws by blocking at that point.
I still need to do the trunk which I will just clean up and then epoxy. I also have to do the underside of the front clip, a few patches, clean up and epoxy.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
c21darrel
PostPosted: Mon Nov 27, 2017 4:41 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
TCP, I bought a bunch from them in the past. Been using the local paint shop most recently with a friends shop discount. I bet your close enough you don't have to pay shipping. Smile
GhiaBuild
1967 DC build
Braukuche
PostPosted: Tue Nov 28, 2017 1:29 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
Yep. About six miles away or so. Just wish they were open on weekends.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
oldbusboy
oldbusboy is offline
PostPosted: Sat Dec 02, 2017 10:16 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
Looks really nice. Great work
Trevor
1968 porsche
Braukuche
PostPosted: Mon Dec 11, 2017 7:21 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
Been messing not with installing disc brakes on my 59 bus, so the Ghia has been on standby. I ended up with a surprise day off today (in other parts of the country they get snow days, here in So Cal we get fire days) so I fired up my new 60 gallon 3.5hp compresser and cleaned up the dash and underside as well as hit some rust spots in the trunk. I then Osphoed it. Will clean it up again, do some sanding.on the pepto bismal pink paint in the trunk, then epoxy it.
Also ordered my paint today from TCP . They had the formula but I.gave them the inspection plate which had excellent original paint on it.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
70 140
70 140 is offline
PostPosted: Wed Dec 13, 2017 6:43 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
That 74 you had was pretty nice from what I remember.
Nice work so far with this one.
Braukuche
PostPosted: Sun Dec 17, 2017 2:00 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
Thanks, that was a fun car, a total mess when I got it.
Cleaned up the dash and trunk and epoxy primed it.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
chrisflstf
chrisflstf is offline
PostPosted: Sun Dec 17, 2017 5:41 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
Looks good, what are you using for a spray gun?
Braukuche
PostPosted: Sun Dec 17, 2017 8:55 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
Thanks.
Devilbis HVLP gun with a wide tip for primer.
I just bought a 3.5 hp, 60 gal compressor which makes it nice. I might even paint the thing.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Braukuche
PostPosted: Sat Dec 30, 2017 10:01 am    Post subject: Re: 1956 lowlight restoration Reply with quote
Been addressing the disaster which was the rear right quarter. The panel had been cut before I got the car so I had no frame of reference for what the actual shape of the fender should be like other than photos and extrapolating based on what I had to work with. I was given some later donor panels and I had a repair section, but none of those are correct, so I had to weld splice cut and pound. So I reconstructed it based on what I think is correct. Obviously it needs more work, so if the contour of the wheel well looks off you won't hurt my feelings pointing it out.it would be easy enough to correct at this point as I have not body worked it.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
lovethatconvertible
lovethatconvertible is offline
PostPosted: Sat Dec 30, 2017 11:02 am    Post subject: Re: 1956 lowlight restoration Reply with quote
Dan, if the rear end ends up looking like the front end, your golden. I have no doubt you'll end up with what you envisioned. That body is going to look fantastic with a coat of paint on it, Can't wait.
1960 Convertible
c21darrel
PostPosted: Sun Dec 31, 2017 2:17 pm    Post subject: Re: 1956 lowlight restoration Reply with quote
nice work. Here is a visual for you (its a fender Blackdog Corey is selling) Its got great pics of the area you are working on.
https://www.thesamba.com/vw/classifieds/detail.php?id=1991772
GhiaBuild
1967 DC build
Page 2 of 13
