Humdinger Samba Member
Joined: September 27, 2012 Posts: 183 Location: NE Arkansas
Posted: Thu Oct 05, 2017 8:14 pm Post subject: Headlight bucket help |
Does anywhere know where I could find some chrome 5.75 inch headlight buckets? These came with my buggy and the chrome was in bad shape so I had to paint them for the time being. On the current buckets the wire run thru the mounting bolt... id like to keep this feature but I will settle for external wires if I have to.
manxdavid Samba Member
Joined: November 24, 2003 Posts: 1841 Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
barrist Samba Member
Joined: September 04, 2010 Posts: 271 Location: South Bend,IN
Posted: Fri Oct 06, 2017 4:28 am Post subject: Re: Headlight bucket help |
This is where I shopped.
https://www.speedwaymotors.com/shop/headlights~14-...headlights
Have a Great Day,
Bill _________________ Back to work after a 6 year lack-of-motivation !
Still looking for the GAS CAP (check that,Done)
Thank YOU , this site works |
Rockbound Samba Member
Joined: September 06, 2017 Posts: 303 Location: Pennsylvania
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Oct 06, 2017 7:33 am Post subject: Re: Headlight bucket help |
"Barrist" beat me to "Speedway Motors" as a source....
Posted: Fri Oct 06, 2017 8:01 am Post subject: Re: Headlight bucket help |
Those last two only come in 7". That top one that manxdavid posted looks like it has a hole in the top for drainage on a motorcycle when it's mounted upside down? |
andygere Samba Member
Joined: January 31, 2014 Posts: 600 Location: Central Coast, CA
Posted: Sat Oct 07, 2017 5:41 am Post subject: Re: Headlight bucket help |
Try Meyers Manx. They are the stock supplied units on Manxter 2+2 buggy kits, which are still in production. The quality is just OK, but they do run the wires through the mounting bolt. |
Posted: Sat Oct 07, 2017 7:26 pm Post subject: Re: Headlight bucket help |
The 5.75 inch buckets are off road lights... NOT standard headlights... Dont think you are going to find small buckets unless you get some off motorcycle chopper merchandising sites....
Friend built buggy and used the small buckets and had to get motorcycle sealed beams to put in off road light buckets to make his setup work...
jsturtlebuggy Samba Member
Posted: Sat Oct 07, 2017 10:28 pm Post subject: Re: Headlight bucket help |
The headlight housing you have are for an off road light 100w single filament bulb. They called them a 6in light, but are actually use 5-3/4in bulb. Same size that was used on dual headlight cars and trucks. Most common on General Motors vehicles before square headlight were used.
Summit Racing does carry a brand called, Anzo off road light that look the same size as what you have, the 6in (or 5-3/4in) bulb (reflector).
They are chrome plated. They use the rubber part like yours to hold the bulb.
Summit Racing Part# ANN-821001 and sell for $18.97 each.
I using a different brand on my buggies that are the same size. What I did was use the bolts that came in my other lights that are drilled for the wiring to go through. On the back side where the wiring comes out, I found a plastic plug to fill the hole at Ace Hardware.
For the bulb(reflector) I am using Hella Summit Racing part#HLA-002850001 and H4 55/60W bulbs in them I bought at Walmart. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Sun Oct 08, 2017 4:45 pm Post subject: Re: Headlight bucket help |
I'm using tractor headlight housings with 5-3/4" hi-low beam Halogen headlight housings/bulbs.
https://www.thesamba.com/vw/forum/viewtopic.php?t=647537&highlight=
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Wetstuff Samba Member
Joined: September 23, 2010 Posts: 700 Location: Maryland
Posted: Mon Oct 09, 2017 9:45 am Post subject: Re: Headlight bucket help |
HD, Some think the larger, 7" bucket adds a lighthearted character... like that farm gate windshield. If your hood is to stay black, it seems your lamps blend in..? Maybe, matte paint.
Jim _________________ Manx #2614 |
Bluggy Samba Member
Joined: September 12, 2017 Posts: 151 Location: Caribbean
Posted: Mon Oct 09, 2017 11:35 am Post subject: Re: Headlight bucket help |
I have been looking at light options and thinking of going with LED's. I am a purist too but at times let practically over ride originality.
I know the halogens will put out decent lighting too and easier to change bulbs, so tossing up between the two. I am one of those who would like to go smaller and lighter (LED's heavier) due to the bumpy roads here and less weight to avoiding cracking paint or fiberglass mounting points.
Here the salt air and beaches will kill chrome stuff easily.
I am also thinking of going two smaller LED lights on the brush guard.
Bluggy Samba Member
Posted: Tue Oct 10, 2017 11:06 am Post subject: Re: Headlight bucket help |
Just called them to look at some options, was looking for stainless steel, but their tech said I should go to an off road shop for that.
They have stainless in the 7" size but not much below that..dont know why they would think an off road shop is better??? |
Bluggy Samba Member
Posted: Tue Oct 10, 2017 11:14 am Post subject: Re: Headlight bucket help |
OP take a look at these 5.75" dia, read the description..seems like an OK quality, you will have to use some parts from your old lights if you want mounts to look the same.
I machine my own parts so I can fab something for mine.
Cheers.
https://www.amazon.com/Chrome-Halogen-Motorcycle-H...headlights
NB. The only review is a 1* saying high beam not centered |
Posted: Tue Oct 10, 2017 1:50 pm Post subject: Re: Headlight bucket help |
I did some more searching for the Stainless Steel headlight buckets like the one I am using, that I bought from Summit Racing. Summit no longer carries them.
There is a brand called Rugged Ridge that has the stainless steel headlight buckets like what I have.
They are listed under a 6in off road light #15208.01 in many different places including JEGS and several other off road stores. I am sure that they can be found on both Amazon and Ebay too.
A 6in off road light uses the 5 3/4in headlight bulb.
Rugged Ridge has a site showing all their products.
They are just like your housings, just made out of stainless steel. They have the same rubber mount for the light and and rubber mounting to the body if wanted to use them. _________________ Joseph
Elrod Motorsports
Bluggy Samba Member
Posted: Tue Oct 10, 2017 7:57 pm Post subject: Re: Headlight bucket help |
There are some made for 1932 Fords in stainless too for $114.00 a pair but these are 3.5 inches in diameter and use regular bulbs.
They might be modified to use H4 bulbs, not sure how that small will look on the Buggy.
https://www.speedwaymotors.com/Speedway-1932-Ford-...,3024.html
The Rugged Ridge ones I have seen before, not bad looking. You will need to modify it to use an H4 bulb to get both high and low beams. There might be H4 type lights which can fit into these too. |
Posted: Tue Oct 10, 2017 8:25 pm Post subject: Re: Headlight bucket help |
Bluggy, In my first post I said what I did with identical stainless steel housings. I have been using them since 2009.
A 6in off road light use a 5 3/4in size bulb. It fit into the rubber part easily. Yes you have to cut the rubber in 3 places for the part of the bulb/reflector that keeps them in position. Keeps them from rotating.
You can use a standard 5 3/4in seal beam dual filament, halogen, LED, HID, Zenon, or any H4 light in that size.
From the OP picture it looks like it already has the 1/2in mounting bolts that has been drilled for the wire to run through.
Where the wire harness that comes out the back, I remove it and used a black plastic plug to fill the hole.
With the light being rubber mounted the filaments last longer from not having to absorb the shock of using them on rough road conditions.
Yes they are not a shiny as chrome ones, but I got tired of the chrome ones starting to rust in a matter of days of installing. _________________ Joseph
Elrod Motorsports
Bluggy Samba Member
Posted: Tue Oct 10, 2017 8:44 pm Post subject: Re: Headlight bucket help |
Hi jsturtlebuggy, thanks for the details and info. Going the route you did seems great and practical.
The 6 inch bucket I think has a nice look, lighter and yes being stainless is a huge plus. I was going for either stainless or LED with the aluminum cooling fins/heat sink.
Gone are the days when Chrome used to be chrome, when your bicycle rims kept its chrome finish forever with all of the abuse.
Even stainless steel was exactly stainless steel back then, now you have to ask the sellers what grade and percentage of stainless they have.
I bought some "stainless steel" bolts and nuts here not too long ago, just out of curiosity I grabbed my pick up magnet to test it, I was not surprised it grabbed them like they had glue on them.
I was thinking of getting the EMPI all "chrome" alternator kit, but since they raised the price on me and thinking the chrome might be a waste of money, I might just get the regular kit.
Cheers. |
