von split Samba Member
Joined: March 05, 2005 Posts: 64 Location: I'm here.... but I'm not all there.
Posted: Sun Oct 08, 2017 6:36 am Post subject: Split Dash Ashtray Problem |
I have 3 split dash ashtrays and 3 dash mounting receptacles for my Sept.1951 (long, ugly story short). All parts are original VW and are all period correct. As it turns out, none of the ashtrays fit any of the receptacles. All of the ashtrays seem to be a little too big in diameter. I've tried every ashtray in every receptacle, and they just don't fit. Has anyone had the same experience? Am I missing something? I looked through the forum, the gallery and the ads looking for a clue. I know VW had supply issues back then, but a simple ashtray? Any help would be greatly appreciated. Thanks. |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Sun Oct 08, 2017 8:06 am Post subject: Re: Split Dash Ashtray Problem |
You probably did try this, but I wanted to check that you rotated the ashtray so the slot on the bottom indexes with the raised bump on the recepticle. The are designed so the ashtray cannot be removed without twisting it just before it comes out of the dash, the opposite for installation. _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Sun Oct 08, 2017 8:43 am Post subject: Re: Split Dash Ashtray Problem |
Yes, I did try that. The raised bump is toward the back of the receptacle. The ashtrays won't go it at all. They are just a little too big. I can't even get them started. Thanks. |
Suboval Samba Member
Posted: Mon Oct 09, 2017 1:40 pm Post subject: Re: Split Dash Ashtray Problem |
You might have 356 Pre A Porsche ash trays. They are a larger diameter. _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
Posted: Mon Oct 09, 2017 5:18 pm Post subject: Re: Split Dash Ashtray Problem |
Thanks for your input. I'm not a Porsche guy, but I'll certainly look into it. |
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Mon Oct 09, 2017 6:03 pm Post subject: Re: Split Dash Ashtray Problem |
Had 'em rechromed? _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
Posted: Tue Oct 10, 2017 10:43 am Post subject: Re: Split Dash Ashtray Problem |
None of them have been rechromed. They all have ware on them, so they have been used. I am surprised that no one has had a similar problem. |
René R. Samba Member
Joined: July 06, 2015 Posts: 1710 Location: No. Calif.
Posted: Tue Oct 10, 2017 12:34 pm Post subject: Re: Split Dash Ashtray Problem |
It's been a while since I've owned a split but I'm thinking that it's possible that the part that mounts in the dash is made of pot metal. I vaguely remember it having a grayish color that looked very different from steel.
In any event, if either part is pot metal it could have swelled over the years -- a very common problem with this often poorly-made alloy. You may just have to do some filing. _________________ Gone but not forgotten: 1950 Hoffman split (restored in 1966) - another 1950 Hoffman split (restored in 1996) |
Posted: Tue Oct 10, 2017 5:36 pm Post subject: Re: Split Dash Ashtray Problem |
The receptacles are made of aluminum. |
52HoffmanSplit Samba Member
Joined: April 07, 2006 Posts: 1272 Location: Lamorinda CA
Posted: Tue Oct 10, 2017 7:38 pm Post subject: Re: Split Dash Ashtray Problem |
von split wrote: |
If they are made of aluminum they are older 80's repops (or possibly Pre-A but I'm no Pre-A guy)... all parts of the originals including the sleeves were made of the cheapest most brittle potted metal you have ever seen. The stuff breaks on the shelf... I'll post a few pics tomorrow... showing just this. _________________ DB
9/1950 Hoffman Standard
11/1966 Porsche 912
10/1966 Porsche 912
7/1968 Type 265 Double Cab
10/1958 Type 117 |
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Tue Oct 10, 2017 7:47 pm Post subject: Re: Split Dash Ashtray Problem |
This is getting interesting, never knew that about pot metal. I knew it was crappy, even in the '60's I thought pot metal was poor from handling different thing's made from it. a lot of stuff from Japan and other small trinkets. _________________ 1960 Convertible |
Posted: Tue Oct 10, 2017 8:19 pm Post subject: Re: Split Dash Ashtray Problem |
52HoffmanSplit wrote: |
all parts of the originals including the sleeves were made of the cheapest most brittle potted metal you have ever seen. The stuff breaks on the shelf... |
That definitely sounds like pot metal.
Filing it (assuming it doesn't shatter) is the only solution.
Working with pot metal can be tricky. Some batches hold up pretty well and can be filed and otherwise manipulated. Others will crack and/or shatter at seemingly the slightest touch. It usually depends upon how much zinc was used in the blend.
Some information. _________________ Gone but not forgotten: 1950 Hoffman split (restored in 1966) - another 1950 Hoffman split (restored in 1996) |
Posted: Wed Oct 11, 2017 4:52 pm Post subject: Re: Split Dash Ashtray Problem |
Thanks for all your help guys. I have some sorting out to do. I had no idea they were originally pot metal.
A. I can keep looking for a nice set.
B. I can work the ones I have and hope for the best.
I guess I'll try both and see what happens. |
