Starter Issues
MeeferMadness
MeeferMadness is offline
PostPosted: Sun Oct 08, 2017 5:02 pm    Post subject: Starter Issues Reply with quote
Finished an Okrasa build for my 59 bug. I am setting up the engine for its first startup and having issues with the starter. I tried using a remote switch ( just a wire running from the solenoid to the battery with switch in between) and was not successful. When I short across the solenoid and starter with a screwdriver the starter spins over, but when using the remote switch I just get a click sound on the starter. Don't understand what the issue might be. Any suggestions would be helpful.
Bruce
mukluk
mukluk is offline
PostPosted: Sun Oct 08, 2017 5:16 pm    Post subject: Re: Starter Issues Reply with quote
Sounds like your remote start switch or wire isn't passing enough power for the solenoid to operate.
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Oct 08, 2017 5:35 pm    Post subject: Re: Starter Issues Reply with quote
Only the starter, and not the engine turning over with the starter??
In Stereo, Where Available!
rockerarm
rockerarm is offline
PostPosted: Sun Oct 08, 2017 6:17 pm    Post subject: Re: Starter Issues Reply with quote
Hi. Follow this video and see if it helps.
https://www.youtube.com/watch?v=WMXENKujYtc&t=28s
MeeferMadness
PostPosted: Sun Oct 08, 2017 7:45 pm    Post subject: Re: Starter Issues Reply with quote
When using the remote switch the engine either does not turn over or it may spin it for a half revolution. Even though the starter will spin the engine over I think it is still spinning too slow. All connections are good and I have clean grounds. I suspect either a defective starter or possibly a weak battery. The suggested video was great and very informative.
Bruce
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Mon Oct 09, 2017 9:04 pm    Post subject: Re: Starter Issues Reply with quote
Skip the remote switch for now. Go back to the basics and check that you can start it without anything fancy. Check the battery with a voltmeter.
Eric&Barb
PostPosted: Mon Oct 09, 2017 9:23 pm    Post subject: Re: Starter Issues Reply with quote
Any answer to the above??
MeeferMadness
PostPosted: Tue Oct 10, 2017 6:42 am    Post subject: Re: Starter Issues Reply with quote
Recently been slammed with family stuff. As soon as I find the problem and start the engine I will reply with the solution. Again thanks for all the suggestions!
Bruce
turbotype1
turbotype1 is online now
PostPosted: Tue Oct 10, 2017 8:02 am    Post subject: Re: Starter Issues Reply with quote
Just went through a starting issue on my wife's 64.
After cleaning all connections and replacing the starter, it still would give me cranking issues.
At sometime in this cars life, the battery cables were replaced with 6 gauge cables. It all ways cranked slow, but being 6 volt, I thought it was normal.
I replaced those cables with 2 gauge ones( seems overkill) and this thing spins over like any other car now.... can not believe the difference!!
One more thing, Make sure your battery is FULLY charged
117harv wrote:
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel
MeeferMadness
PostPosted: Wed Oct 11, 2017 10:10 pm    Post subject: Re: Starter Issues Reply with quote
I double checked all connections for good metal contact, then removed the battery and starter and took the to my local flaps. The battery checked out better than new so I purchased a rebuilt starter. After installing the starter everything works much better although it still seems to crank slow. It could be the brand new engine with a little higher compression ratio, and performance cam. All in all very much improved. Will now also add some fuel and see if I can fire this puppy up!
Bruce
Cusser
Cusser is offline
PostPosted: Thu Oct 12, 2017 7:15 am    Post subject: Re: Starter Issues Reply with quote
Bruce - did you install a new starter bushing with the new starter ????
MeeferMadness
PostPosted: Thu Oct 12, 2017 7:18 am    Post subject: Re: Starter Issues Reply with quote
Yes I did, the rebuilt starter came with one.
Bruce
