Daniel Fisher Samba Member
Posted: Sun Oct 08, 2017 6:15 pm Post subject: Push Rod Tubes |
I recently purchased a VW Dune Buggy. It is a great leaker. Looking for pros and cons for spring loaded push rod tubes. Which brand and why. Best parts supplier to deal with.
Possibly a 1967 dual port 1600.
Thanks |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Sun Oct 08, 2017 6:31 pm Post subject: Re: Push Rod Tubes |
If you need spring loaded push rod tubes to replace the old ones without removing the heads then get the JayCee tubes. They are the only ones that won't leak. The rest are junk. Several places sell them and they are all the same price.
If your rebuilding a engine than use the stock or stainless steel push rod tubes. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Fri Oct 13, 2017 6:08 pm Post subject: Re: Push Rod Tubes |
I just have a leaker so I want to replace the tubes for now. There may be a rebuild in the future but I'm not planning on it currently. Thanks for the reply. |
stevemariott Samba Member
Joined: November 09, 2003 Posts: 1052 Location: Portland, OR
Posted: Sun Oct 15, 2017 8:37 am Post subject: Re: Push Rod Tubes |
I'm using Scat spring loaded pushrod tubes - no leaks so far (knock on wood), and were easy to install while the engine was on the stand. Aircooled.net is great.
http://vwparts.aircooled.net/SearchResults.asp?Search=pushrod+tubes _________________ 1963 Manx copy
1968 Bus |
