rehoward Samba Member
Posted: Tue Oct 03, 2023 11:54 pm Post subject: Clutch/Flywheel for 1.8T Engine Swap |
I am in the process of doing a Vanagon engine swap using a Passat 1.8T engine. The Vanagon is a 1985 Waterboxer with a 1.9 engine.
I have been bartering for the necessary bellhousing, input shaft, oil pan, etc. I have been told that he (the seller) has a new flywheel for the 1.8T engine that will accept a stock Vanagon disc, pressure plate, and diesel starter. My first thought was, "Will the stock Vanagon clutch handle the power of the new 1.8T engine"? That seems sort of iffy to me but I could be wrong. Can I safely use his flywheel and a stock pressure plate and disc? What has been successful in past engine swaps using the 1.8T and manual transaxle?
Thanks for any and all suggestions,
Randy |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 784 Location: WestWorld Nanaimo BC
Posted: Wed Oct 04, 2023 3:17 am Post subject: Re: Clutch/Flywheel for 1.8T Engine Swap |
Kennedy Engineering info
KEP 228mm VW PRESSURE PLATES (9")
Fits '76 and newer VW Bus, Vanagon, Hewland DG, Fortin, and Mendeola transaxles using the KEP 9" flywheel. Torque capacities using a stock disc are shown below.
9" STOCK
200 ft. lb.
Stock 228mm VW Bus pressure plate. Suitable for engines under 3 liter for street use.
9" STAGE I
223 ft. lb.
This pressure plate works well in Porsche 911 powered 914's or V6 camper vans. Enjoy good holding power and easy pedal effort.
9" STAGE II
273 ft. lb.
This is the one used by winning unlimited class off-road racers. Also very popular for use in V8 powered 914's under 400 HP.
9" STAGE III
378 ft. lb.
This pressure plate is designed to handle 500 HP on an organic disc. Good for street or race applications with lots of power.
9" STAGE IV
420 ft. lb.
This pressure plate is designed to handle the larger V8 engines over 500HP.
Post achievement
dougnlina Samba Member
Joined: January 19, 2016 Posts: 246 Location: San Francisco, CA
Posted: Wed Oct 04, 2023 5:03 am Post subject: Re: Clutch/Flywheel for 1.8T Engine Swap |
Most use the Kennedy Stage I Clutch set up, it has a stock feel and handles the power fine as long as you are not riding the clutch rock crawling or something. _________________ "Olive" a '60 Ragtop Beetle
"Grover" a '87 Syncro Poptop 1.8T |
Posted: Wed Oct 04, 2023 6:29 am Post subject: Re: Clutch/Flywheel for 1.8T Engine Swap |
I'm running a single mass TDI flywheel, stock Vanagon clutch disk, and a VR6 pressure plate. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Wed Oct 04, 2023 7:26 am Post subject: Re: Clutch/Flywheel for 1.8T Engine Swap |
This is a pretty informative thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
I have since upgraded to a Dual Mass Setup and would make you a deal on the low mileage Single Mass Setup I removed. Read through the thread I linked. If you want to use the TDI disk, Christopher at T3 used to sell the beefier input shaft. It’s the correct length and easy to install while you are swapping the bell housing. _________________ ☮️ |
