Rear Disc Brake Conversion - seen conflicting answers
Sofia74
Sofia74 is offline
PostPosted: Mon Oct 09, 2017 1:58 pm    Post subject: Rear Disc Brake Conversion - seen conflicting answers Reply with quote
Yes, I know this has been covered and I have read many posts but I wanted to verify a couple things since I have read some answers or opinions that seem to conflict.
Looking at CB Performance rear disc brake conversion with parking brake for a 1974 KG Coupe. Plan is to keep the front discs and add discs to the rear.
My questions:
1. What master cylinder? I will be getting a new one – stock size or go the larger 20.6 mm as I have seen recommended?
2. Do I need a Residual pressure valve? The CB Performance website says: "Vehicles with four wheel disc brakes using a 67-later master cylinder are recommended to install a 4 lb. Residual Pressure Valve." I have seen other answers on this site that seem to conflict...
3. Wheel bearings? Which to use? I haven’t heard this addressed yet and CB Performance should have a recommendation. Just thought I’d ask since I was here…
Thanks,
Matt
slalombuggy
slalombuggy is offline
PostPosted: Tue Oct 10, 2017 11:25 am    Post subject: Re: Rear Disc Brake Conversion - seen conflicting answers Reply with quote
yes, get the larger master, you will need it to move enough fluid for the larger pistons on all 4 wheels.
Yes put in a valve, it will help keep the pedal firm, you can run without and they will work fine, but the pedal will feel spongy all the time.
I prefer FAG or KOYO bearings, anything but white box cheap stuff.
brad
Lo Cash John
Lo Cash John is offline
PostPosted: Tue Oct 10, 2017 11:53 am    Post subject: Re: Rear Disc Brake Conversion - seen conflicting answers Reply with quote
Click on the link below and about halfway down is another very good option for 4 wheel disc brakes.
http://www.coolrydescustoms.com/coolstop-brakes.html
This MC will work with right hand drive or left hand drive cars since the ports exit upwards.
www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone.
Sofia74
Sofia74 is offline
PostPosted: Tue Oct 10, 2017 3:39 pm    Post subject: Re: Rear Disc Brake Conversion - seen conflicting answers Reply with quote
Slalombuggy - thanks. Any advice on where the best location for the valve?
Also, I try to buy FAG bearings when I can. My dad worked for FAG for years. They might have put me through college. Smile
Lo Cash John - 23.8mm MC, that's a pretty big increase over stock, isn't it. Would that lock up the brakes pretty easily? Too easily?
Matt
Era Vulgaris
Era Vulgaris is offline
PostPosted: Tue Oct 10, 2017 4:42 pm    Post subject: Re: Rear Disc Brake Conversion - seen conflicting answers Reply with quote
Matt
Everything else staying the same, going to a bigger MC will create a stiffer pedal feel, but will actually require more pedal effort to stop the car.
This is a common occurrence on the 914, when people swap the stock 17mm MC for a similar-era 911 19mm MC and keep the stock 914 calipers.
However, the coolrydes brake kits are 4 piston front and 4 piston rear (stock VW are 2 piston front), so you'll need a sizable increase in MC to accommodate that.
Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Oct 10, 2017 5:16 pm    Post subject: Re: Rear Disc Brake Conversion - seen conflicting answers Reply with quote
Don't waste your money. 70% of braking is done by the front and adding rear disc is not needed.
Glenn
Member #1009
#BlueSquare
CiderGuy
CiderGuy is offline
PostPosted: Tue Oct 10, 2017 5:54 pm    Post subject: Re: Rear Disc Brake Conversion - seen conflicting answers Reply with quote
Agreed, but I thought it was 80%
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything
Era Vulgaris
PostPosted: Wed Oct 11, 2017 6:40 am    Post subject: Re: Rear Disc Brake Conversion - seen conflicting answers Reply with quote
Especially not needed on a car this light! That coolrydes stuff is insane overkill for a stock engine car. I think his stuff is more geared toward people with subaru conversions or high hp motors.
My only temptation for even considering rear discs would be reduced maintenance. Maybe some people don't mind, or possibly might even enjoy, adjusting drums...but if I never had to do it again I definitely wouldn't miss it.
Currently own:
Previously owned:
slalombuggy
PostPosted: Wed Oct 11, 2017 11:08 am    Post subject: Re: Rear Disc Brake Conversion - seen conflicting answers Reply with quote
Matt
Put the valve at the rear before the "T" and it makes for a nice clean install. Put it just off the master if you're worried about access. Either will work.
Once you've gone to 4 wheel disks you'll never go back to drums. At least that's my personal experience on the 3 cars I've built.
brad
jpjohns
jpjohns is offline
PostPosted: Sun Oct 15, 2017 2:39 pm    Post subject: Re: Rear Disc Brake Conversion - seen conflicting answers Reply with quote
Yeah but rear discs look cool as hell! My question is the lug pattern. 4-lug, 5-lug porche or wide 5?
-Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member)
