Mounting a Radio Under The Dash
thefladge
thefladge is offline
PostPosted: Mon Oct 09, 2017 8:10 pm    Post subject: Mounting a Radio Under The Dash Reply with quote
Rather than install an aftermarket radio in the dash, I would like to install it under the dash.
I've seen under dash radio boxes online, but I'm not sure how they will fit the curved shape under the dash.
Anyone have any recommendations? Pictures of your own installations?
Thanks.
1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate.
Hazza6542
Hazza6542 is offline
PostPosted: Mon Oct 09, 2017 11:16 pm    Post subject: Re: Mounting a Radio Under The Dash Reply with quote
How would just screwing a din cage (if that's what they're called) like this go? How clean do you want it installed? Best option would be a retrosound stereo, fits stock location with no cutting. Wiring a stereo under the dash is gunna need more holes for wiring loom or having them exposed running through car.
55 build: https://www.thesamba.com/vw/forum/viewtopic.php?t=680057
thefladge
PostPosted: Sat Jan 13, 2018 12:23 pm    Post subject: Re: Mounting a Radio Under The Dash Reply with quote
I've decided to install a single DIN radio in the dash.
The cutting is underway. Looks like it will be a tight squeeze.
vwbrewer
vwbrewer is offline
PostPosted: Mon Jan 15, 2018 8:56 am    Post subject: Re: Mounting a Radio Under The Dash Reply with quote
This stereo is from a Nissan Figaro, sold only in Japan. A friend had one in his Bug and it looked really nice. You can google it and find many on the internet. https://i.pinimg.com/736x/6d/99/61/6d99613dc956d3ab7b7741ee65907a26.jpg
1957 Oval Rag
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Mon Jan 15, 2018 8:13 pm    Post subject: Re: Mounting a Radio Under The Dash Reply with quote
... guess it's okay to cut a dash for a radio on a baja... others would be making a mistake
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
thefladge
PostPosted: Mon Jan 15, 2018 8:30 pm    Post subject: Re: Mounting a Radio Under The Dash Reply with quote
The original dash behind the aluminum panels was highly hacked by a previous owner in the '70's.
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Mon Jan 15, 2018 10:01 pm    Post subject: Re: Mounting a Radio Under The Dash Reply with quote
Technology has changed so much that I have to wonder why even bother installing any kind of a head unit anymore. Especially if you have to hack the dash!
Install a stock radio and then use a hidden amp and bluetooth connector to your phone.
thefladge
PostPosted: Mon Jan 15, 2018 10:14 pm    Post subject: Re: Mounting a Radio Under The Dash Reply with quote
It goes with the theme of the car. Vintage custom, but not too vintage.
An 8 track player will be mounted under the dash.
