VW Thing generator replacement
hogwildrestorations
hogwildrestorations is offline
PostPosted: Tue Oct 10, 2017 11:14 am    Post subject: VW Thing generator replacement Reply with quote
Do you have to pull the motor to get a generator out of a thing??? any good references anybody, about how to do it? Thanks for any advise
YDBD
YDBD is offline
PostPosted: Tue Oct 10, 2017 12:21 pm    Post subject: Re: VW Thing generator replacement Reply with quote
It can be a tight squeeze, but I think it can be done.
Take of the carb and the distributor for extra work room. Take the screws out ot the side of the fan shroud, loosen the strap around the generator and push it forward.
The whole thing should lift up about an inch and you can try to tilt and wiggle it out.
If it won't fit, you can take out the four bolts that hold the fan in the shroud, push the shroud forward as far as possible after lifting out of the cylinder tin and pull the fan and generator toward the rear of the car.
Still won't come out...remove the generator stand and the intake manifold...should be easy then.
Best to have a helper...
'56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing"
Wildthings
Wildthings is offline
PostPosted: Tue Oct 10, 2017 1:06 pm    Post subject: Re: VW Thing generator replacement Reply with quote
You can pull a generator by reach around to the front of the fan shroud and removing the nut that holds the fan to the generator the generator can then be pulled away from the fan shroud. Maybe this would work with an alternator as well? If you do this don't drop any parts and make sure you get the washer back on correctly when you put things back together.
hogwildrestorations
PostPosted: Tue Oct 10, 2017 2:48 pm    Post subject: Re: VW Thing generator replacement Reply with quote
Thanks for the help goning to tackle it in the morning appreciate the help!!
YDBD
YDBD is offline
PostPosted: Tue Oct 10, 2017 8:21 pm    Post subject: Re: VW Thing generator replacement Reply with quote
Yes you can do this too, but I find it hard to get the 36mm socket on with a breaker bar to get enough leverage on the bolt in that much space.
Wait...drill a hole through the firewall so you can put an extension on and just work from inside the car....just kidding...
'67 bug
'64 baja
'60 dune buggy
Zylinderkopf
Zylinderkopf is offline
PostPosted: Wed Oct 11, 2017 1:47 am    Post subject: Re: VW Thing generator replacement Reply with quote
Here is a video on how to do it with engine in. I have done this on my beetles, but I’m not sure if this works on a Thing, since it’s more difficult to reach behind the fan shroud.
https://youtu.be/4ewXkdPgsa4
Good luck and please keep us updated.
1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to."
Semper_Dad
Semper_Dad is offline
PostPosted: Wed Oct 11, 2017 8:09 am    Post subject: Re: VW Thing generator replacement Reply with quote
I've done it. Kind of made it up as I went along. Generator to generator replacement. Not sure what it would be like if an alternator was involved. I do remember removing the carburetor for more clearance. Got the 36MM fan nut off by using a breaker bar on the back and turning the generator shaft. I was afraid the shaft would break, but it didn't.
There will be some shims and a wavy washer behind the fan nut. Make a note of their configuration. There's a fan to shroud clearance that needs to be set using those washers. I used a camera afterward to check the clearance.
Good luck
This old (and searchable) thread will might help
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
