Area 351 Samba Member
Joined: October 10, 2017 Posts: 6 Location: Kingston, Pa
Posted: Tue Oct 10, 2017 7:24 pm Post subject: Thing spindles on a Type 1 |
Thing spindles on a Type 1?
I know this is a common swap and I was able to score a set of Thing spindles today locally for $150.
I've heard that you run Type 1 ball joints on top, Thing ball joints on the bottom and swap lower trailing arms side to side.
I've also heard that you should swap the torsion bar 180° so that the grub screws are correctly oriented.
I've also read online that you have to grind the lower trailing arms slightly for the Thing ball joints, and some people say not to run the Type 1 trailing arms because no matter what, it messes up the geometry of the lower ball joint.
I've looked everywhere and can't find any info on modifying the trailing arm for the Thing ball joints.
Can anyone shed some first hand experience with me here? |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Wed Oct 11, 2017 5:50 am Post subject: Re: Thing spindles on a Type 1 |
The lip on the thing balljoint is bigger than type 1. I just ground down the lip so it fit inside the bug trailing arms. No mods to my type 1 arms, other than lowers swapped side to side, don't need to mess with the torsions. _________________ foam cowboy hats aren't good helmets. |
pullstart Samba Member
Joined: August 23, 2016 Posts: 599 Location: Middleville, MI
Posted: Wed Oct 11, 2017 6:02 am Post subject: Re: Thing spindles on a Type 1 |
Though I've not done Thing spindles, I'll second the torsions staying put. The grub screw holes are in line on the side of the spring pack. _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
my build page: https://www.thesamba.com/vw/forum/viewtopic.php?t=662104&start=0 |
