ihfarmer3339 Samba Member
Joined: December 11, 2016 Posts: 34 Location: Indiana
Posted: Sun Dec 11, 2016 12:04 pm Post subject: VW Shorty Project |
I just bought a 59'? vw shorty bus out of a cow lot for very cheap! The car is missing an engine but I have an old 1600 cc engine out of a 72' super beetle. Is this engine compatible to be mounted onto this transaxle? I am new to VW type 2's (restored the super beetle) but I really think this will be a great little car to put around in! Thanks! |
HeidelbergJohn4.0 Samba Member
Joined: March 01, 2004 Posts: 1199 Location: Havre de Grace, MD
Posted: Sun Dec 11, 2016 6:35 pm Post subject: Re: VW Shorty Project |
it will depend on what clutch and flywheel is on the motor. _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.) |
Posted: Mon Dec 12, 2016 1:32 pm Post subject: Re: VW Shorty Project |
So I just need to get a flywheel that will fit in the bell housing of the transaxle? Is the bolt pattern for the engine and bell house, the same? |
Posted: Tue Dec 13, 2016 8:48 am Post subject: Re: VW Shorty Project |
the flywheel, clutch pressure plate, etc needs to all be compatible. The starter also has to match up. then there is the 6v vs 12v. _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
Posted: Tue Dec 13, 2016 12:46 pm Post subject: Re: VW Shorty Project |
This car doesn't have any wiring in it, got ripped out years ago, before I bought it. So I'm definitely building it 12v, the engine I'm wanting to use is also 12v. Thanks everyone! I'm excited to get started! I'll probably match the engine and all after I finish the transaxle rebuild. |
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Tue Dec 13, 2016 12:49 pm Post subject: Re: VW Shorty Project |
Pictures? _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Posted: Tue Dec 13, 2016 12:50 pm Post subject: Re: VW Shorty Project |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Tue Dec 13, 2016 1:22 pm Post subject: Re: VW Shorty Project |
Wire harnesses are available from many sources. If you will drive this thing on the street you are going to have to do it all. Wiring Works has a good rep with many folks here.
There are a number of good threads about 6volt/12volt engine & trans combinations if you do a search on the Split Bus forum.
What is the current problem with the trans? _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
Posted: Tue Dec 13, 2016 2:00 pm Post subject: Re: VW Shorty Project |
The input shaft bearing is locked up, and the whole thing just needs to be cleaned up and fresh oil and seals in it. I opened it up, all the gears are in good shape, everything is tight I just need to replace the input shaft bearing, and clean everything up inside! |
buggerdman Samba Member
Posted: Mon Oct 16, 2017 12:55 pm Post subject: Re: VW Shorty Project |
that looks like a wild little project! keep us posted |
