BrokeBus23 Samba Member
Joined: February 25, 2016 Posts: 8 Location: Virginia
Posted: Thu Oct 12, 2017 1:43 pm Post subject: Pros and cons of pop rivets? |
My spouse has a '74 Westy that we are having fixed up. From my research pop rivets (NOT aircraft grade rivets) seem to be okay for fixing small patches but I cannot seem to find anything about entire panels, such as the front end, corners, etc. Long term speaking is this bad or good? We are having it done to remove the rust but will this "fix" only end up rusting in the near future?
*sorry for the confusion, the person fixing it up won't be welding the panels on.
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Thu Oct 12, 2017 1:58 pm Post subject: Re: Pros and cons of pop rivets? |
I use clamps because they are faster than drilling the holes and filling them after the panel is welded. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Thu Oct 12, 2017 2:06 pm Post subject: Re: Pros and cons of pop rivets? |
The person doing this for us is not planning on welding... |
Posted: Thu Oct 12, 2017 2:25 pm Post subject: Re: Pros and cons of pop rivets? |
This is what has been done so far.
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Thu Oct 12, 2017 3:12 pm Post subject: Re: Pros and cons of pop rivets? |
BrokeBus23 wrote: |
Do yourself a huge favor, find someone else to repair your vehicle. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
anthracitedub Samba Member
Posted: Thu Oct 12, 2017 3:14 pm Post subject: Re: Pros and cons of pop rivets? |
This is not a lasting repair... you'll be paying to have it done again in a few years. These types of repairs should be done with proper welding and metal finishing and then proper treatment/sealing of the areas before being pAinted. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4523 Location: Oklahoma City, OK
Posted: Thu Oct 12, 2017 3:55 pm Post subject: Re: Pros and cons of pop rivets? |
Rivets are okay for holding till welded, Cleco Fasteners are better for they are easy to put in and remove. The problem with pop rivets is eventually there will be vibration, the body filler will crack and or bond loosen allowing moisure to get in then rust.
Do it right once, or continue to pay. |
Posted: Thu Oct 12, 2017 4:24 pm Post subject: Re: Pros and cons of pop rivets? |
Thank you for the replies and we'll be looking for someone to weld her up. |
Sloride Samba Member
67ctbug Samba Member
Posted: Thu Oct 12, 2017 4:43 pm Post subject: Re: Pros and cons of pop rivets? |
Sloride wrote: |
Please don't tell us you are paying someone to do this work. I'd be removing all of that filler and fixing it properly. Rivets or not try at least to preserve the body lines. |
This...
I wouldn't pay a dime to have someone rivet and bondo on a repair panel. Pop rivets are for holding on the panel until you weld... not holding the panel on long term. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Canadian VW Samba Member
Joined: August 24, 2007 Posts: 220 Location: Ontario Canada
marklee Samba Member
Joined: March 24, 2009 Posts: 821 Location: Flintshire, North Wales
Posted: Sun Nov 05, 2017 2:49 pm Post subject: Re: Pros and cons of pop rivets? |
pop rivets are aluminium. They have a steel shank. When used in steel bodies the dissimilar metals will react with each other and actually promote corrosion. Do the job right, do it once... _________________ CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver |
