Emergency brake cable install / shortening
Buzzfagan
Buzzfagan is offline
PostPosted: Fri Oct 13, 2017 5:34 am    Post subject: Emergency brake cable install / shortening Reply with quote
Installing the emergency brake cables on my Manx build and need to cut the cables and install the cable shortening kit. How do I know where to make the cut/determine how much to shorten it?
And specifically ow do you do the install/adjustment/tightening?
For example with the handle up/down/somewhere in the middle?
How tight do you make it?
Anything else I should know? I have looked all over and can't seem to find a step by step with photos or a video. Any help would be great. Thank you!
heywebonya
heywebonya is offline
PostPosted: Fri Oct 13, 2017 7:38 am    Post subject: Re: Emergency brake cable install / shortening Reply with quote
Have you considered trying to use the search function? These are pretty simple questions that you have now made a new thread about to confuse searches?
Bummer
If I knew what I was doing; I wouldn't be building a buggy!
Buzzfagan
PostPosted: Fri Oct 13, 2017 7:43 am    Post subject: Re: Emergency brake cable install / shortening Reply with quote
Wow thanks for your input that was really helpful. As I stated in my post I have searched and cannot find the answer I am looking for. That is why I asked. Pretty sure that is what a forum is for. If you don't want to respond and help then don't. It's not an obligation.
Bummer
Sharp64
Sharp64 is offline
PostPosted: Fri Oct 13, 2017 7:56 am    Post subject: Re: Emergency brake cable install / shortening Reply with quote
https://www.thesamba.com/vw/forum/search.php?searc...=titleonly
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
heywebonya
PostPosted: Sun Oct 15, 2017 5:58 pm    Post subject: Re: Emergency brake cable install / shortening Reply with quote
Yep.
