Buzzfagan Samba Member
Joined: April 03, 2016 Posts: 102 Location: Georgetown,Texas
Posted: Fri Oct 13, 2017 5:45 am Post subject: Shorten clutch cable |
How do you shorten the clutch cable on a Manx build?
Any tips or trick on installing and adjusting the Bowden tube and the cable tightness and the clutch pedal play? |
jspbtown Samba Member
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sat Oct 14, 2017 8:26 pm Post subject: Re: Shorten clutch cable |
Here is an easy and reliable way.
Get three cable clamps from your local "Ace Is The Place" Store and cut the cable in the middle between the clutch throwout arm and bowden tube.
Clamp the cables together and cut off the excess cable after you have it positioned correctly and all readjusted.
Here is a pic of what it looks like when done.
This has worked for 13 years and almost 60,000 miles for me.
It's easy and cheap. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
EVfun Samba Member
Posted: Sun Oct 15, 2017 7:51 am Post subject: Re: Shorten clutch cable |
My method is similar to Clonebug. I use 2 split ground bolts instead of cable clamps and put the splice close to the threaded end. _________________
Wildthings wrote: |
mr_bill Samba Member
Joined: February 19, 2006 Posts: 1008 Location: City of Orange, CA
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Wed Oct 18, 2017 3:30 pm Post subject: Re: Shorten clutch cable |
Use heat shrink tubing on the ends of the cable so they don't fray and come unwound. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
bigfatloser Samba Member
Joined: July 27, 2014 Posts: 94 Location: High Desert Calif
Posted: Wed Oct 18, 2017 4:51 pm Post subject: Re: Shorten clutch cable |
I had mine cut, shortened the same length as the pan was, and a new threaded end crimped back on. Fortunately, Terrycable.com is but miles from me, but most hydraulic fitting and hose places can re-crimp cable ends. At least the ones I called locally here in So. Calif. _________________ DMZFAB.COM |
