Rear Footwell Heating System
FL-Frank
FL-Frank is offline
PostPosted: Tue Sep 04, 2018 6:36 am    Post subject: Rear Footwell Heating System Reply with quote
The rear footwell heating system in my ‘64 coupe is obviously missing some parts. The metal tubes under the rear seat bench are there, and the oulet holes in the kick panel are there, however, whatever connects the metal tubes to the holes with whatever type of open/close valve is missing.
Can someone please provide details, pictures, etc. of the missing parts?
“Tinker Toy” 1967 Savannah Beige Beetle Sedan...........Mostly Original Survivor
“Fritz” 1964 Gulf Blue Karmann Ghia Coupe...Complete Pan-Off Restoration SOLD
sputnick60
sputnick60 is offline
PostPosted: Tue Sep 04, 2018 8:10 am    Post subject: Re: Rear Footwell Heating System Reply with quote
This is from my '66 which has mostly the same set up.
If you look inside you can see the flap that clips to the centre pin.
Under the back seat there is a small tube entering the tunnel that leads a bowden wire to the emergency brake. I have better photos .. but can't find them right now.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
2014 Passat B7 130TDI wagon (cheats in tests)
"Have no fear of perfection - you'll never reach it."(Salvador Dali)
FL-Frank
FL-Frank is offline
PostPosted: Tue Sep 04, 2018 8:28 am    Post subject: Re: Rear Footwell Heating System Reply with quote
Nicholas
Thanks! I believe the outlet in your picture is probably the same outlet my car should have. I just checked, and the sheet metal has two small holes on either side of the large outlet hole...likely there to accommodate the two screws holding the outlet in place as in your picture.
Wondering if the flap is manually opened/closed, or is it done remotely by cable?
bhartwell59
bhartwell59 is offline
PostPosted: Tue Sep 04, 2018 8:32 am    Post subject: Re: Rear Footwell Heating System Reply with quote
Via cables... controls located by your e-/parking brake handle
'74 Zambezi green Ghia vert, auto stick, 91k
'87 Jeep Wrangler, 4.2, 321k
crocteau
crocteau is offline
PostPosted: Tue Sep 04, 2018 11:32 am    Post subject: Re: Rear Footwell Heating System Reply with quote
This photo was recently posted here, and it shows another view that may help you.
c705ncp
c705ncp is offline
PostPosted: Tue Sep 04, 2018 11:47 am    Post subject: Re: Rear Footwell Heating System Reply with quote
I have a 73 Ghia and have blanked the rear heater outlets off. What a difference it make to heat coming through to footwell and screen.
Robert
FL-Frank
FL-Frank is offline
PostPosted: Tue Sep 04, 2018 1:28 pm    Post subject: Re: Rear Footwell Heating System Reply with quote
My car definitely does not have what looks in this picture to be a bowden tube with a cable going into it.
And, it looks like there is a second tube slip fitted inside the lip of the main underseat steel tube.
advCo
advCo is offline
PostPosted: Tue Sep 04, 2018 1:50 pm    Post subject: Re: Rear Footwell Heating System Reply with quote
I don't have any great pics of the area on hand but here's one from my '70 (may it rest in pieces)
it looks like the cable housing design remained largely the same throughout the 60s+ although I know the Y heat exchanges changed design.
I just picked up a pre-70 donor that actually has an extra rear cross member with the bowden tubes, I can snap some pics later. If you need the parts, send me a PM and we can work something out.
"He pulled the mirrors off his Cadillac ‘cause he doesn’t like it looking like he looks back"
'68/'70 Ghia Coupe Project
'70 Westy Project - Champagne I Wannabe
A bunch of vintage Japanese motorcycles
"Much ingenuity with a little money is vastly more profitable and amusing than much money without ingenuity." -A. Bennett
Era Vulgaris
Era Vulgaris is offline
PostPosted: Wed Sep 05, 2018 8:17 am    Post subject: Re: Rear Footwell Heating System Reply with quote
Robert
Your controls and vent openings are different in '73. The 60's cars have one heat lever to turn heat on (open the flapper valves on the heat exchangers), and one lever to open the rear footwell vents. With the small front footwell vents that 60's cars have, being able to open the rear footwell vents allows a massive amount of MORE heat into the car. They are essential for the older cars if you want to stay warm.
1966 Karmann Ghia, under construction
1998 Porsche Boxster, silver, 2.5L overhauled by Jake Raby SOLD!
1967 Karmann Ghia, Black, 1500sp, 4 lug steelies SOLD!
1998 BMW Z3, Atlanta Blue Metallic, 2.8L I-6, 17" factory wheels SOLD!
1975 Porsche 914, Laguna Blue, 2270cc DRLA40's, 5 lug fuchs SOLD!
1972 Porsche 914, Signal Orange, 1.7 FI, 5 lug fuchs SOLD!
1974 Karmann Ghia, Black, 1600dp, bullet turn signals, steelies SOLD!
1974 Triumph TR6 with O.D., metallic blue, stock everything SOLD!
Era Vulgaris
PostPosted: Wed Sep 05, 2018 8:25 am    Post subject: Re: Rear Footwell Heating System Reply with quote
If it helps here are pics of both sides from my old '67
FL-Frank
FL-Frank is offline
PostPosted: Wed Sep 05, 2018 8:35 am    Post subject: Re: Rear Footwell Heating System Reply with quote
Found these on here...guess I can start with these Very Happy
https://www.thesamba.com/vw/classifieds/detail.php?id=2142669
Looks like I also need to find the short pipes that slip fit onto the main pipe under the seat. It appears this short pipe (guesstimating about 3” in length) has a flapper mechanism inside of it that opens and closes, correct? Anyone know what this short pipe/flapper assembly is called? And would the same pipe/flapper assembly have been used on bugs from the early to mid 60’s?
crocteau
crocteau is offline
PostPosted: Wed Sep 05, 2018 4:52 pm    Post subject: Re: Rear Footwell Heating System Reply with quote
FL-Frank wrote:
...It appears this short pipe (guesstimating about 3” in length) has a flapper mechanism inside of it that opens and closes, correct? Anyone know what this short pipe/flapper assembly is called? And would the same pipe/flapper assembly have been used on bugs from the early to mid 60’s?
My '66 Beetle has a very similar setup: flapper valves ganged to the control lever beside the emergency brake lever using solid wire cables running through metal bowden tubes. The key differences are that the partition under the front edge of the '66 Beetle rear seat bottom is fiberboard, the bowden tubes are welded to the pan, and the outlet collars are plastic. Also, the bowden tubes on the '66 Beetle are straighter than those on my '71 Ghia. Just eyeballing it I'd say these parts from a Beetle should be readily adaptable to your Ghia with some minor adjustments.
Redlabel6
Redlabel6 is offline
PostPosted: Thu Sep 06, 2018 5:51 am    Post subject: Re: Rear Footwell Heating System Reply with quote
On my '73, the short vertical pipes are welded in. The flappers have a spring clip for lack of a better word, they snap onto the vertical.
I'll try to find them in my parts bag tonight and take a picture.
d
1973 Karmann Ghia Coupe
2005 Passat TDI
2005 Jetta
