Spray Adhesive Nightmare!
Page: Previous  1, 2
birdmanp
birdmanp is offline
PostPosted: Mon Oct 16, 2017 4:55 pm    Post subject: Re: Spray Adhesive Nightmare! Reply with quote
GOOD NEWS - Gasoline definitely works! I spot treated a place on one of the rear wheel wells, and with a little elbow grease, a shop rag, and a splash of fresh gas, the glue came off. I am thinking a spray bottle and a nylon brush will be my friend on the areas I am wanting to remove the glue. What is covered or will be covered I will leave alone.
'71 Bus (ex weekender someone stripped - in process of converting to "8" passenger)
Millwright/Rigging comes natural to me. I guess I am just used to fitting big things in small places.
Clarkson Industrial Contractors
vwjetboat
vwjetboat is offline
PostPosted: Mon Oct 16, 2017 5:03 pm    Post subject: Re: Spray Adhesive Nightmare! Reply with quote
gas in a spray bottle ? umm maybe a squirt bottle.. but in spray bottle it becomes instant flash bomb if any ANY ignition source is near.. Glad ya got it figured out ...
TomC Premium Member
TomC is offline
PostPosted: Tue Oct 17, 2017 11:31 am    Post subject: Re: Spray Adhesive Nightmare! Reply with quote
Excellent news! My technique was to pour gas on a paper towel and wash an area with it. Then go back and scrub. The adhesive will be soft by the time you get scrubbing. Lots of paper towels. Your fingers end up very sticky with adhesive.
I found that with the bus fully open on a nice warm day, all of the smell was gone in a few hours.
Naturally, be very very careful with flames and sparks while you're working. Perhaps disconnecting the battery would be prudent.
Good luck, and post the results!
Tom C
77 Westy
72 Beetle Convertible
olo
olo is offline
PostPosted: Tue Oct 17, 2017 1:25 pm    Post subject: Re: Spray Adhesive Nightmare! Reply with quote
Spray Carburettor cleaner
, wait a minute to soften the glue, apply heavy duty dishwashing liquid over (eg Jif in oz) and scrub with harsh dish sponge
airkooledchris
airkooledchris is offline
PostPosted: Tue Oct 17, 2017 1:28 pm    Post subject: Re: Spray Adhesive Nightmare! Reply with quote
GUMOUT carb cleaner works wonders, but id be careful of paint that you don't want thinned in the process.
notchboy
notchboy is offline
PostPosted: Tue Oct 17, 2017 3:02 pm    Post subject: Re: Spray Adhesive Nightmare! Reply with quote
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
SGKent Premium Member
SGKent is offline
PostPosted: Tue Oct 17, 2017 5:19 pm    Post subject: Re: Spray Adhesive Nightmare! Reply with quote
This is the best I could find on working with gasoline. The fumes are heavier than air so if you can't smell them that doesn't mean anything, especially with how noses adapt to smell. I would be inclined to try using kerosene or diesel to see if it works before gasoline - and leave it open in the hot sun for a week or more when you are done. Maybe hose down with soap and water if you want it before then. One stupid move and being burned isn't worth the time it saves. We have one member here who was very badly burned and thrown quite a distance in an explosion from solvent fumes on a job site by an error in someone else's judgement. We don't need another or a funeral. Frankly, and not meaning any disrespect but the arrogance of many people and indifference to following safety rules is killing the rest of us - physically and financially.
One gallon of gasoline can vaporize and fill a 250-gallon fuel tank with explosive vapor; that single gallon of gasoline has the explosive energy of 83 sticks of dynamite.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
notchboy
notchboy is offline
PostPosted: Tue Oct 17, 2017 6:17 pm    Post subject: Re: Spray Adhesive Nightmare! Reply with quote
How about this?
1964 1500 S
skills@eurocarsplus
Samba Peckerhead
PostPosted: Tue Oct 17, 2017 9:13 pm    Post subject: Re: Spray Adhesive Nightmare! Reply with quote
spray inside of bus with gas. let soak. ball up rags and drop match. glue will burn off. problem solved
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Abscate
Abscate is offline
PostPosted: Wed Oct 18, 2017 1:34 am    Post subject: Re: Spray Adhesive Nightmare! Reply with quote
Nitrile gioves will keep the nasties out of your bloodstream when working with gas, viton is even better but $$$
Work in small areas with small amounts of gas at a time, less than 100 mL
No smoking, sparks, flames or electrical stuff going on nearby.
.ssS!
Clatter
Clatter is offline
PostPosted: Wed Oct 18, 2017 7:10 pm    Post subject: Re: Spray Adhesive Nightmare! Reply with quote
Oh, come ON!!
Where's the drama in that?
We love drama on this forum!
Back in the old days people used gas all the time, and it even had *gasp* Lead in it!! Shocked
And they didn't even use gloves!! Shocked Shocked
Rolling Eyes
Bus Motor Build
What’s That Noise?!?
Page: Previous  1, 2
Page 2 of 2
