Tcash Samba Member
Posted: Sat Oct 14, 2017 5:06 pm Post subject: Re: Discouraged New Bus Owner |
Welcome to TheSamba, Bay Window Bus Forum!
73-79 NEWBIE
Tcash wrote: |
Every Type IV engine owner should know this!!!
If you over tighten the Oil Strainer bolt, you will brake the engine case!
There is a Oil strainer in there.
TORQUE THE STRAINER BOLT TO NO MORE THAN 9 FT. LBS. |
Gregg in the 603 Samba Member
Joined: April 13, 2013 Posts: 404 Location: New Hampshire, USA
Posted: Sat Oct 14, 2017 5:08 pm Post subject: Re: Discouraged New Bus Owner |
Quote: |
spent about six months paying to get it in working order from a local mechanic.
For six months time and who knows how much money, your mechanic didn't sort it out? _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Tcash Samba Member
VW.parrothead Samba Member
Posted: Sat Oct 14, 2017 5:41 pm Post subject: Re: Discouraged New Bus Owner |
Welcome! I sent you a PM. _________________ 1970 Tin Top Westy |
Manfred58sc Samba Member
Posted: Sat Oct 14, 2017 7:34 pm Post subject: Re: Discouraged New Bus Owner |
Lots of good Colorado VW folk, we even have our own thread. PM if you need service help.. _________________ Fat chick owner/operator |
Oilspot11 Samba Member
Joined: July 31, 2014 Posts: 135 Location: Green Mountain Falls, Colorado
Posted: Sun Oct 15, 2017 8:51 am Post subject: Re: Discouraged New Bus Owner |
So true. Elbows, wrists, whatever knock stuff off when doing various tasks.
Take some pictures before working. Remove various parts in a controlled fashion that make your access easier. Then you can refer to the pics when replacing. |
WendyArmbuster Samba Member
Joined: March 03, 2006 Posts: 330 Location: Springfield, MO
Posted: Sun Oct 15, 2017 12:42 pm Post subject: Re: Discouraged New Bus Owner |
I will say that getting all of the hoses hooked up correctly is vitally important. In my ignorance when I first owned my bus the hoses were hooked up wrong or just left disconnected, and I had many major problems because of it. Even just recently I got my charcoal canister working properly, and it solved more issues. Perfect hoses are important. Even now I think my brake booster is leaking, and that's an engine hose too.
You said, "We are so frustrated, we've barely been able to enjoy this beautiful machine." I would like to point out that picking a socket out of the engine tin IS enjoying your bus. That's what owning a bus is. Over the long term I would say I spend 15 minutes of maintenance for every hour I spend driving. Right now my bus is running strong and reliable, but there is some rust work on the horizon, and I need to go through my windshield wiper system. My turn signal lever doesn't reset when I straighten the wheel. I want to install retractable seat belts. The passenger window crank just broke the other day. By the time I get these things fixed, there will be an entirely new list. It never goes away, and you have to be ok with that. _________________ Brian Z
1978 Westfalia |
cmonSTART Samba Member
Posted: Sun Oct 15, 2017 12:55 pm Post subject: Re: Discouraged New Bus Owner |
WendyArmbuster wrote: |
You said, "We are so frustrated, we've barely been able to enjoy this beautiful machine." I would like to point out that picking a socket out of the engine tin IS enjoying your bus. That's what owning a bus is. Over the long term I would say I spend 15 minutes of maintenance for every hour I spend driving. Right now my bus is running strong and reliable, but there is some rust work on the horizon, and I need to go through my windshield wiper system. My turn signal lever doesn't reset when I straighten the wheel. I want to install retractable seat belts. The passenger window crank just broke the other day. By the time I get these things fixed, there will be an entirely new list. It never goes away, and you have to be ok with that. |
Yup, completely agree. Embrace it, because that's what owning a 40 year old vehicle means.. _________________ '78 Bus 2.0FI
de K1IGS |
stwesty Samba Member
Joined: May 10, 2015 Posts: 128 Location: Vancouver, Canada
Posted: Sun Oct 15, 2017 1:17 pm Post subject: Re: Discouraged New Bus Owner |
Don't get discouraged and just tackle one job at a time. You'll gradually build up your knowledge base subsystem by subsystem. When you're done your current hose issue you'll know just enough about the emissions subsystem to at least know what the major parts of it are next time you dive into the engine bay. Don't expect to understand it all at once.
FWIW, I purchased my bus two years ago an at the time would have had trouble pointing out the carb from the transmission. Today I did my first full engine removal.
The hardest thing at first for complete newcomers to vehicle repair can be the terminology. You'll get a helpful answer on the samba but that results in looking up more terms and soon you're down a rathole.
A few tips for navigating the terminology:
- Bookmark the major diagrams in the Bentley guide and so you can scan the list of items for terms
- Get catalogs from the major parts vendors, their diagrams can also be useful
- Search google for the term using "site:thesamba.com searchterm bus" and then click on the images tab
- That bag of links Tcash posts to welcome newcomers? They are gold. Notice they are stickied at the top of this forum. Use 'em.
- Post to the also stickied Stupid Questions thread. It is great for quick answers on stuff. _________________ 1974 Westfalia, automatic, dual-carb |
allenw Samba Member
Joined: September 20, 2016 Posts: 221 Location: Dalton, GA
Posted: Sun Oct 15, 2017 2:31 pm Post subject: Re: Discouraged New Bus Owner |
I understand your pain although I do not own a bus, I have a 74 SB bug. I had 2 choices when I was searching local for a bug, I bought the one I could drive home. I should of bought the one I needed to have towed home. It had new pans installed but had the rest of the parts were in the inside of the bug. It would of taken less time to put all the parts back on then the one I drove home for the same price. The one I bought had mass electrical problems the brakes barely stopped the car form 20 MPH. no lights worked , the wiring harness was hacked bad. Then when I went to replace the engine compartment seals found out the rear clip had been hit and was tweaked which means i have to cut off and replace the entire read clip. It sat in my driveway for over 6 months before I could drive it everyday. i have still not done the need body and rust repair yet but I can drive it to work all week. |
timvw7476 Samba Member
Posted: Sun Oct 15, 2017 4:50 pm Post subject: Re: Discouraged New Bus Owner |
Picking the right spark plug socket is critical, get one that is magnetic.
Also get a telescopic magnet, for when things get lost in the sparkplug tin holes.
Buying those saves your sanity. You will now laugh when stuff 'disappears',
might even find an old plug or two that you didn't drop in there. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sun Oct 15, 2017 5:49 pm Post subject: Re: Discouraged New Bus Owner |
timvw7476 wrote: |
Buying those saves your sanity. |
ALSO- duct tape the socket to the extension- and squirt silicone on/in the plug socket. No more fun can be had than having the socket stick to the plug when you withdraw the extension. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Rider_Surfboards Samba Member
Joined: April 16, 2015 Posts: 69 Location: New Jersey
Posted: Sun Oct 15, 2017 6:17 pm Post subject: Re: Discouraged New Bus Owner |
Welcome to the world of air-cooled VWs! My advice--stick with it and learn to laugh at the setbacks. After all, if you're not having fun with it, then why do it at all, right?
I came into this two and a half years ago knowing next to nothing. Now I can drive 1K mile round trips with the confidence of knowing I can fix most of the things that could go wrong on the road. Between myself and my two friends who have buses, I've dropped an engine at least 8 times, replaced transmissions, adjusted torsion bars, brakes, electrical, configured carburetors, disassembled and adjusted distributors, and tonnns of other fun stuff. You need to be willing to get your hands dirty and make mistakes. Before you know it, you'll go from simply changing your oil to replacing your main seal--hopefully not anytime soon though
I'll always offer support and of course pitch in with advice when I can, as most people here will as well.
Have fun!
--Kevin _________________ 1979 Bus Weekender -- Gertrude McBus |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
yellowCOwesty Samba Member
Joined: April 16, 2016 Posts: 97 Location: Rocky Mountains
Posted: Mon Oct 16, 2017 9:14 pm Post subject: Re: Discouraged New Bus Owner |
Wherein CO are you? _________________ _______________________
'78 Westy
Currently yellow and white "Sunny"
A few other air cooled VW and Porsches over the years |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Mon Oct 16, 2017 11:04 pm Post subject: Re: Discouraged New Bus Owner |
stwesty wrote: |
FWIW, I purchased my bus two years ago an at the time would have had trouble pointing out the carb from the transmission. Today I did my first full engine removal. |
Well done!! _________________ .ssS! |
vic74westy Samba Member
Joined: December 29, 2010 Posts: 59 Location: Rogue Valley Oregon
