lhenry Samba Member
Posted: Sat Oct 14, 2017 1:13 pm Post subject: Frame/trans horn bolts, extra long? |
'69 bug. I've got a bunch of stuff that is supposed to bolt behind the trans horn bolts. Does any body know of extra long bolts with a similar neck that would work for this purpose? All the brackets use up the threading room on the bolt. Multiple searches have turned up nada.
Thanks in advance |
74 Thing Samba Member
Posted: Sat Oct 14, 2017 2:36 pm Post subject: Re: Frame/trans horn bolts, extra long? |
They are M18x1.5, with a shoulder but I do not remember the length of the stock ones.
You will have to mail order most likely.
There are various lengths and grade bolts available here...
https://www.fastenal.com/products/fasteners/bolts/...ad%22$%7C~ |
widefivebug Samba Member
lhenry Samba Member
Posted: Sun Oct 15, 2017 2:39 pm Post subject: Re: Frame/trans horn bolts, extra long? |
Thanks guys for the leads. Will check them out...
L |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sun Oct 15, 2017 5:11 pm Post subject: Re: Frame/trans horn bolts, extra long? |
lhenry wrote: |
I've got a bunch of stuff that is supposed to bolt behind the trans horn bolts. Does any body know of extra long bolts with a similar neck that would work for this purpose? All the brackets use up the threading room on the bolt. |
What all you you want to attach there? Like a hitch, an under-engine protector???? How much space does that really take up - more than 1/4 inch (6mm) ????
I'll just remind to screw in the big bolts by hand SEVERAL FULL TURNS to reduce chance of crossthreading. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
