ClemTor Samba Member
Posted: Sun Oct 15, 2017 6:19 am Post subject: 1972 alternator bracket help |
Learning what it's supposed to look like. Does the bottom of the bracket bolt to something or just rest there. Mine isn't attached and can't tell if it's rusted away. It is attached on top. |
rusty busty Samba Member
Joined: May 27, 2015 Posts: 310 Location: Vancouver BC
Posted: Sun Oct 15, 2017 7:35 am Post subject: Re: 1972 alternator bracket help |
It's supposed to attach to the heater box and support the exhaust. You can see the bottom of the bracket on the left side of this pic here.
_________________ 1978 CEII Get-away hightop |
Posted: Sun Oct 15, 2017 8:25 am Post subject: Re: 1972 alternator bracket help |
rusty busty wrote: |
Thank you!
Next one: working on the horn all morning. Where does the ground wire from the top horn button go to on the bottom? Inside to? I see a male end on the outside bottom. I have a ground wire from the horn through the floor to this. But when I do that, turn power on, I get constant horn. If I jump from that directly up to horn button, it will beep, only when I push it. That's what I want. But the wire is on the outside. And I can't put the button back on. Lost in electrical. |
Tcash Samba Member
Posted: Sun Oct 15, 2017 10:31 am Post subject: Re: 1972 alternator bracket help |
Horn All |
