Brant258 Samba Member
Posted: Sun Oct 15, 2017 10:39 am Post subject: Single or dual springs |
I'm building a 1835 tw
9.2 to 1 compression
W110
Dual 40 hpmx
69 cw crank
Chromoly pushrods
1.1 rockers
40x35 AA performance heads
Should I run single or dual springs?
Engine will only be revd up to 5800 rpm |
Posted: Sun Oct 15, 2017 10:55 am Post subject: Re: Single or dual springs |
HD singles or Beehives. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Sun Oct 15, 2017 6:59 pm Post subject: Re: Single or dual springs |
Wow! I feel like I'm looking at the specs for a current build! I'd recommend singles, unless you're using all heavy valvetrain parts. Your chromoly pushrods weigh over 80 grams, most likely, whereas stock aluminum weighs ~35 grams. If you have Engle lifters you're likely between 98-110 grams.
Are your AA heads the unported ones? If so, you'll be fine with singles. With porting, you'll engine will be want to rev higher than 6,000 rpm. You should then be running really good, SHIMMED singles or whatever duals. |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Mon Oct 16, 2017 8:33 am Post subject: Re: Single or dual springs |
Brant258 wrote: |
W110
Dual 40 hpmx
69 cw crank
Chromoly pushrods
1.1 rockers
HD singles. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
