heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Mon Oct 16, 2017 5:08 am Post subject: Burro Buggy 2.0 build |
Samba Enthusiasts,
I recently picked up an old school sled and realized that I do not live near the dunes or any recreational area and would need to tow it everywhere. I have decided that making it road legal is the best approach (plus really fun)
Looking around at all the UTVs and RZRs that are around made me realize that they are just short sandrails. I found links to the Burro by Tiny. I took some images and got a few key measurements:
I found a RZR custom top cage that was removed and test fit on the frame.
Now to find some time to keep going.
I just rebuilt a 1600 DP and it runs great.
I am going to replace the pans with 1" x 3" perimeter and widen it to 42".
Any suggestions? _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Mon Oct 16, 2017 3:48 pm Post subject: Re: Burro Buggy 2.0 build |
I always thought the Burro was cool. Would be fun to build one.
What does the wheelbase on yours come out to? _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
pullstart Samba Member
Joined: August 23, 2016 Posts: 599 Location: Middleville, MI
Posted: Tue Oct 17, 2017 4:30 am Post subject: Re: Burro Buggy 2.0 build |
Those back tires and the cage makes it look like a rat/buggy... Need some "Fink" inspiration on it, for sure! _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
my build page: https://www.thesamba.com/vw/forum/viewtopic.php?t=662104&start=0 |
Posted: Tue Oct 17, 2017 5:14 am Post subject: Re: Burro Buggy 2.0 build |
Yes it does! The biggest challenge was deciding whether to build a full cage, that drove the rest of the design. _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Posted: Tue Oct 17, 2017 9:21 am Post subject: Re: Burro Buggy 2.0 build |
If you ever manage to head to Yankee Springs with it, I'll be sure to meet ya for some trail riding fun... _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
dustymojave Samba Member
Posted: Sat Oct 21, 2017 3:34 pm Post subject: Re: Burro Buggy 2.0 build |
Quote: |
If you watch the videos of the 1st 2 Mexican 1000 races (now known as the "Baja 1000") from '67 and '68, you will see Ernie "Elmer" Waring at the finish. A big guy with a big white beard and a big smile. Burro Buggies came VERY CLOSE to winning the 1000 overall. |
1967 1st Mexican 1000 on YouTube:
https://www.youtube.com/watch?v=vpNlLzwxY4U
1968 Mexican 1000 DVD:
https://www.amazon.com/gp/offer-listing/B000A2UBKW...amp;sr=8-1
That roll cage you tried on could be used to build a new cage. By sleeving the connections properly, new A and B pillars could be connected to the bottoms of the ones where it was cut off. Then add rear braces from the top rear corners down to a rear bumper and you would have a complete cage. And you could build that into a structure like a Burro Buggy. Lots of potential for that little buggy.
For offroad use, tires with a more round tread profile would work better with the swing axle. _________________ Richard
SoCalBajas Member
Posted: Sat Oct 28, 2017 2:45 am Post subject: Re: Burro Buggy 2.0 build |
I started to clean up the frame for a new floor and started a smoldering fire in the tunnel because of all the nuts, leaves and other debris. So, I stripped it all down. I always kind of delay the full teardown, but it always happens. I am surprised at what I find.
Lots of stuff
Solid 1" steel steering support ~ 25 lbs
Favorite surprise: frame horns held in by love! Not threaded in, just relying on the add on frame mounts
Had the idea to zip tie the shift rod in place.
The results of stripping a buggy down:
Posted: Sat Oct 28, 2017 2:51 am Post subject: Re: Burro Buggy 2.0 build |
New Frame Build
0.095" 1" x 2" perimeter floor and made the floor 41" wide the whole width.
Started connections to the torsion tubes. Any reason to not connect the pan directly to the tube?
45 degree angle - simple math and plenty of tire clearance
Posted: Thu Nov 16, 2017 6:01 pm Post subject: Re: Burro Buggy 2.0 build |
Had an opportunity to get some welding done today (although I am out of gas, it was flux core).
Finished the floor and tacked the cage together. I should get back to normal welding early next week.
The biggest challenge was positioning the cage roof on top and then inserting the filler pieces. The cage was a CL find that was well built .095 with an aluminum top.
I ended up building a 2"x 12" tower inside to support the roof and then measured several dozen times.
Put a 5 degree downward tilt and the height is 44" inside.
53" wide at the widest part. I forgot how messy flux core welding can be.
Need to start adding more bracing and then the fun bits. _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Posted: Wed Nov 29, 2017 2:26 pm Post subject: Re: Burro Buggy 2.0 build |
Added a front end and mounted seats.
I like how the front end radius matches the roof line; but last night I was thinking how cool sloped front end with a tire mounted would look - kind of like a sportster shape. Too many choices.
Seat mounts were just angle iron drilled and welded in place. There is not much room for adjustment, so I built it for me.
Question: What is the best way to mount the steering wheel shaft? Do I need a special bearing or pillow block? _________________ If I knew what I was doing; I wouldn't be building a buggy! |
It's a play thing Samba Member
Joined: November 19, 2009 Posts: 575 Location: Dayton, Nevada
Posted: Wed Nov 29, 2017 7:49 pm Post subject: Re: Burro Buggy 2.0 build |
Some use the pillow block. _________________ It's not the size of your shop, it's what comes out of it that counts.
I've been playing with my thing ever since I got it... |
tobiism Samba Member
Joined: January 21, 2004 Posts: 502 Location: Chandler AZ
Posted: Wed Nov 29, 2017 10:20 pm Post subject: Re: Burro Buggy 2.0 build |
looking good so far! _________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
Posted: Fri Dec 01, 2017 5:43 am Post subject: Re: Burro Buggy 2.0 build |
Cut off the front end and changed the shape to be more Burro-like
Mounted the steering
Posted: Thu Dec 14, 2017 9:02 am Post subject: Re: Burro Buggy 2.0 build |
Update: Rear cage and hand brake additions
Started to build the rear cage to mount the fuel tank and battery.
I like the flow of the tubing through the pillar. Keeps it nicely aligned. There will be diagonal bracing in the future.
the hardest part was keeping the parts aligned and even
The frame is almost ready for some paint. (need the cut in the hand brake first. Will likely require cutting the tunnel.)
I have been thinking about a hand brake for safety and street legal issues. I was planning on using the surplus Army trailer handbrake, but the challenges of trying to route the cables made me buy a stock VW handbrake.
Any ideas for fuel tank mounting? _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Posted: Sun Dec 17, 2017 5:03 am Post subject: Re: Burro Buggy 2.0 build |
A little paint goes a long way to restoring motivation! I needed to paints some areas in the rear so I can mount the transmission and brake lines.
Paint always makes it look like the plan is coming together!
Posted: Sun Dec 17, 2017 11:05 pm Post subject: Re: Burro Buggy 2.0 build |
coming along nicely! _________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Tue Dec 19, 2017 6:54 pm Post subject: Re: Burro Buggy 2.0 build |
I’d have just restored that buggy to its original glory. Pretty dang cool. _________________ Rides:
300HP 900lb turbo VW rail 18/15 travel
Never ending jeep/rzr hybrid build!
http://www.thesamba.com/vw/forum/viewtopic.php?t=546712 |
SamT Samba Member
Posted: Tue Dec 19, 2017 6:56 pm Post subject: Re: Burro Buggy 2.0 build |
Posted: Thu Jan 04, 2018 2:35 pm Post subject: Re: Burro Buggy 2.0 build |
Update for the buggy - hand brakes and brake lines
Note: I did not restore the buggy to the old school style as there is no where nearby that I can run the buggy. By adding a cage, I can get this street legal.
Before the frame got too heavy I wanted to prime and paint the bottom. I used rattle can undercoating. Worked well on my other buggy, no issues.
Added frame supports for a 12 gallon fuel cell and the battery box.
Painted the cage
I have also replaced the rear bearing covers and seals. Updated the bearing covers from the earlier slinger design to the weep hole design.
Replaced the rear brakes, shortened the hand brake cables and hooked them up.
Mounted the pedals (temporarily since I don't have the clutch cable)
Any suggestions are appreciated! Have a great day _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Posted: Thu Jan 04, 2018 2:49 pm Post subject: Re: Burro Buggy 2.0 build |
Hand brake mounting went well. The hardest part was deciding where to shorten the cable.
