Michael Gross Samba Member
Posted: Mon Oct 16, 2017 4:23 pm Post subject: Figure out what bug is under the kit? |
I recently bought a Bugatti T35 kit, so far loving it but I want to switch to disk brakes and maybe get the thing to handle better. I was wondering how I find out what generation bug parts are at use under the kit.
[/img] |
nelson845 Samba Member
Joined: April 24, 2014 Posts: 59 Location: WASHINGTONVILLE NY 10992
Posted: Mon Oct 16, 2017 4:48 pm Post subject: Re: Figure out what bug is under the kit? |
Ball joint front, irs rear. Is there a vin on the pan? 1968 or later, I believe.
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Mon Oct 16, 2017 4:52 pm Post subject: Re: Figure out what bug is under the kit? |
With the engine completely enclosed without and fresh air louvers or ventilation I'll guess the engine runs hot and will not last very long before it needs a rebuild. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
vwjetboat Samba Member
Posted: Mon Oct 16, 2017 4:55 pm Post subject: Re: Figure out what bug is under the kit? |
very cool looking but have to agree on the running hot with no vents in body.. you look on the wishbone right in the middle were the shifter coupling access is at.. for the vin number of doner bug |
Posted: Mon Oct 16, 2017 6:04 pm Post subject: Re: Figure out what bug is under the kit? |
Thanks so much guys, I'll definitely look into getting some vents/louvers in the back. The cars hasn't been on the road in a long time as far as I can tell, as it has no title, tail lights etc. Bought it for a $1,000 as a fun car to drive while I wrench on my 28 Model A. |
Posted: Mon Oct 16, 2017 6:05 pm Post subject: Re: Figure out what bug is under the kit? |
Michael Gross wrote: |
1k ? you scored.. just for the look factor |
Wetstuff Samba Member
Joined: September 23, 2010 Posts: 700 Location: Maryland
Posted: Tue Oct 17, 2017 9:50 am Post subject: Re: Figure out what bug is under the kit? |
A score for sure ..'cute little hair dryer. I'd probably change out, and fender, the back wheels. Good for you.
Jim _________________ Manx #2614 |
HeidelbergJohn4.0 Samba Member
Joined: March 01, 2004 Posts: 1199 Location: Havre de Grace, MD
Posted: Tue Oct 17, 2017 12:49 pm Post subject: Re: Figure out what bug is under the kit? |
I'd have the front of that thing slammed before the weekend was out. _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.) |
Posted: Tue Oct 17, 2017 1:46 pm Post subject: Re: Figure out what bug is under the kit? |
I plan on changing the tires, would love to slam it. Doing all the research I can, I know zero about VW. |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Tue Oct 17, 2017 4:26 pm Post subject: Re: Figure out what bug is under the kit? |
Based on that wide torsion bar cover, I'm guessing around '72. Most parts are interchangeable.. most ball joint stuff fits all ball joints (though the ball joints themselves can be different sizes). Good score for that money. |
burn-z Samba Member
Posted: Wed Oct 18, 2017 9:28 am Post subject: Re: Figure out what bug is under the kit? |
definitely a good deal. You may want to consider some drop spindles with disks that way you get the disk brakes and you can drop it 2.5 inches at the same time. These guys have some in different bolt patterns. [/url]https://www-cartersaircooled-com.myshopify.com/collections/brake-kits[/url] |
atomicmime Samba Member
Joined: March 30, 2004 Posts: 81 Location: Livermore, CA
Posted: Wed Oct 18, 2017 1:36 pm Post subject: Re: Figure out what bug is under the kit? |
I built a similar Bugatti kit on a '70 chassis, so it has same basic running gear, IRS, ball-joint front, etc. Your front end is obviously very light, by stance and fact that front shocks are at top end of travel. Most people with these kits place about 100 lbs. of weight at the nose, under hood, just behind radiator shell. That works, but better solution is to cut and turn torsion tubes to reduce front end tension and height, use very soft shocks (gas not needed). It will still retain a soft ride, with good handling.
Disc brakes in front is way over-kill. You want brake proportioning to the rear, not better front-end braking. Keep in mind, your seating position is actually behind where the rear seat is in a stock bug! Use a rear disc brake kit if you want, but not front. Get the front end down first, and you'll find it handles well, but still a little light in the front (it'll slide out under hard braking). Rear discs or proportioning valve would help that.
_________________ ---------------------------------
--Patrick--
'69 Meyers Manx (still a project, but not for long!)
'72 Westy
'79 Super Beetle (now electric!)
'13 Beetle |
Posted: Wed Oct 18, 2017 5:46 pm Post subject: Re: Figure out what bug is under the kit? |
^ Killer looking kit there, atomic. I love these things but I don't think I'd fit.. |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Fri Oct 20, 2017 9:19 pm Post subject: Re: Figure out what bug is under the kit? |
What I like about both of these kits is who ever put them together didn't use VW lights, wheels or VW trim of any kind.
If I owned the blue one, I'd loose the fenders, and look at Coker tires Firestone Bias Ply/Pie Crust Tires for the front & Firestone Dirt Track / Grooved Rear tires.
https://www.cokertire.com/tires.html#p=6 _________________ Good Luck
Al |
Posted: Sat Oct 21, 2017 10:21 am Post subject: Re: Figure out what bug is under the kit? |
Took a video of the exhaust today, abosutly love this thing. Needs some carburetor work, and a few other knick knacks.
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Oct 21, 2017 10:51 am Post subject: Re: Figure out what bug is under the kit? |
That exhaust sounds perfect for that style of car! _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Posted: Mon Oct 23, 2017 10:49 am Post subject: Re: Figure out what bug is under the kit? |
I was just about to say that sounds NASTY!!! Love it. _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
SBD Samba Member
Posted: Mon Oct 23, 2017 5:13 pm Post subject: Re: Figure out what bug is under the kit? |
It CACKLES! _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
Bluggy Samba Member
Joined: September 12, 2017 Posts: 151 Location: Caribbean
Posted: Mon Oct 23, 2017 5:28 pm Post subject: Re: Figure out what bug is under the kit? |
I like the look and sound of that..
Thats a nice clean car, man you got a wheel of a deal..pun intended..love those wheels too.
Do you guys have an idea who manufactured that exhaust. I know EMPI made some cannons like that but not sure about the quality.
I am thinking of getting those for my Buggy, some like it and some dont, but since this is a small island, I dont think I will be driving too far for it to become annoying.
I was racing as a young teen so either used to the noise of half deaf by now anyway |
Posted: Tue Oct 24, 2017 5:48 pm Post subject: Re: Figure out what bug is under the kit? |
For those asking about exhaust I took some pictures.
