oil pressure test in non-running 2.1 WBX?
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Tue Oct 17, 2017 9:45 am    Post subject: oil pressure test in non-running 2.1 WBX? Reply with quote
The DoubleCheese parts bus came with no tranny, and the fuel system had been dismantled. I was in no shape to put a tranny in, and recreate the fuel system just to see if I could start it. Now its on the floor of my shop, and I figured I would ask to see if anyone else has come up with a better idea than the one I am going to try.
I have a 091, starter, and the engine. I will give a whirl to see how bolting all that together, removing the spark plugs and see what the starter can spin the engine up to. I have an aftermarket pressure sender I can use.
Is there any point to testing this way? The engine is a complete mystery, but I do see that the floppy head gaskets are a bit cracked. Not sure of when that may have happened (if before it was towed to rest for a few years or during the long nap)
Also on the agenda is a compression test. Now, I know a test should be performed on a warm engine. I have a handful of 500 watt halogen shop lights that I plan to let shine from underneath for a couple hours, that could be warm enough, perhaps, or maybe the Big Buddy.
Suggestions, or more likely, I'd accept ridicule on this notion. I'd just like to find out somehow if the engine is in any way useful before tearing it down to parts.
Regards,
-bobby
MarkWard
MarkWard is offline
PostPosted: Tue Oct 17, 2017 9:55 am    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
No problem doing a compression test on a cold engine. You are looking for even pressures across the engine regardless of temp. That said, for an engine that has been sitting for a long time, unless it was "pickled" properly, is going to have surface rust on the cylinders and the valve seats. Rings will be dry and you probably won't get a good picture of engine condition with your starter rig.
As far as testing the oil pressure, again, you won't learn much from your starter test. Its a 2.1, condition unknown, history unknown, you describe head sealing problems.
I'd say, install the engine and see if you can get it running, or pull the heads, and then pull the cylinders and rods. This is going to give you your best picture of what you have and then you can decide from there.
jberger
jberger is offline
PostPosted: Tue Oct 17, 2017 9:56 am    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
This test will not give you what you need to truly measure oil pressure... which would be full hot under load. You can have amazing cold pressure and very poor hot pressure. I would do a leak down test and if all good, install and run it. Not that big a deal to remove an engine again if need be. And who knows, you may get lucky.
J
PostPosted: Tue Oct 17, 2017 10:33 am    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
J
The leakdown is a good idea. I am nearly certain the big floppy head gasket is bad, but it would be good to see the general condition of the cylinder/head/piston environment before tearing the heads off.
I agree tho, I can't get it up to hot like under load, that is true.
I've never been much good at bottom end rebuilding. Splitting the case, in all my experiences, has been a no-finish deal. Although, those were all due to the condition of the crank, or case. So, I guess I only have bad experiences to go by rather than any other hunches.
djkeev
djkeev is offline
PostPosted: Tue Oct 17, 2017 11:10 am    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
What is your time situation and money situation?
Can you afford to do a top end rebuild of rods rings and heads but know you may need to tear it down if the lower end proves bad?
Idaho Doug had this very thing happen to him.
I on the other hand hit a home run with my top end rebuild. I did have the advantage of information from the PO before I started.
Often if you pull the rods and the crank journal bearings are good, the odds of a solid lower end are quite good.
Dave
Ghia
Vanagon
Beetle
DanHoug
DanHoug is offline
PostPosted: Tue Oct 17, 2017 11:30 am    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
if the engine is on the floor, by all means pull the heads!!!! yes, it means doing #$%#$ exhaust work but if the engine has potential to be good, it's going to need the head seal replaced anyway. just do it.
rent beg borrow buy an acetylene torch to get the exhaust nuts off with. it will greatly reduce the chance of breaking a stud, but even if you do, they are fairly easy to get out with a torch and vise grips so you might end up needing it either way. they'll usually break off at the nut and the stub is still there.
the show stoppers seem to be coolant pipe bolts. those snap close to the heads and are a bugger to get out so take your time on those, use heat and penetrating oil and tapping the bolt head with a hammer.
you don't really need to consider splitting the block. but perhaps think about using it as a core to do a connecting rod/piston rings/head gasket build up. pulling the rods will give you a very good idea of the crank condition and it makes getting the pistons out super easy as they'll stay on the rods using a wobble extension to get to the rod bolts.
-dan
PostPosted: Tue Oct 17, 2017 12:22 pm    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
Dave
The situation there is that The Cosmo rig (my kids') came home on a flatbed. Like kids do, they thought 10 more miles with a blinking coolant light wasn't too far. Bad bad choice. The deal is that Cosmo now sits where Flossie Winters! The full gasket rebuild kit is on the bench. There is a telltale bent pushrod tube and the engine will sputter to a start an die. They really really killed the (original?) engine. Bad choice on their part. So, its a TIME deal for ME, and for them, well, too bad if I have to put the tow bar on and pull it out soon'ish.
The money? Hmm... Funny how that works isn't it? The kids are living with nearly zero expenses right now, so they actually have more in the bank than I do. (They don't live with me any more tho, at least) But I don't think they will be putting a rod/bolt/ring rebuild into the mix.
Right now in the lineup are two unknown engines, and 1 known severely damaged one.
The kids are tearing down the one in the van. I suggested they take a look at it and they started, before anyone looked at the pushrods/tubes --- one is bent --- likely broken valve caused this, so thinking about looking at the piston tops to see if that is a non-start for basic build.
Here are the three:
#1 in Cosmo now
#2 sitting on floor from DoubleCheese parts rig
#3 longblock I snagged a while back as a possible spare, also unknown condition
Which leaves me with my running 2.1 in Flossie, and a EJ22 as my only option if I let them destroy my other options.. I don't like getting cornered
PostPosted: Tue Oct 17, 2017 12:28 pm    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
-dan
Got a cutting/heating torch setup, checkmark
Exhaust teardown, no fun, also checkmark (third time is the charm?)
Head-reseal, gasket kit in hand, so checkmarkable
Rod rebuild with the 1.9 rod/bolts, not-yet-checkmarkable
Possibly up to 5 heads to choose from, I guess.
question at the far end.. how to tell if crank journals (not connecting rod ones) are good without splitting the case?
djkeev
djkeev is offline
PostPosted: Tue Oct 17, 2017 1:00 pm    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
You have no way to know if the crank mains are good without splitting the case or to get it running and put an oil pressure gauge on it.
Dave
Ghia
Vanagon
Beetle
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Tue Oct 17, 2017 1:02 pm    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
From what I've been able to glean over the years, the 2.1WBX cranks don't wear their thrust surfaces quite like the old AC bottom ends. I'd think that if the rod journals looked good then the crank journals would likely be in similar condition. I'd be far more concerned about the cam lobes.
Casey--
'01 Weekender --> full camper
y u rune klassik?
djkeev
djkeev is offline
BTW, don't be too harsh on them running with a warning light on.
Cars today are so dumbed down with that stupid and annoying "Check engine" light.
These lights are often on for tens of thousands of miles with no harm done.
Warning lights to kids today are absolutely meaningless.
Dave
Ghia
Vanagon
Beetle
PostPosted: Tue Oct 17, 2017 1:10 pm    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
Dave
Noted, thanks.
Its a process of learning. I hope they do the Learning before I get too frustrated tho. I just get cranky thinking Flossie is getting rained on and starting to frost on her at night.. I guess I could put a tarp on her. But, I'd also like to keep driving her to work while the salt isn't on the roads yet. Some nights I have on-call duty, and can't afford the half hour of drive time to go home for a nap. I just drive Flossie and use lunch hour as nap time... I feel a little like a kindergartner again.
djkeev
djkeev is offline
PostPosted: Tue Oct 17, 2017 1:15 pm    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
Back in the 70's my cousin had a Beetle. She was your stereotype cute blonde, she fried a couple of engines.
My Uncle in frustration wired the oil light to a relay that shut off the ignition.
That fixed the engine problems.
Dave
Ghia
Vanagon
Beetle
PostPosted: Tue Oct 17, 2017 1:25 pm    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
So, the general thinking here is that the bottom end is probably good in one of the three candidates... ZG brings up the cam lobe concern, which I have to think would be of greater concern in the one which bent the pushrod/tube. Maybe the hydraulic lifter saved the lobe?
I've been pondering how to get a "read" on the connecting rod and wrist pin condition in a minimally invasive manner.
Any way to tell by "feel" if there is play, heads off cylinders on, pistons in place? Any creative method to tell the 2 thousandths that would be unacceptable wear? Or is it less that that? I'm sure if it were more, it would be humanly possible to feel a clunk if pushing the piston down after the crank got to bottom dead center for each piston, but 2 thousandths? Not imaginable. Maybe there is a tool?
djkeev
djkeev is offline
PostPosted: Tue Oct 17, 2017 1:30 pm    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
Pull the heads and cylinders, remove the rods...... easy peasy.
Dave
Ghia
Vanagon
Beetle
PostPosted: Tue Oct 17, 2017 1:43 pm    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
Dave,
I am good at unbolting things. I could do just that, and then I'd be sitting with a bench full of parts and no idea about what to do next. I am sure that if I had a few 1.9's around, I would have already done such a thing, and have the rods from those ready. It's all the finicky tiny-tolerance things that I balk at. I guess I have seen a Mic used a few times, and they are not that expensive. I guess I could find out what each rod journal measured and get proper replacement bearings sized in those 1.9 replacements. Or, I guess I could give the kids the Subaru ej22 and harness, and let them get the install kit from Kennedy. That would be so much easier than doing any of this myself.
But, I guess I'm just Dad here, and trying to help the kids figure out how to live life. Time to quit shaving the Yak, and get their rig out of my shop.
djkeev
djkeev is offline
PostPosted: Tue Oct 17, 2017 3:04 pm    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
Worry about reassembly after you find out if it is worth reassembling.
On an Air Cooled we would pull the #3 Rod, the cylinder most likely to suffer damage.
Dave
Ghia
Vanagon
Beetle
DanHoug
DanHoug is offline
PostPosted: Tue Oct 17, 2017 8:15 pm    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
you don't really need to get a 'read' on the con rod condition in a 2.1... just replace them with a reconditioned set with 1.9 non-stretch bolts and new bearing shells. we're talking $150. buy a cheap digital caliper and it will tell you close enough if the rod journals are stock size. if they look all shiny and polished without streaks or grooves, then go fer it. "they" say rod failure in the 2.1 can happen anytime around 165k miles, which the above work mitigates. i also know of many high mileage vans where this never happens.
or there's nothing wrong with just doing the head gaskets while the engine is out. you spend more, you get more assurance. or insurance as it is, against failures. it's all an odds game when there isn't critical teardown and examination. in the words of Dirty Harry... "Do you feel lucky, Punk? Well, do ya?" mission critical = do the most you can. kids van with AAA membership = do whatever.
nothing wrong with picking your best, low mileage core that looks the happiest, doing the minimum (which i consider head gaskets always), and trying it out with the understanding of the risks. i went the other direction hoping for another 100k miles.
-dan
djkeev
djkeev is offline
PostPosted: Tue Oct 17, 2017 9:47 pm    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
With all due respect to Dan ^ I disagree.
The connecting rod bearing is the weakest link on the crankshaft and is where excessive wear or oil problems will manifest itself first.
By pulling the rods you instantly know if you have a potentially good engine or if you should stop and move on to the next engine now. This is "reading" the bearings.
Educate yourself, this i an excellent tutorial on bearings put out by a major beating supplier......
https://www.mahle-aftermarket.com/media/local-medi...ochure.pdf
Down load it and read it all. Understand why bearing wear and what various lubrication problems look like on the bearing surface.
This link has color photos which make it much easier to understand the typical wear issues......
http://www.speedperf6rmanc3.com/content/Engine%20Bearings.pdf
The repair isn't hard when you pull the rods, it only sounds hard.
Dave
Ghia
Vanagon
Beetle
DanHoug
DanHoug is offline
PostPosted: Wed Oct 18, 2017 4:16 am    Post subject: Re: oil pressure test in non-running 2.1 WBX? Reply with quote
actually, Dave, i'm 100% on the same page as you. that's why i went down the Rabbit Hole and did this plus a ton of other stuff on my 'low mileage' 90k mile core. and i ended up with an engine with great hot oil pressure and should run reliably for another 100k.
but if he's feeling lucky, and it totally is luck, he could just do gaskets and slap it together to see what he has. spin the big wheel. there were many vanagons used for medical transport around here that did 400k miles without engine work other than head gaskets and water pumps. you and i are not comfortable with that approach but the payoff *might* be hardly any work for a serviceable engine. maybe. maybe not.
but i'm guessing he's going to pull a head and cry a little bit at the head corrosion. if i had to buy new heads, i wouldn't take a chance on the rods and i'd do everything right. too much money invested at that point to risk it. go big or go home.
-dan
