vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 350 Location: Green Bay, WI
Posted: Tue Oct 17, 2017 4:16 pm Post subject: Build Suggestions for 40 HP with Saxomat |
I've got a 1964 Beetle with the original engine. The oil light is coming on at idle when the engine is warm, so it's time to pull the motor and rebuild it this winter. I'm not looking to go fast, but a little bump in power to keep up with traffic would be nice.
My limiting factor is the 160mm Saxomat clutch.
I'm thinking 83mm pistons/cylinders and 1.1:1 rockers with the stock 28 PICT should be fine. Would a mild cam be too much? There's also a bronze sintered centrifugal clutch, made of unobtainium, that's fully engaged at about 1200 rpm. So it might be good to move the peak torque higher up in the rev range. _________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Thu Oct 19, 2017 5:23 pm Post subject: Re: Build Suggestions for 40 HP with Saxomat |
The 83mm P/C set will give you enough power increase to be noticeable.
I'm sure the 1.1:1 rocker arms will help a bit, but that gain will be dwarfed by the increased displacement.
My son has been driving a 40hp 83mm Big Bore for perhaps the last 10 years. He likes the '67 30PICT with the 40hp distributor.
I really like stock camshaft grinds with stock carburetors. Maybe someone else can give you some better advice on how to make that choice. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Fri Oct 20, 2017 4:20 am Post subject: Re: Build Suggestions for 40 HP with Saxomat |
I had a stock 1200 in my 65 and did the big bore upgrade a few years ago with a 28PICT 1 and one of Glenns 019 distributors. HUGE difference. The car runs as strong as a stock 1600, BUT keep in mind that I still have a stock geared transaxle, so that also helps the low end. You will want to rejet the carb to be a little fatter. Made a substantial different. Not sure how much anythingh like the higher lift rockers will do since you are limited on the top end by your intake and exhaust (if staying stock)
Since you are tearing it down, you definately need to mock up the p/c on cylinder 3 because you will likely have interferance issues. There are threads about this. Oh - find a set of 65 square boss heads (also covered here). _________________ D-Dubya Manx clone - 63 Short pan,1914.
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
vwoldbug Samba Member
Posted: Wed Oct 25, 2017 9:43 am Post subject: Re: Build Suggestions for 40 HP with Saxomat |
Will 1300 cylinder heads fit and the 67 carb will help . |
Posted: Thu Oct 26, 2017 4:59 am Post subject: Re: Build Suggestions for 40 HP with Saxomat |
No and maybe....If you increase displacement, more carb is not a bad thing. Dont know if i would suggest a larger carb with the stock displacement. Bigger is not always better. That being said, I have replaced a leaky 28 PICT on a stock 64 bug with a 30 PICT 1 and the car ran well. No better or worse. The main reason was that we converted to 12V and I didnt have any 28 PICT-1 carbs (that can use a 12V choke) in my stash.
For a 1200, its typically suggested to use the 65 square boss heads. From everything I have read, they are the best stock head for this application. That is what I have on mine and they work well. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7212 Location: Videbaek Denmark
Posted: Sat Oct 28, 2017 12:33 pm Post subject: Re: Build Suggestions for 40 HP with Saxomat |
IMHO
The increase in displacement only works in the lower rpm. as soon as the engine gets above approx 2500 it is limited by the intake manifold. I have tried to see if a 1200 cc with stock intake would benefit from a little more cam duration and CR. but the improvement is so minor that it is not worth it.
The swop to 83 mm big bore is good as such. But if you want to be able to enjoy it in the "entire" rpm band you shoud swop to 1300 sgl port heads at the same time. If you want a little more you can swop to the CB 2280 cam. Go 8,5 CR and masage a stock 1300 intake manifold to fit on the narrower engine and use a 30 mm Pict 1 &2 carb. That will give you a noticeable power increase which will suit the Saxomat just fine.
with the clutch. I actually think the stock parts will hold the extra torque. But if you want to make sure that you do not have to get in there again you can send the disc to a clutch specialist and get a lining mounted that has a higher grip coifcient. You can get anything from +10 to +70%. I have used sintermetal discs many times with the Saxomat and up to 1776 cc. engines. Then itīll hold at least 83 hp and 150 Nm torque, which is the highest I have tried. This was with a ī74 1300 original set up. I doubt there is much difference except maybe a tad higher clutch pressure. but that can be fixed too. No problem.
T |
Fifty-Eight Rag Samba Member
Joined: September 07, 2011 Posts: 936 Location: St. Louis, MO
bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Thu Oct 08, 2020 5:26 pm Post subject: Re: Build Suggestions for 40 HP with Saxomat |
Dry interesting thread. I'm looking to do this with both my 1500 Squareback using the totally stock 1500 mated to a saxomat and with my bus using a 25hp case and Okrasa kit to make 1500 as the pre A 356 did, again mated to the saxomat but it needs modifying to fit the 25 horse set up.
I don't think I have quite enough saxomat Parts for two set ups, the key component I am missing is the diving clutch pressure plate. If anyone knows of one for sale I'd be most appreciative.
Cheers. Dave |
