skimhead Samba Member
Joined: September 14, 2005 Posts: 108 Location: Vancouver Canada
Posted: Tue Oct 17, 2017 10:53 pm Post subject: valve slipping |
Hi, last summer I did a 1000 mile highway roadtrip and had to adjust Cyl #3 exhaust valve 4 times (to increase gap). I did notice the engine miss about 4 times also. CHT never rose above 425F. Other valves held their clearances. I'm planning a trip 8 times that long this winter and expect that adjusting valves every 250 miles will be problematic, if not fatal. I've had issues with valve seats sinking/dropping before but very rarely since driving with a CHT. The motor was rebuilt (top/bottom) about 4000 miles ago or less.
Thx, Andrew |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3551 Location: San Diego (Encinitas)
Posted: Tue Oct 17, 2017 11:45 pm Post subject: Re: valve slipping |
Model year? Engine type? _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Wed Oct 18, 2017 12:44 am Post subject: Re: valve slipping |
1979 panel hightop Bay
2 liter FI |
my59 Samba Member
Joined: August 13, 2003 Posts: 3791 Location: connecting the dots
Posted: Wed Oct 18, 2017 2:30 am Post subject: Re: valve slipping |
Recessed valve seat or valve stretching.....but why are you increasing gap? 79 FI would be hydro lifters if it was stock, and your adjustment would be 1.5 to 2 turns after contact of adjustment tip.
What was done during rebuild? _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Wed Oct 18, 2017 5:32 am Post subject: Re: valve slipping |
If you are having to adjust your valve lash that often with solid lifters then the head needs to come off and be properly rebuilt or replaced with a new one.
If you have hydraulic lifters, four adjustments of 0.006" each would add up to .024" total or about 1/4 turn of the screw. Photographing the head would be a good way to keep track of the position of the screws. |
Posted: Wed Oct 18, 2017 11:16 am Post subject: Re: valve slipping |
I'm using solid lifters |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Wed Oct 18, 2017 11:21 am Post subject: Re: valve slipping |
X2 on head rework- How many miles on the engine since overhaul and who's heads are on there now-- WAY better than dropping a valve- [img][/img] _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
SGKent Samba Member
Posted: Wed Oct 18, 2017 11:24 am Post subject: Re: valve slipping |
(1) how old are the heads? Or were the heads rebuilt or replaced with new, and who did the work?
(2) how much did you have to adjust them?
(3) was the engine cold each time you did the adjustment? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Oct 18, 2017 1:22 pm Post subject: Re: valve slipping |
not sure of age of heads, were rebuilt approx 4k miles ago by The Bug Shop in Delta BC Canada. Each adjustment was from no gap to .008" with engine cold |
SGKent Samba Member
Posted: Wed Oct 18, 2017 1:26 pm Post subject: Re: valve slipping |
the heads need to be replaced. Buy new ones from Len Hoffman. https://newsite.hamheads.com/2017/01/16/vw-2-0-transporter-cylinderheads/
It is possible a valve is stretching or a seat was not put in right, but you have a long voyage ahead so I would not trust the heads you have on it now. These bus engines were kinda built with disposable heads. They really run hot because of how they are used. Original heads for a 1979 bus are almost 40 years old with most of their life severe service due to the temps they run at. What you are seeing is not uncommon. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Thu Oct 19, 2017 12:12 am Post subject: Re: valve slipping |
People use the term “rebuilt engine” loosely. One guys rebuild isn’t equal to another guys rebuild. T4 heads seem to be the biggest failure point on these engines. That’s why it’s very important to include the highest quality possible and I’ve seen a pair of these heads cost $700 to rebuild. That’s was roughly 8 years ago. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri Nov 10, 2017 9:57 pm Post subject: Re: valve slipping |
Hi, I just purchased a new 1800cc AMC head from CIP. The studs were not installed but included in a separate bag. I need to know the torque specs for the different studs ie rocker-arm, intake, exhaust studs.
Thx, Andrew |
Posted: Fri Nov 10, 2017 10:10 pm Post subject: Re: valve slipping |
skimhead wrote: |
Thx, Andrew |
When needed I just look such things up in one of the various shop manuals I own. Haynes, Bentley, Muir, or any of several others all have this info. |
timvw7476 Samba Member
Posted: Fri Nov 10, 2017 10:49 pm Post subject: Re: valve slipping |
skimhead wrote: |
Thx, Andrew |
I do recall the exhaust stud nuts are about 14 foot pounds.
Ridiculously low, but VW assumes your heat exchanger support struts are
still intact to hold some of the weight (mine weren't) I went to 18-20 ft/lbs
with new copper self-locking nuts. The studs themselves are just a snug fit
in the castings, all those nuts are supposed to be well under 20 ft/lbs. |
Posted: Fri Nov 10, 2017 10:54 pm Post subject: Re: valve slipping |
manuals do not contain info on stud installation torque just nut torques |
tommu Samba Member
Posted: Fri Nov 10, 2017 11:11 pm Post subject: Re: valve slipping |
You'll need to search around for previous discussions, like this one:
https://www.thesamba.com/vw/forum/viewtopic.php?t=553943
I think you're looking more for an idea of stud installation technique than specific torque values. Of course once the stud are in then nut torque is critical. _________________ |
Posted: Sat Nov 11, 2017 1:32 am Post subject: Re: valve slipping |
any tips on stud installation appreciated thx |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sat Nov 11, 2017 4:20 am Post subject: Re: valve slipping |
I've always just jammed two nuts together on the stud, screw the stud in and lightly tighten it. Maybe 5 ft-lbs. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Sat Nov 11, 2017 4:52 am Post subject: Re: valve slipping |
skimhead wrote: |
There is no torque spec on stud installation because the stud is torqued when the nut is applied not when the stud is installed. You just need to get each stud in sufficiently deep, which in most cases on the heads will mean it is lightly bottoming out. You can use a tape measure to see if all the studs of the same type went in about the same depth, if one stud is sticking out 1/8" or more than the others you should check to find out why it isn't going in further. A drop of oil on the threads will ease installation. |
Posted: Sat Nov 11, 2017 12:00 pm Post subject: Re: valve slipping |
thank you all for your information |
