jacksonp32 Samba Member
Joined: November 28, 2015 Posts: 377 Location: fort collins
Posted: Wed Oct 18, 2017 9:08 am Post subject: front brake chirp/squeak!!! |
Before i start... keep in mind i have DISC BRAKES up front!!! This problem is finally driving me mad. my front wheels/brakes begin making a chirping noise as i am driving. it is much worse on the passenger side, but is also a little apparent on driver side. it doesnt automotically chirp while rolling, but as i am driving, give it a few seconds when at a constant cheap and it goes "chirp chirp chirp chirp" constantly and quickly. The moment i press the brake pedal to even the slightest bit, the chirping stops for about 5-10 seconds and begins again, and the cycle continues. I have lifted the front wheels on my car, depressed the brake pedal fully and multiple times to check if the brakes are releasing and not sticking, and there is slight drag, but no worse than any other vehicle i dont think. tie rods are brand new, alot of new steering components, aligned correctly, yada yada. any idea? its driving me mad! |
Tom Butler Samba Member
Joined: October 03, 2016 Posts: 287 Location: Bay Area, California
Posted: Wed Oct 18, 2017 9:35 am Post subject: Re: front brake chirp/squeak!!! |
jacksonp32 wrote: |
people are going to want more information as to what year and stuff your car is just an FYI.
did you do the brake swap yourself or did it come with the discs? _________________ 1971 Super Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=674120
Proud Member Pata De Perro Vw Club
iowegian wrote: |
Instead of converting your car to a different color, why not just buy one that is a color you like? |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Wed Oct 18, 2017 9:44 am Post subject: Re: front brake chirp/squeak!!! |
Sorry to hear this. I've never felt a disc system that didn't have a tiny drag off the ground, so I don't think that's the root cause of your issue.
Have you checked both discs for axial runout? I do not recall the tolerance for any particular car, (what car are your discs off of?) but my Jetta had a disc with .010" runout and it chirped like mad.
www.airschooled.com |
Posted: Wed Oct 18, 2017 9:50 am Post subject: Re: front brake chirp/squeak!!! |
asiab3 wrote: |
Robbie |
I actually did check the runout on my discs at one point last year. I dont recall the measurements, but it was a very minimal measurement. I'm honestly unsure of what the disc setup is, because it was on the car when i got it. im assuming it some remanufactured empi type of kit..
and what more info is needed on the car? engine type and year shouldnt make any impact... its a 1970 beetle with a disc setup |
Posted: Wed Oct 18, 2017 10:14 am Post subject: Re: front brake chirp/squeak!!! |
jacksonp32 wrote: |
asiab3 wrote: |
Robbie |
This forum is quite broad. Supers and what not being talked about here. _________________ 1971 Super Beetle
iowegian wrote: |
sb001 Samba Member
Posted: Wed Oct 18, 2017 10:28 am Post subject: Re: front brake chirp/squeak!!! |
jacksonp32 wrote: |
Some brake pad manufacturers suggest the application of thin coat of grease to the pads to quiet them, others (like the Wagner thermo-quiet pads) you are not supposed to use that stuff. Or some use shims and some don't. Admittedly I am not too up on the disc brake scene but is it possible your pads are using shims when they are not supposed to, or not using a bit of grease when they are? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Wed Oct 18, 2017 11:33 am Post subject: Re: front brake chirp/squeak!!! |
sb001 wrote: |
jacksonp32 wrote: |
Some brake pad manufacturers suggest the application of thin coat of grease to the pads to quiet them, others (like the Wagner thermo-quiet pads) you are not supposed to use that stuff. Or some use shims and some don't. Admittedly I am not too up on the disc brake scene but is it possible your pads are using shims when they are not supposed to, or not using a bit of grease when they are? |
thats actually a very good thought. I am in need of new brake pads soon anyways, so i will look into that manufacturers instructions. thanks for the idea |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Wed Oct 18, 2017 12:07 pm Post subject: Re: front brake chirp/squeak!!! |
Just to be clear, the grease goes on the back of the pads, not on the friction surface. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Wed Oct 18, 2017 12:22 pm Post subject: Re: front brake chirp/squeak!!! |
Q-Dog wrote: |
Just to be clear, the grease goes on the back of the pads, not on the friction surface. |
Dont worry, im not that stupid lol! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Wed Oct 18, 2017 12:47 pm Post subject: Re: front brake chirp/squeak!!! |
jacksonp32 wrote: |
Before i start... keep in mind i have DISC BRAKES up front!!! This problem is finally driving me mad. my front wheels/brakes begin making a chirping noise as i am driving. it is much worse on the passenger side, but is also a little apparent on driver side. it doesnt automotically chirp while rolling, but as i am driving, give it a few seconds when at a constant cheap and it goes "chirp chirp chirp chirp" constantly and quickly. any idea? its driving me mad! |
Some brake pads have little wear indicators which chirp - as the pad surface wears these come into contact with the rotor and chirp, to let the driver know that it's time to change the brake pads before wear causes rotor damage.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Oct 18, 2017 2:25 pm Post subject: Re: front brake chirp/squeak!!! |
Cusser wrote: |
jacksonp32 wrote: |
Yeah I am aware of this. That isnt the problem since the brake pads arent too old. Did it on the old pads too |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Wed Oct 18, 2017 8:29 pm Post subject: Re: front brake chirp/squeak!!! |
Amazon sells a liquid supplement to apply to the backside of the pads to help reduce the vibrations you are hearing.
http://www.autozone.com/brake-and-power-steering-f...348169_0_0 _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Cusser Samba Member
broskinny Samba Member
Joined: December 04, 2005 Posts: 11 Location: Atlanta, GA
Posted: Mon Dec 04, 2017 8:10 pm Post subject: Re: front brake chirp/squeak!!! |
I’ve experienced this before. This chirping can happen if the front wheel bearings are adjusted a bit loose.
Also, while the front wheels are off, confirm that the calipers are centered with the rotors. Some aftermarket kits need the calipers shimmed on the spindles for rotor/caliper clearance. _________________ '73 Std. Beetle
Peach State Vintage Vdubbers |
