sweetguth Samba Member
Posted: Wed Oct 18, 2017 12:58 pm Post subject: Electromagnetic cutoff ? |
I got my 72 SB buggy back from being rewired. I noticed there is no wire connected to the electromagnetic cut off on the carb. What should be connected to that? |
bluebus86 Banned
Cusser Samba Member
Joined: October 02, 2006 Posts: 31359 Location: Hot Arizona
Posted: Wed Oct 18, 2017 1:43 pm Post subject: Re: Electromagnetic cutoff ? |
bluebus86 wrote: |
should be off the spark coil, the ignition side. It was orignally daisy chained with the wire that feed the electric choke heater. Black wire as I recall |
Black wire, female connector to coil positive terminal #15, runs to electric choke heater and electrojet on the carb, so female connectors on all three "legs" of the "Y" wire. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Wed Oct 18, 2017 2:25 pm Post subject: Re: Electromagnetic cutoff ? |
If the wire is not connected and the car still idled, it is likely that the plunger end of the solenoid has been chopped off. It might be worth removing it to inspect before connecting a wire that might not do anything.
Just because solenoids have a 13, 14, or 17 mm hex on them doesn't mean they need to be cranked down tight! Snug will do just fine.
www.airschooled.com |
