911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Thu Oct 19, 2017 4:04 pm Post subject: Metal button on cylinder head-intake side |
I've just about to start my dual 40 Weber install on my stock 1600 dual port engine when I noticed these two metal buttons on the intake port.
Obviously, they will have to be removed to install the dual carb manifolds, but I'm not sure how to do it.
How do I get these off?
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Thu Oct 19, 2017 4:06 pm Post subject: Re: Metal button on cylinder head-intake side |
Grab it with a pair of vice grips and slowly twist out. _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76909 Location: Sneaking up behind you
ViseGrips.
It's just a locating dowel. _________________ Glenn
Member #1009
#BlueSquare |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Thu Oct 19, 2017 4:31 pm Post subject: Re: Metal button on cylinder head-intake side |
Or mark your manifolds and drill a hole to fit the pin...would be simple |
Posted: Thu Oct 19, 2017 9:17 pm Post subject: Re: Metal button on cylinder head-intake side |
Thanks-I'll try the vise grips tomorrow. |
mark tucker Samba Member
Posted: Fri Oct 20, 2017 7:17 am Post subject: Re: Metal button on cylinder head-intake side |
light tap's back & forth then it should pull out just fine. |
Posted: Fri Oct 20, 2017 10:02 am Post subject: Re: Metal button on cylinder head-intake side |
Thanks Mark. |
