heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6593 Location: Houston, Texas
Posted: Sat Oct 21, 2017 10:22 pm Post subject: Re: replacing master cylinder |
Look for the rubber band trick. I've seen it mentioned. _________________ www.vwnos.com [email protected]
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sat Oct 21, 2017 11:23 pm Post subject: Re: replacing master cylinder |
Tightly wrap a rubber band or twist-tie around the cable eye and clutch arm at the pedal. This keeps the cable eye from disengaging while you're positioning the pedal assembly. The rubber band or twist-tie will eventually fall away.
You can also have someone hold the transmission-end of the cable taut while positioning the pedal assembly.
I have a custom bearing/locknut at my clutch shaft, so it can't come off while I'm installing the pedal assembly. I like to cheat, you see.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
bluebus86 Banned
web macomber Samba Member
Joined: December 02, 2010 Posts: 274 Location: Webster Wisconsin
Posted: Sun Oct 22, 2017 7:05 am Post subject: Re: replacing master cylinder |
ok thanks, back to my original question about the little hoses that connect the tube from the reservoir to the MC. I have some 5/16 fuel injection hose. Would that be ok until I can find some brakes hose?
web |
bluebus86 Banned
Posted: Sun Oct 22, 2017 8:52 am Post subject: Re: replacing master cylinder |
web macomber wrote: |
web |
If it fits and dont leak it will work in suppling brake fluid to the master. long term it may deteriorate, but for short term it probably wont harm anything the newer lined with fluoropolymer hose as found in 30R9 rated hose likely is safe to use long term I suppose, but I have not tested that.
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Mon Oct 23, 2017 11:44 am Post subject: Re: replacing master cylinder |
Thanks everyone. I didn't know if I should start a new topic for this or not but it is related.
n
Trying to put the pedal assembly back in. I have done a fair amount of things to bugs but this has to be the most frustrating!! OMG, I had to walk away 4 times. Are there any tricks besides the "rubber band" thing?
Web |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Mon Oct 23, 2017 12:27 pm Post subject: Re: replacing master cylinder |
The easy way is to have a helper hold the opposite end of the cable and keep some tension on it while you put the pedals back in. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4520 Location: Oklahoma City, OK
Posted: Mon Oct 23, 2017 3:46 pm Post subject: Re: replacing master cylinder |
Fast two minute mod that keeps the clutch cable on pedal arm during install, picture shows where to drill two holes in the arm, put the cable on the arm, string a short length of metal wire through the two holes then twist the ends together, pack the end with grease, I like Super Lube, install, cable will not come off nor the wire interfere with the operation. I use 1/32" drill for the wire is .020, had to use 1/16" drill when I broke a 1/32" drill bit.
Sorry do not have a arm laying around to demonstrate with, instead you get my 1st grade artist training
Posted: Mon Oct 23, 2017 4:04 pm Post subject: Re: replacing master cylinder |
For some reason, installing the pedal assembly is one job I have more trouble with than any other. Take into account that my clutch shaft doesn't have a hook where the clutch-cable eye can slip off, but I still have trouble.
The main thing is to remove the seat so you can get all up in there. The other "trick" is to position the pedals properly (this is trial and error, but it seems the pedals want to be in a certain alignment before it all comes together). The other trick is to have a long enough, thick round Phillips screwdriver to help locate the threaded tunnel holes, once you have to pedal assembly flush against the tunnel.
That rubber band, wrapped nice and snug, holding the eye of the clutch cable is a must in my opinion, unless you have a helper holding pressure on the opposite end. But I'd still wrap the hook with a rubber band.
Richard O'Brien |
Posted: Mon Oct 23, 2017 5:18 pm Post subject: Re: replacing master cylinder |
Thanks for all of the advice thus far. I can see how it has/would work in general but I feel like I am losing my mind. As I mentioned, I have worked on VW's for years but this has to be the most frustrating task. For those of you that say well maybe it's you, I will agree! Okay, is it possible to secure the clutch cable, align the pedals to set the spring properly and get the brake push rod in the hole?
I seem to be having more success getting the assembly ready to bolt in and then screwing in the push rod. Is that not right?
why do we do this,
web in wisconsin |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Mon Oct 23, 2017 6:19 pm Post subject: Re: replacing master cylinder |
Tim Donahoe wrote: |
The main thing is to remove the seat so you can get all up in there. |
I don't remove the seat, I just move it back. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
