Chris333 Samba Member
Posted: Sat Oct 21, 2017 1:33 pm Post subject: No clearance Clarence |
Putting my 1600 engine back together and when I pop the carb on it rests right up against the fan shroud. The stock oil bath air cleaner barely fits as well. I know someone will mention my chrome cylinder tins, but the dog house in the shroud lines up with the oil cooler.
Only thing different is the PO cut the heat rise tubes off the manifold so I used a 1500 1968 manifold that looked identical.
Any idea what I'm doing wrong here. Is the round tin bolted to the generator on correct?
There is a small deflection of the belt too. Like the gen sticks out further than the crank. Even though the pulleys are chrome, they are the same size as what I took off.
bluebus86 Banned
Posted: Sat Oct 21, 2017 2:02 pm Post subject: Re: No clearance Clarence |
Pulleys must line up, carb must not rub, else it wear a hole in it.
aftermarket tin might be the issue. But I think you have a mix of incompatible parts
the generator strap by the way is orientated wrong, but that is seperate issue.
looking at the generator backing plate, yours is indented outwards. on my 1973 motors doghouse shroud it is indented inwards, on my stock 66 it is indented outwards.
it may also be an alternator type, verse generator tyle as I think alternator as shorter than generators.
looking at my Orange late model Bentely service book, figure 6.7 of the electrical section, there is a cut away diagram, of side view of generator and fan, and it clearly shows the backing plate should be indented inwards, thus moving the genrator toward the fan house. the base of generator should be inwards to the rear plane (nearest to rear of car) of the fan house.
so It appears you have the wrong generator backing plate for use with the dog house shroud.
The manifold you have is not stock use for the the dog house as I believe the dog house was used on dual port motors. That might be the issue with the carb.
also note if you use the dog house shroud you MUST use the later wider fan, and dont forget other little things like the important "hoover bit". if this hoover bit little peice of metal is missing, you lose cooling air for the oil cooler. seach Hoover bit if you dont know what it is. also dont forget the roam tape seal around the cooler and a thinner foam tape around the cooler duct work, else cooling air bypasses the cooler and hot air leaksmout the duct work, sucked back into the cooling fan.
so it appears you have a mix of different style parts, the generator backing plate is almost certainly wrong for the shroud as per the Official VW Service manual (Orange Bentely Book)
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
bluebus86 Banned
Posted: Sat Oct 21, 2017 3:29 pm Post subject: Re: No clearance Clarence |
Thanks I checked the diagram in the Bently. If I flip the front piece over it doesn't line up with the back.
The fan is the thicker one made for the dog house shroud.
This is the 1500's non doghouse gen:
The 1600 is from a 1970, but the block is from around 1974ish. Heads are probably 1970 (last year for single port) From what I've read the doghouse offset cooler is a good thing and 3&4 won't overheat. I have the hoover bits installed, but still need to get the foam strips.
So with a doghouse shroud, wider fan, offset oil cooler and single port heads. Can I make this work?
Do I need a special generator tin? |
Posted: Sat Oct 21, 2017 3:34 pm Post subject: Re: No clearance Clarence |
And since we're talkin'... how should my gen strap go? |
bluebus86 Banned
Posted: Sat Oct 21, 2017 5:39 pm Post subject: Re: No clearance Clarence |
Chris333 wrote: |
the strap should be formed to fit over the stand for generator., the strap should be countored for a nice fit, this puts the bolt at near the 3 oclock or 2 oclock position roughly, _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
bluebus86 Banned
Posted: Sat Oct 21, 2017 5:43 pm Post subject: Re: No clearance Clarence |
my thought is the backing plate you have might be the wrong one for the doghouse generator combo mine appears different on my 73 motor, but it was fitted with an alternator, and it is much different than my stock 66 backing plate, there thus are at least 3 types, maybe more?
but for sure, Id say the plate you have is wrong, that is a significant offset of your pulleys it appears, how much of an offset is it, half an inch, one inch or?? _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
bluebus86 Banned
Posted: Sat Oct 21, 2017 5:53 pm Post subject: Re: No clearance Clarence |
See link below...
https://www.thesamba.com/vw/forum/viewtopic.php?t=643780&highlight=generator+backing+plate
note post by "royraison" near end of thread, he states there is a 30 amp generator and a 38 amp generator, the 38 Amp one is 1/2 inch longer than the 30 amp one, and hence needs a different backing plate.
read the numbers off the generator, it should indicate voltage and amps, which do you have? see first port photo on that thread, showing the stamping on generator housing indicating amperage
measure length, it appears you have more than one if the other one is shorter, use it.
next we need to determine if your intake manifold is compatible with the shroud. as far as I know only dual port manifold came with the dog house style. but maybe yours is simply mounted crooked. even on my stock 73 motor (dual port, with doghpuse shroud, all stock) the carb to shroud clearence is small, on krder of quarter inch or so. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
bluebus86 Banned
Posted: Sat Oct 21, 2017 6:06 pm Post subject: Re: No clearance Clarence |
I just check my kit car,,it has a stock vw doghouse shroud, and 30 generator, the backing plate surface is above 1/8 inch above the rasied lip around the plate. lay a straight edge on yous and tell use the gap between the surface the generator mounts on and the top of the raised lip around the plate. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
bluebus86 Banned
Posted: Sat Oct 21, 2017 6:15 pm Post subject: Re: No clearance Clarence |
See link, near end of thread see lost by "dalotheman" with photograph of the offset caused by aftermarket cylinder tin. maybe this is your problem for BOTH the carb and pulley fit issue. regardless of the oil cooler, this might be it.
someone else wrote that all the 12 colt backing plates are the same, but then the other person said that the the 38 amp generator requires different parts to fit, (pulley or backing plate??. but that it is rare (the 38 generator that is.)
do you have original cylinder tin to compair with the chrome tin?
good luck, keep us posted _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
bluebus86 Banned
Posted: Sat Oct 21, 2017 6:22 pm Post subject: Re: No clearance Clarence |
Here is another link showing difference between the 38 amp and 30 amp backing plates...
https://www.thesamba.com/vw/forum/viewtopic.php?t=479291
so if you have a 38 amp generator, you need the dished inwards plate, it is noted it is a rare part, for Busses. if your generator is a 30 amp, the plate is nearly flat, only raised about 1/8 inch above the lip as I have measured.
so if that is the case, you either have a poorly made aftermarket plate that sticks out too far (lay a ruler on it and see how much the flat part stands above the lip, OR you fan house is located too far back towards rear of car, likely culprit then would be the aftermarket cylinder tin as discribed in the link I gave you on one of my prior posts. since your carb is also hitting, I strongly suspect it is the aftermarket cylinder tin that is wrong. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
bluebus86 Banned
Posted: Sat Oct 21, 2017 6:30 pm Post subject: Re: No clearance Clarence |
on your first post, last photograph showing the cooler, I think I see the cylinder tin to fan house flange bent forward toward the tranny, that is wrong!!! the cyljnder tin flanges are supposed to fit nicely on the outside of the fan shroud nice and tight, your cylinder tin flange looks peeled back and the shroud is to rear of car from it.. also the shround should rest against a rib on top of the case, rib being inside the shroud on the carb side of the shroud.
bluebus86 Banned
bluebus86 Banned
Posted: Sat Oct 21, 2017 6:53 pm Post subject: Re: No clearance Clarence |
Thanks for all the responses. I'm at work right now so can't check anything.
My pulleys are maybe 3/16" off or a little less. But my accelerator pump linkage is right up against the backing plate.
When I search backing plates, they all look like mine. Hope I can find the right one.
As for the clamp. I mounted it just like the photo I took before tearing the engine down. I can fix that though. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Sat Oct 21, 2017 7:03 pm Post subject: Re: No clearance Clarence |
Try posting an image of the carb and intake manifold from the left side. Would help greatly to get edge of head tin in lower image. _________________ In Stereo, Where Available! |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6595 Location: Houston, Texas
Posted: Sat Oct 21, 2017 8:04 pm Post subject: Re: No clearance Clarence |
I think there is a plate you can put between the intake and carburetor which will raise the carburetor up a bit. This will help with the clearance.
If you get everything else right you might not need it. Also, adding the plate may cause some other problems. _________________ www.vwnos.com [email protected]
bluebus86 Banned
Posted: Sat Oct 21, 2017 8:29 pm Post subject: Re: No clearance Clarence |
kawfee wrote: |
If you get everything else right you might not need it. Also, adding the plate may cause some other problems. |
the plate or stand off discribed is for conversion of an alternator on an early car, it raises the carb to allow the accelerator pump linkage to clear the fatter alternator verses the thinner generator. since the problem here is the carb hitting the fan housing, raising the carb wont be the solution. I think the fan housing is mounted in the wrong spot, as evidenced by the generator being too far towards rear of car. move the housing forward and both generator and carb problem will be solved. it looks to me it is probably an issue related to aftermarket cylinder tin, seeing as the fan housing is a stock one. the cylinder tin is likely causing the fanhouse to be located wrong.
but we will see. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sat Oct 21, 2017 9:58 pm Post subject: Re: No clearance Clarence |
Yeah I'll try it with the stock tins just to see. Was hoping to never have to take the manifold off again. I hate those short studs, can't even slip a washer under the nut.
More to come... |
heimlich VWNOS.com
Posted: Sat Oct 21, 2017 10:05 pm Post subject: Re: No clearance Clarence |
I was suggesting the standoff for the carb hitting the alternator. I guess I should have tuned in a bit better.
The generator is round. If it is a tin problem he may have side to side instead of just front to back issues.
For the head studs please take a picture. There should be plenty of room. Do you know what heads are on there?
I know the exhaust studs sometimes can be screwed in to far. _________________ www.vwnos.com [email protected]
